24
Everything posted by miniace
Dear Sylvi this is ordinary regenerative braking right? Glad to hear Mazda joins the regenerative club following Toyota, Honda, Merc Peugeot and Chevy to name a few. MINIACE
Welcome to AL. Which area you from mate? If your clutch is playing funny do attend soon before you ruin the flywheel.Flywheel jobs are really expensive. There are many good and reputed garages. Tinkering is a simple job.Tell us where you from and surely many members will come for your rescue. MINIACE
Oh how did I miss this topic, Running engine with loads such as AC and maybe alternator loads on idle power will not damage the engine instantly but has a definite bad effect and will reduce the life of the engine and its components including AC. If a petrol engine due to low running, spark plugs will very bad effects when running idle for prolong periods. (Will explain this in detail if required).Resulting loss of power,incorrect sparks and reduction of life. If a diesel engine the effect on inj nozzles are seriously greater.Since the oil pump rotation is restricted on idle power oil circulation and lubrication will be less resulting bad effects on bearings. Mind you all this happens on heavy loads and obviously temp goes up and secondary effects on lubrication. If vehicle is equipped with an electric cooling fan the effect on temp is relatively less.There are bad effects on AC system as well.All ACs are designed to run with 50-60% ram air and when stationary the ram air support is zero and will ruin the system soon plus again the overall cooling will effect including the AC effects... Running idle for a long period on multiple occasions is definately bad but once when you in a serious situ with GF is fine..but dont make it a habit MINIACE
Further to this, If you are caught violating its a spot fine.If Cops failed to track you and had you with penalty sheets, situation is turning into a court case at the nearest intersection courts. MINIACE
12T is standard for D56 and M40 engines with three bolt attachment if im not mistaken.AFAIK TD04-11G is not sufficient and not sure thats 3 bolts or 4. There is a garret turbo comes for Nissan VX models and thats a straight fit and ideal if you opt for a replacement. Im going to give you a warning..by any chance if the turbo gives up suddenly and oil drains into the combustion sector, your engine will start running high reves even if you attempt to shut the engine.Simply fuel is replaced by oil and engine will start running on oil.There is no way you can shut the engine unless you select 3rd or 4th gear and go emergency brakes with normal barakes and release the clutch to kill the engine.Be prepared for that mate...Just a warning. Will get you a good turbo guy. my advise is go for a complete replacement than a repair job. MINIACE
- 19 replies
- 1
- Mitsubishi
- Pajero
(and 2 more)
Mate are you in a position to DIY check where the leak is from. Is it from Turbine seal or compressor seal or both. sometime when the oil lines are blocked or oil filter is clogged,the bypass valve opens and oil spill everywhere. Even obstructed turbo oil drain lines and engine crank case vents can cause oil leaks. Act fast before its too late.Good luck mate! MINIACE
- 19 replies
- Mitsubishi
- Pajero
(and 2 more)
For accidents yes, driver got to pay for the damages.This was clearly announced. But i need to know the situation if Patrol services and mobile assistance are obtained. MINIACE
The method now is they radio all cops manning near exit toll centers and alert.On exit traffic cop there hands over penalty sheets.If failed they post 'Summons' to owner of the vehicle. MINIACE
Need Some Opinons On How To Get To Katharagama....
miniace replied to Shock's topic in General Automotive
Practically it takes more than 2 hrs for Galle- Kataragama leg dude. MINIACE -
Which Is The Nicest Area To Go For A Drive In Colombo??
miniace replied to MoneyMaker's topic in General Automotive
Oh yes thats fun....Just imagine doing the same in a Mini on a Sunday...surely you will sing "I feel good" MINIACE -
In other words...marketing and promoting in a decent way MINIACE
Little question, do we have to pay for mobile breakdown services or Highway patrol assistance when services are used? MINIACE
Raikkonen To Return To Formula 1 With Renault
miniace replied to pug306xsi's topic in International Events
Dude this is already discussed. Sad you didnt check the active F1 topic here http://forum.autolanka.com/index.php?/topic/10235-formula-1-2011/page__st__100 MINIACE -
Heard thats ready for a nuke warfare too But didnt see the famous umbrella. MINIACE
Kubica's 2012 F1 return is not really confirmed. http://www.autosport.com/news/report.php/id/96418 MINIACE
shame shame MINIACE
Hey where is 'Toyotasucks' dude..awaiting his comments MINIACE
Post your downloaded link here, Honda experts will tell you about model changes if any. MINIACE
MINIACE
Yes FT-86 and Subaru BRZ STi is a joint Toyota and Subaru project.Car will be in market as Subaru Scion and Toyota. MINIACE
More to come...so better keep all your awards ready... Highways are new to SL..People are still learning how to use and how to drive...Accidents do happen..cant help. MINIACE
Well only upto Pinnaduwa- Galle not Matara. MINIACE -
Help Regarding Revenue License Issue... I Have Only 5 Days :(
miniace replied to venomafiax's topic in General Automotive
Yep...Just to clear all your doubts..verify with the three wheeler guys near the gate MINIACE- 30 replies
- 1
- Kurunegala
- motor traffic
(and 1 more)
Mini once..Mini twice....Mini thrice MINIACE
