Everything posted by Anjo
Toyota Passo Service At Daihatsu
+1 And when one of my friends bought a D**L laptop from them, it came with a US power cord which couldn't be plugged in to any standard LK outlet without having to purchase an expensive adaptor. When I called them (So*t L**ic) up on my friend's behalf, and calmly explained that they should've included a UK power plug like ALL the other vendors do, the moron at the other end rudely replied that that's the US cord is what's included with all their laptops and I was the only one who ever complained about it! Speaks volumes about their after sales service....
Most Easiest Way Of Restoring Your Head Lights
I use 3M Cleaning Wax. Worked for me on multiple cars.
Need This Alloy Rim
The crack is running along one of the forks and I don't wanna do any slipshot work which might affect the durability of the rim. So I prefer to replace it. Thanks anyway.
Need This Alloy Rim
Hi Guys, There is a crack on one of my alloy rims and I need to find a replacement. Couple of places I checked said they don't have the exact model and tried to sell me a new set. This is the rim I seek. Does anyone know a place where I can get one? It's a size 13 btw. Thanks. Anjo
Nissa N K11 Eps Problem
All the K11s I've seen has EPS, basically that means the power assist is provided using an electric motor. Does the dashboard light for steering (a steering wheel icon or the letters EPS) come on at the time you loose power? Most EPS issues can be attributed to an ailing battery. The symptoms are the steering is sluggish when you start in the morning but becomes ok after driving for a few minutes. If this occurs when going over pot holes or bumps, it can be due to a loose connector. What's the mileage of your vehicle? EPS motors are pretty durable and a chance of them failing early is pretty slim. As for a place to get it fixed, I would recommend that you show it to the agents (A*W)
Good Garage Around Seeduwa
Thanks VVTi and Miniace
- Good Garage Around Seeduwa
Guys, Can you recommend a good garage to get basic maintainance and repairs done that is around Ja-Ela or Seeduwa. Currently taking car to L** Al****** and need a more convenient place. Thanks a million.- Need Driver's Door, Glass And Mirror (retract)
Hi guys,I need to buy the driver's side door of a 4door Nissan March K11, and the power mirror (retracting) Any places that you recommend that has reasonable prices? I tried J***N L***A but they only have 2 door version doors.- Nissan Fb15 - Central Locking... Etc Not Working
Do you hear your door lock timer clicking when you press unlock on either remote or door switch?- Nissan Fb15 - Central Locking... Etc Not Working
Get your door lock timer checked. Strange as it may sound, the door lock timer is linked to all of the above accessories in most Nissans. It should be hidden under one of the kick panels, usually on the driver side. Press the unlock button and listen for a clicking sound from somewhere in the dash. Provided the fuses are OK, it should be a loose connector. You will need to remove your instrument cluster to check this, but usually it's a very easy and straight forward task.- Lock Timer For K11 Yom 2000
Can you PM the directions please? Thanks- Lock Timer For K11 Yom 2000
Guys, thought of adding a bit more info on my issue, This is the lock timer that was supposedly removed from my car. The Label The Wires Can another K11 owner with factory fitted CL confirm if this is the correct lock timer for my car (Model Number on label says 28451 89900)? Also, I found these two connectors with cut wires that were just left to hang underneath the dash on the driver's side. Connector 1 Connector 2 What were they connected to? And what's the function of this Yellow w/ red stripe wire shown here? it comes from the driver side door.... Any help much appreciated, and if anyone has the wiring diagram for the K11, PLEASE send me Thanks in Advance P.S. As you can see from the pics, my fusebox cover is 404. What are the chances of finding one from Delkanda?- Is 3k A Good Battery?
Yup! made in Thailand The place that gave the offer has a batch of batteries without the warranty card and offered them at reduced rate. I don't think I can mention the name and prices here (or can I?) but PM me and will give you the info if you're interested- Is 3k A Good Battery?
Hi guys, I was offered a good deal on a 3K battery for my car, Are any of you guys using it? How good is it when compared with other brands like Exide and GS? Thanks in Advance- Auto Technical Data Books-pls Request Yours
Micra 1.0i CAT (K11) 93 - 97 Please email to [email protected]- Lock Timer For K11 Yom 2000
Update: Found a friend of friend working @ A*W. When told about the issue, he said to bring it around on a weekend to have a look at it. Said most probably it's a simple fix. Will keep this thread updated. Thanks 4 ur replies guys! P.S. Know a place where I can buy a fusebox cover? coz that was missing too- Lock Timer For K11 Yom 2000
C'mon now guys, am I the only guy on AUtolanka with a K11?- Lock Timer For K11 Yom 2000
But the problem is that along with the CL, some other functions are also missing, namely Door open indicator Cabin light As per http://www.micra.org.uk/ the factory fitted CL has some cool features such as automatic door locking when the vehicle starts moving, etc Thus, I prefer to have the factory fitted CL- Lock Timer For K11 Yom 2000
Hi Guys, I bought a Nissan March K11 (YoM 2000) and the previous owner has had the Central Locking Disabled by removing the lock timer and a few wires. He handed me a lock timer and said to go visit this electrician ( S*man@Ka**bowila) and said he will fix it and restore CL. However when I did go visit the guy, he checked for a while and handed it back saying it's the wrong type for the car. He said the lock timer of my one should have around 10 wires coming out where as the one I had has only 5. I checked at J**an L*nka but couldn't find one matching his criteria. Question(s) Does any of you who own a K11 had their lock timer replaced? if so any particular place where I can get it done (I have doubts about this guy's claims)? A*W said they have to get it down via special order and said it would cost around 14k! and that does not include installation!! - Good Garage Around Seeduwa
