hyacc
Everything posted by hyacc
  1. hyacc replied to Le Sabre's topic in General
    http://www.rda.gov.lk/supported/expressways/stdp.htm
  2. hyacc replied to lasa's topic in The Lounge
    http://www.autolanka.com/ad.asp?ID=13587 http://www.autolanka.com/ad.asp?ID=33830 http://www.autolanka.com/ad.asp?ID=13309 http://www.autolanka.com/ad.asp?ID=25376 http://www.autolanka.com/ad.asp?ID=33831 http://www.autolanka.com/ad.asp?ID=33987
  3. Download this poi file created by ironbutcher_x, extract contents and follow the instructions in howto.txt. http://rapidshare.com/files/416564973/custom_poi.zip.html
  4. How did you run it? If you go to windows explorer and run it it will be very slow. I also have a chinese GPS and came across the same problem. I overcame this problem by this method I posted above.
  5. hyacc replied to NPP's topic in General Automotive
    Now diesel auto 4x4 Hilux Vigo double cab is available for 5950000/= http://www.autolanka.com/ad.asp?ID=36034 but yom is 2006 Next may be Fortuners.
  6. Check this http://www.tradecarview.com/used_car/japan...p;pn=0&so=1 Axios are available from FOB9000$. Look like you can save even 1 million if you import.
  7. Heard it'll be effective from 1st of September.
  8. http://www.thebottomline.lk/2010/08/29/page1.html
  9. What's the tax category for these vehicles? Vans or Cars? http://www.picknbuy24.com/detail/TOYOTA/NO...772.html?k=list http://www.picknbuy24.com/detail/NISSAN/LA...483.html?k=list http://www.picknbuy24.com/detail/MAZDA/PRE...803.html?k=list Thanks
  10. From today's lankadeepa.
  11. It's true. Sorry I didn't seet it before.
  12. There's no such news http://epaper.lankadeepa.lk/index.php?opti...book&id=923 http://www.island.lk/index.php?page_cat=ar...code_title=5178
  13. Download this files http://rapidshare.com/files/327368443/Garm...wsCE_50020w.rar Extract the contents. Save the following code in a file as Garmin.mscr Copy this file to Garmin\RunGMXT folder. Download this file http://rapidshare.com/files/61579171/SriLanka.img Rename it to gmapsupp.img Copy this file to Garmin folder. Get the latest poi file from ironbutcher_x. Create a folder as POI inside Garmin folder and copy poi file to that folder. Copy the Garmin folder to root of your SD Card. Go to Windows CE in our device and click Start -> Run dialog box and browse to SDMMC/Garmin/RunGMXT and select Garmin.exe and click ok and run it. (or create a shortcut to desktop. this is the best way to run this application. If you go to Windows Explorer and open this app it'll run very slowly) Then follow the instructions found in Keygen folder. "Garmin.mscr" Errorlevel("warn") If(WndExists("Garmin Mobile XT")) Show("Garmin Mobile XT") Exit EndIf #Whether to use Port Splitter usePortSplitter = 0 cwd = SystemPath("ScriptPath") queDir = cwd \ "..\Apps\WM" queExe = "Que.exe" #Devices with Windows CE 6 already have aygshell.dll hence Que.aygshell.exe will be run instead of Que.exe which is linked to aygshel2.dll If(SystemVersion("major") = 6) queExe = "Que.aygshell.exe" EndIf #Rename coredl2.dll depending on the current version of Windows CE Call("RenameCoredll") If(usePortSplitter) Call("StartPortSplitter") EndIf #Hide Taskbar Run(cwd \ "TaskbarHide.exe") #Copy previous stored settings to \Garmin XCopy(cwd \ "Settings\*.*", "\Garmin", TRUE) #Run and wait for Garmin Mobile XT to exit RunWait(queDir \ queExe) #Save new settings back to SD Card XCopy("\Garmin\*.*", cwd \ "Settings", TRUE) #Show Taskbar Run(cwd \ "TaskbarShow.exe") If(usePortSplitter) Call("StopPortSplitter") EndIf #Start Port Splitter Sub StartPortSplitter Global(cwd) #If Settings.dat does not exit ask the user to configure Port Splitter If(not FileExists(cwd \ "Settings.dat")) BigMessage("Port Splitter's Settings.dat not found.^NL^Port Splitter will now run to configure it.^NL^1. Select input port and baudrate.^NL^2. Check Autostart.^NL^3. Select ouput port.^NL^4. Click Add.^NL^5. Click Start.^NL^6. Click Stop.^NL^7. Click Exit.^NL^If you want to reconfigure it delete:^NL^" & cwd \ "Settings.dat", "PortSplitter Settings") Run(cwd \ "Port Splitter.exe") Sleep(500) #Wait up to 60 seconds for the window to be closed timeout_ms = 60000 sleep_ms = 250 i = 0 While(WndExists("Port Splitter V1.31") AND i < timeout_ms) Sleep(sleep_ms) i += sleep_ms EndWhile #Stop Port Splitter in case the user did not click exit Call("StopPortSplitter") EndIf #Run Port Splitter if not running If(not ProcExists("Port Splitter.exe")) Run(cwd \ "Port Splitter.exe") Sleep(500) EndIf EndSub #Stop Port Splitter Sub StopPortSplitter #Try first to stop and exit Port Splitter before killing it If(WndExists("Port Splitter V1.31")) #Stop button SendCommand("Port Splitter V1.31", 1010) Sleep(500) #Exit button SendCommand("Port Splitter V1.31", 2) Sleep(500) EndIf #Kill Port Splitter process If(ProcExists("Port Splitter.exe")) Kill("Port Splitter.exe") EndIf EndSub #Rename coredl2.dll depending on the current version of Windows CE Sub RenameCoredll If(SystemVersion("major") = 4) If(FileExists(queDir \ "coredl2.wince4.dll")) If(FileExists(queDir \ "coredl2.dll")) Rename(queDir \ "coredl2.dll", queDir \ "coredl2.wince5.dll") EndIf Rename(queDir \ "coredl2.wince4.dll", queDir \ "coredl2.dll") EndIf Else If(FileExists(queDir \ "coredl2.wince5.dll")) If(FileExists(queDir \ "coredl2.dll")) Rename(queDir \ "coredl2.dll", queDir \ "coredl2.wince4.dll") EndIf Rename(queDir \ "coredl2.wince5.dll", queDir \ "coredl2.dll") EndIf EndIf EndSub
  14. This map shows villages, small towns, main cities, bridges, lakes, main roads(A,B grade).
