Ruchira88
Everything posted by Ruchira88
  1. Yes . Ayway my car has done 215Km so he asked me to replace to piston rings aswell .Even i thought the problem is with the rings and the head . Luckily head is good and no need to bore . So i was more than happy to replace the rings and head gasket
  2. hi mchg mechanic checked the engine and the problem was that my oil valve seal are worn out . and he asked me to replace the piston rings , bearings and the head gasket as well. Bought parts from toyota lanka . hopefully no more white smoke after this
  3. Hi mchg Going to do that after auwrudu
  4. Hi guys Can anyone give me a contact of a mechanic who does compression test around colombo . I live in moratuwa . And the cost for the service
  5. Hi rumesh i live in moratuws and i need to do a compression test . Where i should go Thanks
  6. Can you give a contact of a place which they do compression test . Hard to find a place . I live in moratuwa
  7. Yes . Car oil is burning and my mechanic said . It could be oil seals or piston rings or bore . But to verify he said he has to oen and inspect the engine
  8. Hi guys I need information about engine overhaul process of tercel 2e engine Mechanics who does this How much the cost Engine overhaul or engine replacement if so prices of an engine Appreciate your comments
