pradeepbuss
787 profile views
pradeepbuss's Achievements
  1. hello rumesh.. unfortunately my car doesnot include RPm Guage. I short TE1 E1 using wire and Enginie raise RPm for couple of second and slowly rpm back to normal(clearly hear RPM Up)
  2. Thanks tilvin , MV-5 , Davy for your valuable help. Yes Car idle smoothly. Yes i check my TPS and using multimeter it seems to be OK. MY Car only have Diagnosis box.i short T1 Te1 pin and dashboard engine light show no any problems in car. i want to clear this is only happen After Hot engine starts only. Not engines Hot. Ex: morning first start i can drive car without this problem. once drive 30min and engine warming up i turn off the car and restart this hesitation occur.
  3. yes you are correct. this problem happenin 2 situation. 1) when i change gear and try to accelerate 2) when i foot off from gas pedal (Ex :apply Break) and reaccelerate. this only happen engine hot situation Start. cold start car run perfectly normal.
  4. ok i will try to change gear oil. problem is this not occur in in cold engine start. if engine hot , stop the engine and start again imediately this hesitating (jump) problem occur.
  5. clutch replaced before 2 weeks ago.
  6. hello friends.. My car is Toyota Corolla Ae110 1996 and 165000Km on it. This is my car problem When i shift gear and accellerate car loss power for couple of seccond and suddenly car jump with sound in engine area. in the morning cold start this not happen and i can drive car whole day without stopping engine. after engine hot i turn off the engine and restart car proble is start and car jump(shake) each gear change. I think this issue occure in Engine Hot, after engine cold this not happen also note i foot off from Gas pedal and re accelerate this car jump problem occured. anyone can advice to solve this is issue i really appriciate Thanks
