The bird on water
  • Location
    Ratmalana
My Vehicle Details
  • Vehicle Make
    Suzuki
  • Vehicle Model
    Liana
The bird on water's Achievements
  1. As you all know the Japanese Domestic Model of the Prius comes with Japanese as both display and voice language. I was just wondering if it would be possible to change this to English. Does anyone know if this is possible? Cheers, Hansa
  2. Sylvi, Many thanks for the advice. I shall try this.
  3. Thanks but I don't think insulating tape can survive the high tempreature there. Are there similar products with high heat resistance?
  4. Hi, I've got a Suzuki Liana 1.6. Recently took the ignition coil assembly out to change the spark plugs and noticed that the rubbber bit surrounding the contact point between the plug and the ignition coil rod has broken in one unit. It is the wide bit right at the bottom; My questions are; Is there a specific name for this rubber bit? Can I buy this rubber bit only(without buying an ignition coil)? If I cannot buy this bit, trust that I can salvage one from a disposed ignition coil from a Liana or a Swift (engine model: M16A). Any thoughts on where I can find one? Thanks in advance for your support.
