rcmadawala
Everything posted by rcmadawala
  1. ok I've inspected the top tank but couldn't notice a crack or leaking spot. So decided to go with the clamp. Bought a wurth clip from Link, Jubilee post before: after: Ran around 50KM and no leak so far. Let's see
  2. The same process mentioned in here http://www.trinituner.com/v4/forums/viewtopic.php?t=490906 (kudos to Rumesh88)
  3. Finally i got it done from Nuwan Auto, Pitakotte (https://goo.gl/maps/CgVCxdgCNQ82) It's a half an hour job and cost me 600 LKR. Happiness is seeing your fuel gauge is on F
  4. Thanks Crosswind. I'll check it. Meanwhile i checked eBay for woodgrain trim stickers but i think stickers might not be the best for this
  5. Ah. It might be the tank
  6. Thanks all. Then I'll cut / replace the hose and put a clamp too.
  7. Thanks PerfMad on your valuable input. So if the hose is not lengthy enough, do i have to replace the hose? If that is the case any input on where to buy would be awesome.
  8. Hi Guys, As you can see in the below image in my Nissan TIIDA Latio's driver side door pull, the wood grain is worn off. I'm just wondering is there a way to restore these or replace these? If so some info on places to repair / buy would be great help. Seeking some advises from AL experts
  9. Hi guys, In my Nissan TIIDA Latio (yom 2008 / 85k odo), I can see a small leak of coolant. Leaked coolant collecting on top of plastic (fan housing ? ) When i touch under the lid, It doesn't feel any coolant coming from there but can feel a little coolant-ish on the edge of the hose. This is my first car so seeking some advise from AL experts
  10. Hi Guys, Do anyone know a place to buy an original blank key for Nissan TIIDA 2008 (yom) ? As far as i know, the original key is not a transponder chip key. It looks like this
  11. Alright. It will be a great help if you can find me a guy to do this. I'll wait then. Thanks mate
  12. I'm near Weliweriya, Gampaha. But I'm ok to travel to Colombo to get this done. I guess replacing fuel pump just for this (if track is cracked) is waste because it will cost around 30k+ Done some search on the youtube and found this but he talks about replacing the regulator from the pump .
  13. Thanks Rumesh for the Great explanation. Btw do you happened to know somebody / place to do this kind of thing. Also to do this, do i have to go to the mechanic with an empty tank
  14. Thanks for the comment. Let's see others thoughts on this
  15. Actually I'm still having that sound and my car is a Nissan TIIDA 2008. I can join with your thread instead of opening separate thread for this problem Let's wait and see the ideas from AL experts
  16. Is the sound like some door opening creepy sound in horror movies. I'm having that kind of sound when slowly riding down a slope while applying breaks
  17. Hi guys, This is my first topic in AL. I recently bought my first car, a Nissan TIIDA Latio 2008 (yom). When i full tanked the car the gauge shows bit less than the F sign as marked below. I stepped out of the car an checked when filling because i wanted to make sure the guy in the shed wasn't too lazy to hold the pump. But he stopped filling when the tank gets overflowed. So right now I'm not sure the problem is with fuel gauge or something else Can someone please help me out?
