kdw
Everything posted by kdw
  1. Hi All, Could you please tell me, what is the recommended octane value for Mazda Axela (Sky Active, 2.0) Thanks in Advance
  2. Thank you very much davy. I will definitely change the mechanic. Is there any good place around colombo to get done this job? Thank you very much for your reply ajm. I will go to a new mechanic. Could you please suggest me a good place to get done this job?
  3. My Lancer CK2 (EFI, YOM:2000 ) recently failed the emission test due to high CO. Then i did an engine tuneup and again went for the emission test. This time i got very bad values than the 1st attempt. I went to the mechanic and then he asked me to replace my Oxygen sensor and TPS (throttle body sensor). Now i am getting very bad fuel consumption. Is this happen due to above sensors? If so, please let me know a place to buy them. Thanks in advance.
  4. Hi Noon, The place is "Kumara Motor Traders", Puttalam Road,Kurunegala. Contact numbers: 0772149206 / 0372056702
  5. Hi All, Does anybody know about the recommended power steering fluid for lancer Ck2 (2000 model)? I have read few forums and they have mentioned to use ATF. I used Mitsubishi SP III for my gearbox. Is it okay to use same for power steering? Really appreciate your responses. Thank you.
  6. Hi all, Thank you all for your valuable supports. I didn't replace the relay as still i didn't get the issue again. If i face the same issue i will go for your options. Thanks again
  7. Hi Dushyantha, Thank you very much for your reply. I don't have any idea whether he cleared the code or not.. He said that he cannot find the ECL relay and check this from another place if the issue occur again. No ther was any dock sound while the car moving. Sound came when changing gears manually. Hi Davy, Thank you very much for your reply. It is difficult to read the diagram as it is not clear. i will attach image to this. i think i have to go to a good place to check this. I checked the relay price from UM and Price is 6240/= LKR. And they will import the relay on customers order. Should i go to that place or can i find good parts from panchi...
  8. Hi, I have a Lancer CK2 (2000/ Automatic/ EFI) and it has done 183000Km. Last week suddenly i got a gear transmission issue after i traveled from Colombo to Kandy. When i change the gear to "D" , Gear was getting engaging with a DOCK sound and "N" light on the dashboard was started to blink. When i accelerate car was moving slowly. Then i went to a near garage and did a scan. Result was "54 ELC relay open" issue (Image has been attached). but that mechanic didn't have any idea to repair that, he checked the relays in engine compartment and he interchanged some relays and said he cant find the ELC relay. After few minutes i started my car and issue was not there.Then i came to Colombo and still i didn't get that issue. But i think i need to check that from a good mechanic. Is this a serious case? What should i do..? Is there any good mechanic around colombo ? Your responses are much appreciated.
  9. Hi... Were you able to find the Lancer ck2 owner manual.. I àm also looking for it and if you have found it could you please share with me...
  10. Hi All, Today i checked mounts in Panchikawatta Jayamanna Motors. They have brand new japan mounts and LKR 15350/= for all the four mounts(Including one gel mount) and they offer 6 month warranty. Is it okay to use these mounts? Did anybody use them. Highly appreciate your comments on this. Thanks.
  11. Hi CK2, Could you please share the price details that you spent on all 4 mounts? I checked the mounts in the shops around Delkanda junction. But i couldn't find any.. Thanks.
  12. Thank you all for your valuable opinions. Those are really helpful. @Dushyantha... I am also thinking about going for genuine.. but the problem is price Anyway mechanic said that it is not in critical situation since there are no any big damages in the mounts. But he said it would be good if you get it done early as possible since there is a small vibrations in the car when it is idle... @PerfMad Mechanic advised me to don't go for re-bush. He said that its quality is not enough to hold the CK2 engine as CK2 has a heavy engine. yeah.. thatz true.. 63 is a big amount for mounts..But i am thinking about go for the best low price one. @CK2 It's EFI... Mechanic also recommended recon... yes. i am agree with you.. have to check it carefully before buying. But i dont have good knowledge about vehicle parts .. I think i have to go with mechanic.... Otherwise i will spend money on useless thing... What i feel is , if recon mounts dont save for at least 1 year, i will b in a big trouble with money. Anyway thanks again for all the quick replies. 1st i will check for recon mounts. If i couldn't find good mounts , i have to go for brandnew
  13. Hi All, I have to replace engine and gear box mounts of my CK2 and i checked the price from UM. Their price is around 63000/= for all the 4 mounts. Is it okay to use recondition parts or should i go for brand new parts? is there any good place to buy recondition mounts? Please help me on this.. Thanks.
  14. Hi, Thanks for the reply. I showed it to a mechanic and he advised to change it. I got price details from the company and i will share details here for others reference. Timing Belt : Rs: 15346/= Razer : Rs: 7940/= Oil Seals : 1. Rs: 1804/= 2. Rs: 1138/= I didn't go to the company and i bought japan parts from kurunegala.. Timing Belt : 2950/= Razer : 1950/= Oil Seal : 330/=
  15. Hi All, I recently bought a lancer CK2 (YOM: 2000) and my friends advised me to change the timing belt. It has already done 181,000Km. I would much appreciate if anyone could tell me a rough estimation on the parts. Thanks. Kalpa.
