Twin Turbo
    51
  1. HI, the number before the W stands for Winter,. as there is no winter in SL, Don't worry. What's your tire size?
  2. HI, the number before the W stands for Winter,. as there is no winter in SL, Don't worry. What's your tyre size?
  3. And just how're you going to pass emissions cert? most owners have enough fun with original engines,.. Most petrol engine jungle is cleared and binned for the new arrival.
  4. USED V46?
  5. Ever bothered to check the accuracy of your fav fuel station?
  6. HI, and welcome to AL, A complex sub of engine lubrication,..what ever grade you use, don't reduce the oil 's viscosity.
  7. Warning : Bubble burster !! This is a pre defender , series3 88 inch,..with some defender bits. Ask the seller from Honest Edd's where the front wipers have gone on holiday to?? The DEF90 had coil springs all round. The Defender was on the drawing board in1980 !
  8. The new engine needs a little millage to loosen up.
  9. First, take the car to a specialist/agent. it's fuel injection system is different from the standard model. -TT.
  10. Regular 92 will do,..you do not stand to gain anything other than loose money over pumping fuel not specified for your car by the manufacturer. Save your money and enjoy the drive,.. TT.
  11. It will be like inventing the wheel,. backwards.
  12. Service stations frequently do this,.. as there will be more head aches for them if they filled less,..?
  13. Repair/replace the engine - keep it diesel,.
  14. HI, Welcome to AL. 1. Can be done.you'll need the wiring and Be sure to change cooling system components. keep in mind that your doner engine is rear wheel drive and considerably different from what powers the RZ-1 which is front wheel drive. 2. The RMV must be informed of the engine change and the number updated in the reg document. Suggest a B13. engine
  15. Tata Nano manual,..
  16. We don't know if the work was done professionally at a work shop or by a road side garage geese monkey under a jack tree. the tolerances will therefor depend on the quality of the mercenary used in the overhaul.
  17. Clean and re pressurize the injectors?
  18. Possible cracked/warped head ?
  19. Manufacturing year? The 2C engine has a timing belt. check it's sticker on the timing cover and any replacement history on it,.. you should be more concerned on the current condition of the entire car when purchasing as it will affect the future running and reliability,..
  20. Check the engine no with the Reg doc. Can you up load some pics of this supposed virgin engine? Ok, if the engine is original and not re-buil;t, it's now due for a major tear-down ! ? TT.
  21. Hi and welcome to AL,.. The check engine light comes to do the same,..change the air filter, check the ecu with a scanner,. Clear the fault codes and do the required maintenance,.. Cheers, TT.
  22. May be a previous owner replaced the engine with a reco unit?
  23. The 325 number series was given to re-registered vehicles by the RMV for civilian use Eg; Diesel conversion,.. or Ex DPL and Ex Armed force no's TT.
