misnad
Everything posted by misnad
  1. Damn, I thought the hybrid version was worse w.r.t pulling power compared to the petrol variant. Should do more research on this. W.r.t the Civic, doing a bit more digging into it before I make the leap. Got an offer for the City RS, but no way am I taking it. That BYD Seal is looking quite neat too BTW, guess what? A day after the compressor change, the AC gives up again, so it looks like it wasn't the compressor alone after all. Took the car to another AC place close to home (the one named after a Japanese flower) and they've ripped the whole dashboard apart to change the Evaporator coil (leaky). Also, apparently the condenser that was previously fitted in wasn't meant for this car (it had 30 rows of fins vs. the correct 45 rows)... however, there wasn't a leak there. I think if I just change the engine and CVT, I'll have a brand new car! 😖
  2. Yup, really glad I didn’t get the timing belt issue so far, but was advised to get it changed by 80k km given it’s a wet belt. Was thinking of switching to something else like the 1.5L version, but don’t see too many of those around on sale. The alternative is a newer Corolla, however it goes at like 19Mn recon, which is insane. In any case, I’ve decided to switch to something more reliable.
  3. Alrighty, how’s everyone’s Civic holding up? Been an expense-ridden few months here. So much so that I now have a completely new front-end (shocks, bushings, mounts and links), a new engine under-guard,…. and a brand new AC compressor (yup, just when everything was settling in, the shaft seal leaked again). Don’t even ask how much it cost me, but all in all, I must’ve spent close to 2Mn in repairs since last August. On a more positive note, I bought some Unity Performance smoked side markers (a lot of the others don’t seem to fit too well for some reason). Waiting for it to ship, but the pics do look great. Even brighter side is that I might be able to fetch max price for the car if I sell it… and boy am I tempted to sell it now. Or should I just continue using it for a while longer. I still like the car (it’s nearly brand new again!), but the issues have really done me in especially at just 52k km on the clock.
  4. Yup! Sneaky Honda eh? Also read elsewhere that you need to recalibrate thrice if you’ve changed tyres entirely to trigger an “reset” otherwise it uses the difference from the previous values and adjusts. No idea how that SW works, but it explains a lot of false positives and negatives.
  5. Hey, yup got a tune up done and didn't have an oil pressure warning or knocking sound since; it's very quiet now. As for the TPMS, it looks like the one on the Civic is a little weird or it may just be mine. I used to never get any alert on the TPMS during daily driving in traffic despite tyre pressures being quite off (I check my tyre pressure at the shed every month out of habit and could see the fluctuation). However, if I hit the highway or drive at faster speeds, it then tends to detect the pressure difference. In this case, however, it never popped up. What's worse is that after changing the 4 tyres, those folks pumped them up to 40-42psi. That caused a major rattle everywhere as the vehicle was so bumpy. Got that checked and reduced down to 32psi on all 4; much smoother since then. Not once did the TPMS go off though, oddly. I wonder if it only picks up these differences when driving at higher speeds for a while as opposed to stop-start traffic. EDIT: Found this thread that explains why the TPMS might be a bit weird on the 10th gen onwards: Getting the entire front-end dismantled tomorrow to check for any worn bushings and especially that weird intermittent metal scraping noise. Hoping for the best. BTW, do any of you know a good place that does plastic welding? I have a broken mounting hole on the lower lip of the front bumper and need that fixed; the entire lip itself is quite pricey and not worth replacing for just that damage.
  6. Changed the rear struts finally as it was extremely weak. But apart from that, there was a weird issue with the rear camber and as per the dealer, there have been a bunch of other CR-V's and Civics that came in with the same problem. They had to do some lathe work on the arms to get it sorted. Apart from that, there seems to also be a bit of play on the rack and it's most likely one of the bushings that's worn down. The front links also seem to be a little shaky, so that's due for a change. However, just when I thought I was getting things sorted out, ended up with a flat tyre that I didn't even notice and drove around with it unfortunately. Only realized once I landed the front right tyre over a metal manhole cover and it felt like an earthquake. Tyre had to be replaced, so I got 4 new Yokohamas... yes, another major expense there. Had to replace the rears anyway since the Continentals were nearly completely worn out (uneven wear due to previous suspension issues). The only issue though is that after that knock, there is a very slight intermittent squealing noise like those from the brake wear indicators on the affected wheel. It isn't the rim or anything either since that was swapped to the rear. Got the alignment re-done and there's no damage, but I guess something's off alignment at the rotor or pad level. Hoping it isn't the wheel bearings that have got some play since that's usually a pricey repair. The woes never end!!
  7. Ok so I had enough with the issues and took the car to C*r C****s. Glad I did since they found out the cause for my suspension woes. Apparently the inner CV boot and tie rod ends were messed up. They also said that the rack was gone, but didn’t really inspect the whole thing, so it needed to be checked separately. I also have some weak rear shocks as the car once hoisted had its rear wheels move into the shocks even with a little push (shouldn’t be the case). This means that the car can’t even take its own body weight and hence needs those 2 replaced. Also found out that the rear wheel alignment that the dealer did last year caused a misaligned rotation marker, so it’s difficult for anyone to figure out the exact angle now just by looking at it. Needed a few more things done too, like an engine tune up as it was noisy on idle (guessing carbon build up thanks to the crappy 0w20 Performax oil they used). Will swap out for a good 5w30 next service. Took the report to the dealer as I wanted to show them what they kept shrugging off for the past several years. They were so defensive at first and when I forced them to check it out, they admitted the tie rods were worn as there was considerable play. When asked if they checked it this way before, they said they didn’t since the test drive down their “boralu paara” was fine. They also tried to say that just because there are oil stains on the CV boot doesn’t mean that grease is leaking; asked them to change it anyway since it’s most likely cracked. They did say that the rack ends were ok though, but I’m going to get that specifically checked elsewhere. Rear shocks will be replaced later from outside as I can’t be dishing out 98k per strut at the dealer. Anyway, the ride is super smooth now on the front end. Just like the good old days when I purchased it. A few more fixes and it’ll be as good as new!
  8. December update! Yes, I still have the Civic. Just had a check engine light come up on the way back home from Nuwara Eliya and ended up replacing the O2 sensor as it was faulty; cleanup with brake cleaner wouldn't solve it. Apart from that, I seem to have a weird knocking sound from the engine after my last service just 2 weeks back. They used 0w20 Motul 8000 Performax, which I saw was specific to India (it isn't listed anywhere on the global site nor are the specifications available), but it was ACEA C5 rather than A5. Not sure if that is causing a problem since I also got a low oil pressure warning light a few days back in Colombo, but it went off within like 30 seconds and didn't reappear. Oil level seems fine. I wonder if it's the C5 oil with lower HTHS compared to the A5 ones. Also, it's a little weird since after the oil leak fix back in Aug / Sep, my maintenance minder indicated a service due in December; this was within just like 3k km or so. Need to get this thing checked and also replace my engine under-guard since that was damaged as well; thanks to the wonderful holes and roads we have. By the way, I just checked my VIN on the Honda UK site and there’s a recall notice around the fuel pump. Apparently there’s a defect in the impeller that causes fuel to leak out, resulting in a fuel odor once parked. It apparently fails and the vehicle either stalls or refuses to start. I don’t think the recall is offered by the dealer here though. Might want to check your VIN and see too.
  9. Chipped edges? Damn that’s quite a coincidence as my Honda (Akebono manufactured) ones were wearing off so quickly. The last pair I changed had chips all along the edges.. not small ones, but like chunks.
  10. Please go with aftermarket ones. I’ll be doing the same when it’s time for my replacement again. Look for the brand called “Akebono” as they are the OEM manufacturer for Honda brake pads.
  11. Done! I now have my baby back with a fully functioning side mirror. Insurance inspected it and asked them to find a lens and bracket, which they finally did. So they didn’t need to replace the full mirror assembly, thank heavens. I have a feeling it might even be my own stolen mirror they bought back. Btw M*g C**y has a 3D wheel alignment device too that caught my eye; didn’t see it at the agent though and it looks like they’re using the older laser guidance method. Got them to inspect my shocks and it looks like mine are wearing out fast for some reason. Going to visit Lanka S***k A******r in Moratuwa to get that checked out/ refurbished if needed.
  12. The compressor isn’t inside the dashboard and doesn’t need it removed. It’s only the evaporator that’s around that area just inside the firewall. I got my compressor repaired by a known technician and that saved me a very expensive replacement. Switched it to R134a entirely and it’s running fine. Only had a leaky condenser after that. More than the compressor, it sounds like there’s a leak somewhere along the lines that’s causing the refrigerant to empty out. It’s pretty nasty if you’re smelling it in the cabin and I suggest you get it fixed ASAP. Still, they’ll need to use a dye to figure out where the leak is occurring. If it’s beyond the firewall and near the engine bay, you’re lucky as that can be done up without removing the dashboard. Shall message you my contact. If it requires a dashboard removal though, I suggest going to the agent.
  13. Got the insurance claim shifted to Mag C#ty Nugegoda as they have the parts. Estimate is roughly 100k and he too said the entire assembly should be changed, but they’ll see if the rubber bushes are available in stock too so they can just fix the lens. Awaiting insurance approval now. Let’s see how this goes.
  14. Bad luck; they said I need to change the whole assembly and it’s not in stock. Back orders are 3 months so will have to use a temporary dud lens till then. Cost of replacement is 328k.
  15. Not sure. The car was as it was when I got there and anyway I couldn’t hear the alarm as I was in the hospital. Mirrors were folded so it looks like he had sneakily taken it without opening it up.
  16. Same thing happened to me. Looks like the whole lens movement assembly was taken too. Just outside the General Hospital near the Cardiac section. Insurance assessor said it’ll be 40k, but I guess it’s going to be more. Blind-spot and heated mirror on the Civic Tech Pack. Some ppl will never change in this country.
  17. My neighbor’s cat happens to sleep on the roof of my car. Paw prints everywhere and an occasional pee stain, however it looks like it has made friends with the rat; they’re bunk buddies! Either that or the rat chased the cat away!
  18. Ok folks, I was driving around at night and got an oil level warning; found that it was right at the lower marker on the dipstick. Also saw some oil spots in the garage.. I hardly see the floor there as the car is always parked on it. What’s worse is that I saw traces of a rat defiling my engine bay once I popped the hood. It had left a lot of droppings and some ball-shaped (pretty big ones!) stuff… guessing it was the rat’s protein balls to keep itself buff. So I eventually decided to get the oil leak fixed at the agent and let them deal with the cleanup job. Didn’t want anyone else playing with the engine and gearbox. They’ve also flushed out all the oil and cleaned out the turbo lines. New seals and tappet cover were fixed too. Wheel alignment was included as well. All inclusive charge was 155k including 0w20 oil. Not too bad. The car drives nicely especially after the realignment. Hope that’s the end of the oil worries now. As for Mr. Ratty, I need to get some repellent spray. Used to get it off Gr***e M****y before, but they’re now an online scam portal so that’s out. Know a place that stocks this stuff?
  19. If it’s a hiss that goes off quickly, that’s fine for now. May need a charge later though. But also if your spec says r1234yf, it’s best to find out from the previous owner whether it was converted to r134a. Do not mix refrigerant. On oils: The agent can frankly shove their semi synthetic oils up their exhaust pipes! 😀 Follow the book and maintenance minder always.
  20. Congrats on your purchase! I’d recommend checking the oil next time and see if it is of the right standard expected of your car. For example, mine recommends 5w30 ACEA A5, so I use Castrol Edge Professional A5 (gold can) now. Take care of the fluids and you’ll have a great ride overall. For your AC, does it make any hissing noises inside the cabin? If not, that’s just fine and leave it as is. You’ll need to be cautious about the type of refrigerant in use. Mine uses r1234yf and got messed up when the agent decided to mix it with r134a. Eventually had to change the condenser due to a leak, completely flush it and convert to r134a. R1234yf is super expensive! Last thing is your wheel alignment. Just get that checked once and you’re golden. Other than that, just keep the car clean and it’ll serve you well. Oh and just get the 12v battery tested too in case that needs replacing, but I’m sure your service report would’ve checked that too. All the best with the new drive! You’re sure to enjoy it.
  21. True. Just got the car back and they at least listened to me this time with the brake fluid bleed. The pedal feels more responsive now, however the brake hold issue still exists; it keeps trying to slip forwards. I use brake hold quite a bit in traffic towards office as it saves my foot from cramping up (Dematagoda tends to be chaotic!). Apparently the ABS module is starting to malfunction, however not to the level where the warning light comes on. They said there were a few other cars that had the same issue and one had a complete ABS failure that caused the car to skid sideways when braking on the highway. Was asked to watch for uneven discoloration on the front discs since that would indicate the situation worsening. In any case, if that needs changing, I’m going to do it outside with a recon part. I do not intend to crash into god’s breakfast table past the pearly gates of heaven yet!
  22. Brakes, brakes and brakes. Ok so upon further inspection (and under my dictatorial approach this time!), it looks like the agent has come across 3 similar incidents with the Civic hatch, i.e. Brake-hold slipping on flat surfaces and the pedal slowly sinking to the floor after the initial stop. They’re draining the brake fluid finally, but said that it could either fix the issue or make it worse, which means it’ll require an ABS unit replacement, for which they do not have parts in stock. Wish me luck!
  23. Nope. I specifically asked to check the MBS and just drain the fluid + replace entirely even if there isn’t any air bubble, etc. cos that’s how annoying the issue is. The Hub did something and made it a little better, but the pedal still sinks after the initial push and resistance.. not too easily though. Both places have something in common: they tend to think they know it all. Like Matroska said, the dealer is on the side of “it’s all ok baby!” and the other one will give you a full load of details, but ignore your request for specific checks.. cos they’re detailed like that 😏. Found another called Nitr*Z**e. Here’s hoping they don’t decide to throw my car into a vat of liquid nitrogen.
  24. Honestly, I just love this car, however there is unfortunately less than a handful of people who can repair / maintain it well. The agent IMO is utter rubbish and talks big while making you feel like you need to worship them for any attention. With all these recent issues, I was actually contemplating fixing them up and switching to a Premio (I would never sell my car with all these unattended) purely because the level of support from that dealer is unmatched. Giving it one more shot at another place I found recently (the Hub also just did nothing to fix the brake issue and just “reset” the ABS sensors, whatever that means). The brakes are a bit better, but the pedal still can be pushed to the floor after the car comes to a stop, which means there is most likely an issue with the Master Brake Cylinder or water/air in the brake lines. BTW all this is on a factory brand new car I purchased and imported so it is disappointing. I still love the ride though.
  25. So I got a courtesy call from the agent’s customer relations manager today after my online feedback to their survey from the last job. She was all “oh sir I hope your car is working well now after the job”. I mean if there’s a way to make a situ worse, she checked the boxes. So I had to politely say no after which she gaslit me by asking why I didn’t bring the vehicle back to them immediately. Yup, told her I didn’t want to hear more of the, “it’s normal with these new cars. Long live the old!” that I experienced even after taking it on a test ride. She was like, “oh ok sir we look forward to welcoming you again for your next service!”. I’m lost for words.
