Everything posted by NRA95
- Fuel Efficiency
Audio Set Up Upgrade For Honda
Oh okay. Same fuel economy with my one. I thought 6Km/L-7Km/L in the city is too low coz Stafford claims that it does 8Km/L in the city on Eco mode. But I've got only 6Km/L-6.5Km/L in the city with Eco mode. With 95 octane petrol. My one has still done only 11,400Kms though.
Ohh okay. BTW an out of the topic question. How is the fuel economy? I guess you have the 2 liter version.
Viva Elite Community
Guys, What's the maximum milage you all got from the original tyre set?
Try Gilbert & Sons. Saw a 2014 CR-V at Stafford which was fixed with a Clarion setup. It had been done by Gilbert & Sons. BTW did you buy your CR-V from Stafford?
How To Get Rid Of Oiliness On The Windscreen
Will try those. Thanks a lot for the valueable inputs everyone.
Hi all, Just wanna know a way to get rid of the oiliness on the windscreen. Any chemical to use or any place where I could get it done? Thanks in advance.
Pothole Damage To Suspention Or Any Other Part.
Thank you for the reply. Yes there was a bump on the outside sidewall where the rim was bent. But when I replaced the rim the bump disappeared. Today I went to a tyre shop & removed the tyre from the rim & checked the inside of the tire. It was 100% perfect. No damage what so ever. Anyway I put that tyre to the rear & I thought of pumping nitrogen so that the tires won't heat up a lot. Is there a need to replace the tire? There aren't any visible damages in the tire. It's 100% perfect.
<blockquote class='ipsBlockquote'data-author="Rohnd" data-cid="288963" data-time="1454254723"><p><br/> Yes , you can do a physical inspection as you suggested. The internal structure damages sometimes not visible at early stages.<br /><br/> <br /><br/> Refer below link for reference. You may get an idea.<br /><br/> <br /><br/> <a href='<a href='http://www.euroratas.lt/galery/_euroratas/kita/naudinga_informacija/radial_tire_conditins_analysis_guide.pdf'>http://www.euroratas.lt/galery/_euroratas/kita/naudinga_informacija/radial_tire_conditins_analysis_guide.pdf</a>'><a href='http://www.euroratas.lt/galery/_euroratas/kita/naudinga_informacija/radial_tire_conditins_analysis_guide.pdf'>http://www.euroratas.lt/galery/_euroratas/kita/naudinga_informacija/radial_tire_conditins_analysis_guide.pdf</a></a></p></blockquote> Will do. Thanks a lot.
Thanks for the advice. What can I do to check whether the tire has internal damage? Remove the tire from the rim & inspect? Would that be enough?
The tire pressure was around 30. And yes it was a quite a big hole. The buffer didn't touch the ground though. I still can't believe that the tire didn't crack.
Thanks a lot everyone. Relived my mind ?
Hi guys! Recently I drove over a deep pothole at around 35Kmph (Front driver's side) in my 2015 Toyota Axio hybrid. The wheel cover went flying & the rim was bent. Nothing happened to the tire though. I replaced the rim & got the alignment checked. There was a small difference in the alignment. Other than that there is no issue at all. There is no body damage or anything as. The buffer hasn't touched the ground even. But I want to know whether it could harm any suspention parts or ball joints or anything? At the moment there isn't any noice or anything. It's 100% perfect. But can it cause any problem in the long run? Anything that I should do about it? Thanks in advance.
