Everything posted by Car Lover
At Gear Shift Problem - Bluebird Sylphy G10
Hi K9M, thanks for your feedback. ATF was changed by A*W (agents). After ATF change i haven't done not more than 10,000km . Even now ATF level is with-in standard limits & colour seems good. Regarding O/D light status: During Normal condition, - Dash board O/D indicator (light) "OFF" , indicates O/D is switched ON. -- > Normally I used to drive with O/D switched ON. - Dash Board O/D indicator (light) "ON" , indicates O/D is switched OFF. So during normal days, when start the engine dash board O/D indicator lights up... wait for few seconds & go OFF again. But now when i switch ON the engine, O/D indicator lights up & blinks for few secs and goes OFF... which is not normal ...!!! Planning to go to A*W now to check this out ... Will get back to you with their findings... ( but not sure whether they are open today ... !!! ) Regards CL.
Auto Gear Shift Problem - Nissan Bluebird Sylphy G10 (2003 Model )
Hi All, I have a Nissan Bluebird Sylphy G10. ( 2003 model ) Recently i noticed that there was a problem with Automatic Transmission (AT) system. Gear shifting was not soo smooth as earlier... This problem was observed only in lower gears ( e.g: when shifting from 1st --> 2nd.. there is a observable jerk.... ) . O/D light was blinking only at startup. ( mostly this was observed during morning ) But after 10~15min drive this will get disappear.... ( i.e. gears shifts soooo smoothly & O/D light is normal ) ( PS: I have changed ATF 6 months back from agents. ) Have anyone came across with similar issue ? Any clue ? Thanks.
Yes i have changed ATF 6 months back....
The Dashboard 'piece'
try Delkanda area. i got one two years back for Rs 16,000/= the problem is matching the color. Black ones are readily available.. ( even bandnew in delkanda area ). but if it's diffrent color (e.g: Dark/ light brown ) u need to try hard ..... good luck
Hi All, I have a Bluebird Sylphy G10. Recently i noticed that there was a problem with Automatic Transmission (AT) system. Gear shifting was not soo smooth as earlier... This problem was observed only in lower gears ( e.g: when shifting from 1st --> 2nd.. there is a observable jerk.... ) . O/D light was blinking only at startup. ( mostly this was observed during morning ) But after 10~15min drive this will get disappear.... ( i.e. gears shifts soooo smoothly & O/D light is normal ) Have anyone came across with similar issue ? Any clue ? Thanks.
Brake, Engine, Battery Light Comes On
hi all, Thanks for all your feedback. Finally i got my car reparied 2 weeks back. Sorry since i was soo busy i haven't had time reply. Issue was with the Alternator. Electrician gave me 2 options; 1. To replace with new alternator --> I checked, for my model it will cost me around Rs 12~14k since this model is soo rare. 2. To repare the exsisting one. i.e. to Rewire the coil,replace brushes, bearings & to replace the IC ( Since my IC also got faulty Voltage regulator / indash indicator ) I went with 2nd option since it cost me less. ( arond 7k with labor.) Now battery is charging well. Also i found below link which discuss about all 4 wanning lights (i.e. Battery, Oil, Brake, CHeck Engine ) & their fault indications, http://autorepair.about.com/od/lightsbuzze...and_Buzzers.htm hope this may useful. thanks for all your feedback.......
Brake, Engine, Battery Warning Lights Continuously On
Hi, The link below gives comprehensive list of free technical information for TOYOTA. http://www.autoshop101.com hope this is useful... Thanks
Hi, I just went to an auto electrician. He said seems alternator is defective, since battery charging voltage is below 12v. He said need to remove the alternator and see. So i have to keep my car there and come back. After came home, I checked are there any alternator repair mannuals in the web, just to get an understanding of how it works... Fortunately i found below from Toyota USA. It's very informative, therefore thought sharing it for you all. www.autoshop101.com/forms/h8.pdf Hope this may useful..... thanks.
Hi, I have Toyota Corolla CE96 Diesel 1991 Station Wagon. Last week suddenly i got Brake, Engine, Battery warning lights continuously ON. Any idea what may be the cause .......? Is it due to alternator issue or something else ? thanks.
Toyota Corolla Ce96 & Ae91
Hi all, please let me know from where can i download "Toyota Corolla CE96 & AE91 Service Manuals" ? Further I have a CE 96 Wagon. Im planning replace Shell, Head & Signal Lights with AE91 stuff. CE 96 Face (looks like this ) http://carhopes.com/images/Vehicles/cars/A...rolla-ce-96.gif AE 91 Face (looks like this ) http://img03.carview.co.jp/trade/img01/car...8/540250/01.jpg Is this doable without any major changers to mouting points ? have any 1 done this before. Appreciate your advise. thanks.
Nissan N16 Front Wheel Hub/wheel Bolt
HI, Is there anyone who had replaced NISSAN N16 front wheel Hub Bolts? Since recently, one tyre service person had cross threaded one of my front wheel hub bolts ( wheel bolt ) while trying to refix a reparied flat tyre. I just want to know is; 1) Replacing a hub bolt is a simple task or need to take it to garage ? 2) Is it simply available in motor spare parts shops or need to look for 2nd hand one from Delkanda? 3) Any idea of avg cost of a Hub bolt ? Appreciate your comments .... Thanks
2003 Bluebird Sylphy - Owner's & Service Mannual
HI LAsi, If you refer my previous quote above in this thread, you can see the links for N16 manual download. Anyway pasting it again below for your reference... ----------------------------------------------------------------------- For all N-16 SUNNY / BB users can download the mannual from below link. http://www.phatg20.net/component/option,co...ishdown/id,111/ or http://pdftown.com/Nissan-Almera-2001-Service-Manual.html Also for SUNNY range Europe version NISSAN SENTRA 2003 -2005 also would give a close match for N16. http://www.phatg20.net/component/option,co...derby,2/page,1/ -----------------------------------------------------------------------
Guage Cluster - With Tachometer
Any help on this....
Insurance Claim For Interior Damage??
Jehan, My friend is bound to purchase complete guage set, since non of the 2nd hand sellers willing to give only the lense. Seems lense only can be purchased from agents. ( but @ a very high price ...... Brandnew lense only costs more than 2nd hand complete guage set )
Dear all, One of my friend has N16 EX Saloon car with a non tachometer type (i.e. without rpm meter ) guage cluster. Due to some issue he needs to replace this. When he went to delkanda there are meter clusters with & without tachometer option. Price wise both the models are allmost same. Will it be possible to fix tachometer type guage cluster to his model? Does this need a engine speed/rpm sensor also or it's already there for N16 models? Will the wire harness/connectors be same ? If not will it be possible do a small modification n fix it? Appreciate your valuable comments on this..
After all the comparisons "cleaning vs buy " finally he decided to buy a complete 2nd hand meter cluster. Seems he got several offers between Rs 3000~5000 from delkanda area. But now there is another question to clarify regarding the guage culster: which i'll post it under Forum--> Ask an expert --> Electrical Thanks for all your comments...
Thanks Ruslan... This has both service & owener's manuals even for my Model i.e. BlueBird SYLPHY QG-10 2003. As Jayathu mentioed G-10 service manual need 1at least 150 requsts to translate. But as you said it's not freeee......... Any way it's a good link.. Anybody else with more links with free download ????????
Thanks for your comments... As per my friend it's a well reputed service station. BUT now it seems only the name is reputed but not the job. BTW is there any one who had actually inquired b'fore "whether it is possible to claim insurance for any interior damages " from any insurance guys? This is for NISSAN N16. Most of the 2nd hand sellers don't like to give only the meter panel since it's come along with the complete dash board. Therefore some of them are demanding very high prices..... Any guess on what’s the std price of a meter panel and where exactly to look for...
Hi all, Can somebody tell whether, we can claim insurance for any interior parts damage? ( but not due to a road accident ) Why I’m asking this is one of my friend had a bad experience during his vehicle service recently. Service station ppl had put some dashboard cleaning liquid on to his meter pannel transparent foil. Now it’s totally blurred. Therefore it's soo difficult to see the meter readings. He said it will cost him around Rs 6000 to 8000 from agents to replace only the foil. Or else he has to purchase 2nd hand complete meter pannel ( i.e. meters+foil ) which will cost around Rs 11000-15000. In any case can he claim this from his Insurance ? ????
Muchang, I guess u were tired after searching for the particular manual for STARLET. I can feel it, since i also encounted same. lol But the logic is simple... For most of the Japanese versions the owenr's or service mannuals are not freely avaiable to download. Therefore you need to figure out Europen or US varients for your required model. I guess Ep 91 is the turbo charged sports version of Starlet which is called as Glanza V in Japan. So try to findout the equivelent Europen or US version for this & then search for particular mannual for that model. Hope this would help u.
I found seveal sites & seems most matching one to BLUEBIRD SYLPHY is NISSAN ALMERA. But i found only 2001 ALMERA Mannual but not 2003 or above.. I guess this exactly matches to 2001 N-16 NISSAN SUNNY & 2001 G-10 BLUEBIRD SYLPHY. For all N-16 SUNNY / BB users can download the mannual from below link. http://www.phatg20.net/component/option,co...ishdown/id,111/ or http://pdftown.com/Nissan-Almera-2001-Service-Manual.html Also for SUNNY range Europe version NISSAN SENTRA 2003 -2005 also would give a close match. http://www.phatg20.net/component/option,co...derby,2/page,1/ Would appreacite if anyone could validate above. And also by anychance if you find any matching mannual for 2003 BlueBird SYLPHY ( New face with E-Throttle Engine or N17 which most of locals call) pls let me know. While serching for last week i just found following links where you can download mannuals for some other models too. http://pdftown.com/Pdf-eBook/Nissan.html http://cardiagnostics.be/ http://www.courtesyparts.com/nissan-manual/index.html Hope this might useful you all....
Thanks Jayathu for the link. But i need to clarifiy which model exactly maps to 2003 BlueBird SYLPHY G-10... Is it 2003 SENTRA or ALTIMA or something else?
Hi All, Can somebody help me in finding Owner's & Service Mannuals for 2003 Nissan Bluebird Sylphy. Model: FG-10 Year: 2003 Car is exactly similar to below. http://www.tradecarview.com/used_car/japan...sylphy/1509820/ Appreciate your help.
