kush
Everything posted by kush
  1. Fuel consumption will be around 9-10 Colombo hevy traffic. 12-15 outstation. Even the basic comes with intelegent key, climate control. Higher grade will have winker mirror, alloy wheels, front fog lights and audio controls in the steering wheel which will add value to the car and in my openion is worth 100-150k. Most of the Navi/DVD finctions are useless in SL you are better off fixing an after market good unit
  2. Swift has better performance, handling, smoother engine (dual VVTi) 4 insted of 3 cylinders, climate control A/C, Vitz will be more expensive to buy but will have better resale value as it is a TOYOTA
  3. If you happen to have a user manual just go by it. Both Mobil and Caltex recommends 5W-30 @ 12 months/15000 km intervals. for the 1.8 model Mobil 1 ESP formula (Fully synthetic) Castrol EDGE (Fully synthetic) Castrol Magnatec (Semi Synthetic) Even Toyota USA site recommends 0W-20 Toyota synthetic for 2010-2011 models very 10,000 miles (I dont think T****A L***A has this) Your fuel saving could be put to good use by going for synthetic I suppose.
  4. It is no worse than any other JDM of similar size, main issue is the wind deflector below the front bumper which gets scraped easily. Fortunately this is not visible unless you peek under the bumper. Due to the short wheel base and the overhands this will not be much of an issue in day to day running. Best way to increase the height would be to replace the coils and shocks from Indian version which has little more ground clearance. However you will ruin the ride comfort. If you want high ground clearance go for a small SUV
  5. Wow both the used cars have done magic 60K (i hope the Allion figure you have given is a typo mistake) If the condition is alright I would go for the Allion even paying 200-300k more as it is a class over the Axio.
  6. How about Corolla 141, you could get a excellent company maintained 2007/2008 for around 3.5 M. Fuel will be 8-9 Colombo 12-15 Outstation (personal experiance) a bit light footer might be able to get bit more. There are cars which have done around 30-50K, however most of them are with the car dealers so you have to be careful about the history. If you can find one still with the fist owner with full service history this is nice A-B ride. Upto date I have not reard of any reliability issues with 141, and I konow of few which has clocked over 100k (correct me if I'm wrong) 121 and the Allion 240 are excellent cars however they are aging around 8 years and that is the time generally they start giving trouble. (Electric/ Suspension/ Transmission/ Cooling) besides you will not know the milage it could be 60K, 160K, 260K, 360K cause they were very popular rent a car models.
  7. 318i is a 4 cylinder where as 320i and 325i are 6 cylinder units. They were the best of engines at that time and had very good reviews. 320i would be the best without much compromise on fuel bills, if can find 325i would be a real treat. However only very few were imported to SL.
  8. I don’t think it is anything to do with fuel, there are many Vitz 1.0 running on 90 octane without issues. Since you have no unusual issues when the car is running I don’t think it is injectors of clogged fuel filter, my gut feeling is it is fuel delivery issue/ weak pressure during startup. New cars have fuel pumps located inside the tank, once you on the ignition it start pumping fuel to the injection system which usually takes couple of seconds if the car was not running for few hours due to the fuel returning back to the tank. If you listen carefully you might hear the sound of the pump working for few seconds building fuel pressure in the system. Just wait for 5 – 6 seconds with the ignition on before starting the engine and see if the problem solves. If not better take the car to an expert who had diagnostic facilities and get the car checked, believe me it will be the cheaper option. Good luck
  9. My previous car Lancer EX 1.5 (A) came with recommended 95 Octane, however according to the user manual if not available could be run on lower octane and according to the manual a small drop in power / economy. I switched from 95 to 90 when CPC decided to increase the price difference to Rs. 18 from Rs. 5 and did not observe any significant power loss and no change in economy apart from the saving of Rs. 900 on each fill up. Same form with my current ride Swift 1.240 (CVT) even with an 11:1 compression ratio. My advice if your car doesn’t need it save the cash.
  10. These cars are not economical as the size suggest both will do around 9-10 Colombo, 12-15 Outstation. Info from family and friends who has them. My personal car is a 2007 Swift 1240 CC CVT does around the same. But I hev been told that the Indian versions are better, may be due to the manual gear shift.
  11. Check the ads here, sunday papers you should be able to get a good idea. Cars available here are made in Japan / India All Indians are manual and has a diffrent engine
  12. 1) & 2) M13A 1.3 L (1,328 cc); bore is 78.0 mm and stroke is 69.5 mm. 68 kW (91.2 hp) @5,800 rpm, 116 N·m (86 lb·ft) @4,200 rpm M15A 1.5 L (1,490 cc); bore is 78.0 mm and stroke is 78.0 mm. 74.5 kW (99.9 hp) at 5,900 rpm and 133 N·m (98 lb·ft) at 4,100 rpm. 3) Since you are considering a 2004 it will anyway be a second hand with the initial depriciation taken care of, finding a manual will be like looking for a needle in hay stack as most of the Japs came with Auto, selling a auto will be equally difficult. Howver manual will be a treat to drive and most problably better of fuel.
  13. My wife had one which she used for about 4 years. 2000 model 1.0 auto CVT. Used to do around 10-11 in Colombo and 13-15 in long drives. Only issue was the electric power steering which was replaced. Now i think the car is little dated (over 10 years) so you might have rust, electrical issues. Most of the cars would have covered over 100k and pesonally you might be better off with a newer car like a Viva/ Alto which might be only couple of 100k brand new against a 10 year old used car. If you still want the March then check the steering, front suspension, CVT gear box (if equiped), rust (they start around the engine compartment near suspension assembly)
  14. kush replied to mensoft's topic in General
    Oil pressure guage would be usefull too
  15. Please keep us posted on the outcome
  16. Strange problem, they might have damaged brake lines / ABS wireing when drilling holes for fixing the seats. This could cause the computers to shut down the systems for safty. First go underneath the vehicle and do a visual check, better get it checked by agents / expert.
  17. 1.To my knowledge Pistons, valves, gasket and the injector pump are diffrent from the stock 2C. 2.There will be a increase in power even with the stock engine, however you will wear out the engine fast. 3.Yes, it will not be a proper conversion you will gain more engine power however gearing and breaks might not be able to handle the extra power. 4.you will need extra cooling as the engine will now generate more heat. 5.Depends on the driving conditions if you are a hard footer you might even see a improvement. 6.Not really when you consider the down sides. Unless you go for the full conversion ie. engine, transmission, electronics, cooloing. (expensive)
  18. Good point, forums can be very useful to share info/ ideas. It is sad to see that it is being used to ridicule others so much so the purpose is lost. After all majority of the population are not petrol heads
  19. Your modifications must have improved your fuel consumption cos my same car with stock specs does only 10 km/l in Colombo. I have verified the AVG readings and they are pretty accurate +/- 5% Have they removed your Cat when fixing the beat silencer, that would improve power/ fuel consumption
  20. Will be difficult to find outside. Try U****d M****s they might be cheaper than you think. Best is to get it down from Singapore/Malayasia/Thailand
  21. kush replied to Zambo's topic in General Automotive
    There are few Nissan Z,Skyline, Toyota MR2, MRS, Toyota is200, Honda Civic R, VW Golf Gti around might not be very economical but good sports cars with power and handling. Price range will be around 2-3 Mn. (I'm not refering to the latest models) I have seen couple of BMW 325i E36 which should be pretty good.
  22. Dude it takes at least 3-4 weeks for them to register and deliver the vehicle after it arrives (personal experiance of a friend), apperantly there is a delay at customs in inputing the data in to the system.
