upaliamah
  • Location
    HOMAGAMA
My Vehicle Details
  • Vehicle Make
    Toyota axio wxb 2017
  • Vehicle Model
    axio wxb 2017
  • Future Plans
    toyota double cab
1,627 profile views
upaliamah's Achievements
  1. Did you change map reading lamps to LED ? if not check wire harness for Rat/mice attacks. because this was happened to me after replacing map reading lamp to led.after change to original bulb problem solved.
  2. Clean the windscreen,specially camera area.
  3. AQUA 2013) I have done 14882 Km,782 Lts,of 95 pumped,(details recorded fuel buddy app) my Journey is Meegoda to Borella in heavy traffic (malabe Battaramulla) about 19km/l
  4. https://www.google.lk/maps/dir/Kaduwela/Pasikuda,+Kalkudah,+Eastern+Province/@7.7333861,80.9606617,10.75z/data=!4m13!4m12!1m5!1m1!1s0x3ae256f2fd041817:0xc3964cf05a9089a4!2m2!1d79.9842178!2d6.9308305!1m5!1m1!1s0x3afad903403b27d9:0xceee87334703322b!2m2!1d81.565127!2d7.922823?hl=en
  5. PREMIO
  6. :laughing-smiley-002:
  7. Dissolve camphour balls (kapuru) in Kerozene oil and spray into tires and inside of mudguards.also can use pepper powder (gammiris kudu) in engine bay.I am using this method for about two months back as rat entered to my aqua and damaged cabin air filter. If you using baits to catch rats do not touch the bait from your fingers.keep open the engine bay and switch on light in garage in night time.
  8. Connector was 4 wire bundle (red,blue,yellow,black with yellow stripes) Thanks for the link JADEYBlLITSON one sensor there as you mentioned sorry for my neglegance.I will check it.but its not easy to reach that place as I have to remove the front bumper I will check it on next sunday. I have removed all the fuses in fuse boxes (one by one)and cleaned with contact cleaner (CN20) both fuse and every contacts in fuse boxes.After that I have done more than 700Km within 3 days but problem (auto reset and display on automatically) not came so far.
  9. I think it's better if you start by figuring our what's wrong with temperature sensor. It's behind the front bumper at the bottom right corner of the condensor. If its not there locate the two wires that connect to it that come from under the front headlight. Make sure it's not touching anything. If its faulty replace it. It's not that expensive and might be cheaper brand new. Missing temp sensor could mean the car was in an accident and this area was damaged. This is one of the overlooked parts when repairing cars. Anyway lets not assume the worst and see what we can do for the time being thanks for the reply. I have checked the place you have mentioned.I could not found two wire connector or sensor there,but I found 4 wire connector under the left head light without connectiing any device.
  10. thanks iRage and Ramishkad i have checked 12v battery terminals its ok. When I first time serviced the car T/L given a diagnostic report.according to that they said DTC code cleared by previously.not from T/L may be in japan as report says car has done 729 km after reset the code.
  11. Hello Dear freinds My aqua 2013 having strange problem. when I off the engine it offs.but somtimes its automatically on the display again after few seconds.but not the ready mode.in this occacion can off the display by pressing start button.if I press start button with brake pedal it goes to ready mode.but ac temperature display goes to 25C,clock 1.00,avarage fuel consumption 0.00,average speed 0.00km/h only trip counters remaining previous values. When the service(done by Toyota lanka) I have got vehicle diagnostic report.according to the report DTC B1412 recorded and cleared previously.also its not display outside temperature from the day i brought the vehicle. please share your comments.is this normal or having a problem with car ? this happened three or four times only.can I ignore the thing or have to show vehicle to technical knowledgeble person ? Thanks in advance
  12. Fixing reverse sensors is not a rocket science.You only need a drill machine mesuring tape and insulating tape.All the instructions and hole puncture included with package.
  13. some interesting link regds. chinese made vehicles http://chinaautoweb....foreign-brands/
  14. upaliamah
    Obdii Compliance
    any one using this gadget ? i saw some one advertised this on wow.lk http://www.scangauge.com/products/scangauge please comment
  15. check this link also http://www.hafeiauto.com.cn/en/
