Kcho
Everything posted by Kcho
  1. Hi Tiv, Thanks for the reply. Both ATF and CLutch oil needs swap? Regards
  2. Can anyone share a good manual for the maintenance including changing clutch oil.
  3. Hello All, While reviewing some threads here, I've experiencing nearly the same issue for my Honda Vezel. My post: Please advise accordingly.
  4. I'm unaware if the agent changed the Clutch oil. You mean changing the clutch oil can solve the issue.
  5. Hello Tiv, Thanks for your reply. Please see other photos I could take at the Garage. The machine is at 51,000 KM run. I've not changed ATF fluid yet. Do you think the issue is with that? There's the engine - Clutch - Gearbox. The drain as I called it, is a small hole, this is where the oil is coming. My mechanic told me the small hole is like that on Vezel he serviced and he told me its a drainage feature. But the mechanic is unaware of the Vezel dual clutch technology. Grateful if someone can help me on same please.
  6. Hello All, I own a Hondal Vezel 2015 Hybrid System. During servicing this week, my mechanic told me about an oil leak on the clutch drain. Please see attached photo. Grateful if someone can help me to understand the following: 1. The drain is in-built in the clutch, is it normal that oil leaks through that drain? 2. Is the Clutch faulty? 3. Why does Honda included a drain on the Clutch? Awaiting your comments and replies. Thanks.
