Everything posted by upaliamah
Pre collision system warning malfunction
upaliamah replied to Malaka@123's topic in General Automotive
Did you change map reading lamps to LED ? if not check wire harness for Rat/mice attacks. because this was happened to me after replacing map reading lamp to led.after change to original bulb problem solved. -
Clean the windscreen,specially camera area.
AQUA 2013) I have done 14882 Km,782 Lts,of 95 pumped,(details recorded fuel buddy app) my Journey is Meegoda to Borella in heavy traffic (malabe Battaramulla) about 19km/l
https://www.google.lk/maps/dir/Kaduwela/Pasikuda,+Kalkudah,+Eastern+Province/@7.7333861,80.9606617,10.75z/data=!4m13!4m12!1m5!1m1!1s0x3ae256f2fd041817:0xc3964cf05a9089a4!2m2!1d79.9842178!2d6.9308305!1m5!1m1!1s0x3afad903403b27d9:0xceee87334703322b!2m2!1d81.565127!2d7.922823?hl=en
PREMIO
:laughing-smiley-002:
Dissolve camphour balls (kapuru) in Kerozene oil and spray into tires and inside of mudguards.also can use pepper powder (gammiris kudu) in engine bay.I am using this method for about two months back as rat entered to my aqua and damaged cabin air filter. If you using baits to catch rats do not touch the bait from your fingers.keep open the engine bay and switch on light in garage in night time.
Connector was 4 wire bundle (red,blue,yellow,black with yellow stripes) Thanks for the link JADEYBlLITSON one sensor there as you mentioned sorry for my neglegance.I will check it.but its not easy to reach that place as I have to remove the front bumper I will check it on next sunday. I have removed all the fuses in fuse boxes (one by one)and cleaned with contact cleaner (CN20) both fuse and every contacts in fuse boxes.After that I have done more than 700Km within 3 days but problem (auto reset and display on automatically) not came so far.
I think it's better if you start by figuring our what's wrong with temperature sensor. It's behind the front bumper at the bottom right corner of the condensor. If its not there locate the two wires that connect to it that come from under the front headlight. Make sure it's not touching anything. If its faulty replace it. It's not that expensive and might be cheaper brand new. Missing temp sensor could mean the car was in an accident and this area was damaged. This is one of the overlooked parts when repairing cars. Anyway lets not assume the worst and see what we can do for the time being thanks for the reply. I have checked the place you have mentioned.I could not found two wire connector or sensor there,but I found 4 wire connector under the left head light without connectiing any device.
thanks iRage and Ramishkad i have checked 12v battery terminals its ok. When I first time serviced the car T/L given a diagnostic report.according to that they said DTC code cleared by previously.not from T/L may be in japan as report says car has done 729 km after reset the code.
Hello Dear freinds My aqua 2013 having strange problem. when I off the engine it offs.but somtimes its automatically on the display again after few seconds.but not the ready mode.in this occacion can off the display by pressing start button.if I press start button with brake pedal it goes to ready mode.but ac temperature display goes to 25C,clock 1.00,avarage fuel consumption 0.00,average speed 0.00km/h only trip counters remaining previous values. When the service(done by Toyota lanka) I have got vehicle diagnostic report.according to the report DTC B1412 recorded and cleared previously.also its not display outside temperature from the day i brought the vehicle. please share your comments.is this normal or having a problem with car ? this happened three or four times only.can I ignore the thing or have to show vehicle to technical knowledgeble person ? Thanks in advance
Fixing reverse sensors is not a rocket science.You only need a drill machine mesuring tape and insulating tape.All the instructions and hole puncture included with package.
some interesting link regds. chinese made vehicles http://chinaautoweb....foreign-brands/
any one using this gadget ? i saw some one advertised this on wow.lk http://www.scangauge.com/products/scangauge please comment
check this link also http://www.hafeiauto.com.cn/en/
get well soon Mr.sylvi
one person reported dead after a lorry toppled on e 01 @ kahathuduwa adaaderana.lk
check this link also.but you have entered CSE at wrong time http://forum.srilankaequity.com/forum
The Oxygen Sensor detects the amount of oxygen in the exhaust gas and sends a signal to the ECU which adjusts the air fuel mixture to the optimal level. Too much oxygen in the exhaust gas indicates a lean mixture, which can cause performance problems, including misfires. Too little oxygen indicates a rich mixture, which wastes fuel and results in excess exhaust emissions. When does an Oxygen Sensor need to be replaced? Exposure to carbon, soot, harmful gases, thermal and physical shock will shorten the life of an Oxygen Sensor. This results in increased fuel consumption, poor engine performance and excessive exhaust emissions. Oxygen Sensors with 1 or 2 wires typically have a service life of 50,000kms. While 3 and 4 wire sensors have a service life of approximately 100,000kms.
varunatech thank you for your kind reply
I have gone E01 twice with two cars one micro trend petrol consumption was 16Km/l max speed i have done 130 km rpm 3500 another one corolla 121 max speed 140 rpm 2500.petrol consumption 15Km/l ,Both average speed was 115km/h,but i have noticed engine rpm high in micro trend (1075cc)is this ok or any thing wrong with trend rpm. need advice please
80Km/h lancer (1979 model) 110 Km/h datsun 720 (1981 model) 114 Km/h Bajaj pulsar (2009 model) 120 Km/h Micro trend (2010 model)
I think Nissan Datsun 720 D/cab good it does 15Km/L diesel (sd22)& pretty decent lookhttp://forum.autolanka.com/public/style_emoticons/default/rolleyes.gif
