Nadee7
Everything posted by Nadee7
Dear All, I'm facing a small issue, when I'm turning the steering wheel after car is in fully hot I'm feeling a small tight in steering wheel. But the car is in cold that mean just after start in the morning there is no tight.What will be the issue ??
Rumesh, I met Ravi & show my issue.He checked & said that is normal thing in this type of OHC engines & he said that oil leaked coming due to bad oil seal in engine crank. So thanks again..
Ok noted . Thanks a lot.
I just open and see.There is nothing .
Yes definitely i know very well about that. Thanks a lot & ill go tomorrow & let you know about his opinion also. Appreciated about your valuable comment .
You know him??? ok I'll go there and show my issue. Do you think that he can resolve my issue??? Thanks
You know there is a famous Nissan expert near Bulugaha Junction. He is a A*W perso5and doing all nissans. Do I need to do the repair immediately??? pls help
give me a good idea. I want to know whether this is a issue or not.
Yes.I open Oil filler cap when engine running.
Oil is not burning actually becos im checking oil stick daily .Im daily running until 31st.So that's why i asked that repair is urgent or not.
No actually. Only after the cap removed.
Ok noted.But this is coming continuously.So do i need to do PCV immediately ???
After remove the oil cap only.Then oil spilling out from oil filler hole. What is PCV ?
I just remove the oil cap & then Oil spreading from engine to outside from oil cap hole.
Oil is very clear like when i check oil level from oil stick.
Dear All experts.. My car engine is Nissan QG15 .Mileage is 200,000KM Genuine.I just remove Oil cap & then only see there is a Oil coming from engine.But Oil level is not going down. I want to know is this normal ?? How can i easily check engine status?? Pls help. Thanks
Ok noted.Do you know good garage around Gampaha kadawatha ? Im in Gampaha
Pls I need more information.. Could you explain with more details? How much it will cost ? Is it serious repair?Do they remove gear box?
Yes I can check oil levels there are two oil sticks.Actually i want to know about this repair.Is it serious ?Do i want to go for a big garage?
Dear All Experts, I'm having a issue.My car is Nissan Sylphy FG10 2003.Mileage 200,000KM(Genuine) there is a small oil leak in between engine & gear box.I attached two images . But still engine oil & gear oil level is not reducing.I have been checking this since one month.What is this ? What is the solution for this? Is this serious? Do i need to do the repair immediately ?
Yes someone changed due to accident.But i checked H4 bulb is larger than IH01.So we cant fix H4 bulb to IH01 socket. Im @ office now ill upload some photos.
I'll upload.In that headlight housing mentioned in right side H4 & left side IH01. H4 bulb cant fix to IH01 socket .
No physically one bulb there. In that light frame they have printed bulb type. its H4 in right side & left side IH01
I recheck my bulb.Its H4 in right side & Ichikoh IH01 ,printed in bulb .
