HardHat
Everything posted by HardHat
  1. the bushings at either end of shocks and also the suspension arms seem to have a limited life-span anyway (say 6-8 years) and the rubber appears to get stiffened and crackeld as time goes by a chap in a service station once told me that the "penetration oil" which is often sprayed to the underbelly of a car after a hoisted wash may contribute to quicken the deterioration of rubber bushes Neoprene bushings is a better product, not sure if available in SL.
  2. in Seoul South Korea, about a decade ago, a shopping mall which had been showing signs of structural stress for some time but ignored by the mall owners collapsed - about 15 people died and hundreds injured. The mall owner, the contractor, structral engineer, safety officer, mall manager - the whole gang of culprits approx 12 of them, some of them multy millionnaire business tycoons - were fined heavily and went to jail in Sri Lanka, no one will go to jail, not even to the police, nor receive at least a slap on the wrist I presume
  3. mind you, those fake plates even got the government emblem (the good old "Rajya Lanchanaya") on them as well . Because of that I for one thought these plates are also provided by RMV probably the Police will wait until there are many vehicles on the roads with fake plates and then make a killing by fining them all - like they turned a blind eye a few years back until half the cars in the country got windows tinted and then started pulling you off the road pointing out that it is, and has always been, against the LAW!
  4. I was collectively referring to both AWD and 4WD as "AWD" but you are right - that's not the correct technical term. I'm not familiar with the RAV4, but the other Toyota SUVs (say post M/Y 2000 - 2001) LandCruiser, Prado and Fortuner are AWDs with locable center diff, and the option of Low Range of course. I'm not sure whether there is a pure 2WD version of RAV4, but if there is, and to answer denprash's Q - you will not see a rear prop shaft under a 2WD RAV4
  5. while on the subject, I've seen a few cars with pre-english reg numbers fitted with num-plates looking very much like the authentic english plates; i.e. WP 300-#### how does one get these done? from the RMV or are there buggers outside producing these?
  6. yep. that's how it works. Under normal driving conditions only front wheels are driven. If front wheels start to spin faster than the rear (i.e. front wheels slipping) power gets transferred to rear wheels as well. don't know about RAV4 but had a Honda CRV sometime back with similar set up and it s*cked bigtime offroad - used to dig into sand more often than not when taken to a beach for verifying whether one is 2WD or AWD, I guess only AWD version would have a propeller shaft going to the rear and a rear diff, thus a peek undernethe would do? Suzuki Jimny and Kia Sportage are small SUV in same class with RAV4 and Nissan Xtrail but with proper dual range 4WD setup
  7. Stuff happens
  8. need votes!! there are a few email threads going around as well with the link. Let's froward to all
  9. Rebel, yours being a passenger car most probably has a sealed, unserviceable metal box (the so called 'slush box') containing a fine steel mesh (aka the 'filter'). This is located inside the gearbox towards the bottom of it, and removal of the gear box sump will be needed to reach this unit. You cannot see the mesh or how clogged the unit is, unless you cut it up (i.e. destroy). While this can be cleaned somewhat by blowing high pressure air at the reverse direction to the oil flow, this may not be that effective if the device is clogged with a lot of particles and gunk. I'm not sure whether using any liquid like kerosine oil or diesel is recomended for cleaning the devise, ask your mechanic I suggest you check the availability of the part and the price as well before removing the sump. If the price is not prohibitively high, best would be to replace the unit as opposed to trying to clean the existing one. I've heard that certain larger vehicles like trucks and large SUVs come with serviceable units, which can be taken apart and cleaned. This may not be the case for a pasenger car though
  10. I'd usually do it after having a couple of pints of beer and some s*x
  11. better do it in a garage mate. need a service pit or ramps, may need to drain ATF and retain in a proper clean container for re-fill, need compresed air to clean the stuff, may need to replace the slush box, need gasket or sealant when putting the cover back on, etc etc - might be a tall order if you are not into DIY taht deep.
  12. With all due respect to Land Rover, I second that Velocity I have seen your stuff in the forum - pretty impressive I must say If you don't mind will get in touch with you shortly for a bit of off-roading guidence. with mercury already hitting 40+C the offroading season is all but over in Dubai until weather cools down come Sept - Oct. These are the times I feel how blessed SL is in terms of nature, despite all it's current problems which are man-made
  13. would definitely recommend this. Your problem sounds like a block in ATF circulation. In most A/T boxes the filter is located at the bottom and is accesible through a removable panel. Not a difficult operation to clean or replace this
  14. Z, thanks for the leads, I've googled around and found a few links. Unfortunately I don't have the opportunity to do any hardcore off-roading in SL, but need to network with a few like minded people to share info on mods, spare parts, garages and most importanly some less trodden and more interesting paths for getting from A to B within SL
  15. thanks mate! yes the Y61 is one brilliant piece of machinery. This one is powered by the TB45E 4.5L efi straight six and has the basic 4speed auto tranny. Except for a suspension upgrade with OME shocks and colis with 2 inch lift, rest of the car is bone stock. I would love to get hold of the later version with 4.8L VTC engine and 5 speed triptronic, but this old faithful has never let me down so far (touch wood) anywhere on or off road, so I'm stickin with it. In Dubai, UAE and the entire gulf region for that matter where petrol is cheaper than water, almost every second car on the road is a SUV, and at least 1/3 of SUVs seem to be Toyota Landcruisers (Sahara). Nissan Patrol (Safari) is a firm favourite with local boys and you can see many with bizzare modifications. Almost all SUVs available here are petrol powered, except for Landrover Defenders as for the SL off-roading scene, I think the best suited are Toyota BJs, Mitsubishi Js and Defenders from the 70s and 80s era, in terms of availability, price, spare parts, mods and local expertise. for anyone visiting Dubai, I would strongly recommend going on a desert safari arranged by a professional tour company - an afternoon of pure exhilaration!!
  16. HardHat replied to HardHat's topic in General Automotive
    is that so? Too much red tape?
  17. Pretty neat stuff. Looks like a challnging trail for an excursion. Where was this? can't make out from the plates here are more of my embarrasments crested again Jeep stuck, Patrol stuck, tight rope in between a shot from the bottom of the dune
  18. yep! that's what I'm talkin about desert driving is a child's play compared to this stuff
  19. There definitely are quite a few hardcore off road nutters in SL, perhaps they are not in this forum as you said Z I once received an email with a string of photos of a few D90s, D110s, J44s and BJ40s doing some really cool offroad stuff in SL - rock crawling, wading, climbing and mud the whole thing. Darn I did not save that mail
  20. HardHat replied to HardHat's topic in General Automotive
    yeah! how hilarious when a classic car club of all gets a classic car brand wrong?
  21. no one else got stuck? or too proud to admit getting stuck?
  22. HardHat replied to Sparky's topic in MAZDA
    for the life of me I didn't notice that the make and model has already been mentioned in the topic heading OK, if the engine is not turning over at all, we gotta start the investigation at the starter motor, and anything related to supplying power to the starter motor. No need to muck around with ingnition coils, distributors, plug wires, alternators, fuel pumps, turbochargers as yet. First of all, must make sure whether there is enough juice in the battery. You said that dashboard lights comes on. What about the headlights and horn? do they work? If not, or of they work but very weak first remove the battery, charge it at any battery kade (or at home if you've got a charger) and re-install. Battery terminals must be clean and the clamps must be tight Once the battery is full, next step is to check whether all the fuses are OK. Pay special attentian to fuses marked with "Start" "Engine" and "Ignition". There may be two to four fuse boxes in your car (not familiar with the Astina) probably one or two under the dash and another one or two under the hood in the engine compartment If the fuses are fine, next check is whether the solinoid thingy on top of the starter motor receives current when you turn the ignition switch to "Start" position. Don't try this at home if you are not familiar with what on earth I'm talking about, and bring a mechanic home and ask him to do it (having said that 9 out of 10 so-called "mechanics" out there these days will also not know how to do this simple operation). If the battery and fuses are OK but no current received at the solinoid - problem is a loose connection somewhere in the wiring - get it sorted. If the solinoid received current when the ignition is turned but the motor did not turn, next step would be to supply direct power to the starter motor bypassing the solinoid. Now definitely don't try this at home. Basically, high ampere power supply is already at the starter motor via a thick wire coming directly from Battery + terminal, but disconnected through a switch. All what you do when you turn the ingnition is that you supply some low ampere power to a magnet and coil device (the solinoid which got checked at the previous step) on top of the starter motor, which in turn moves the switch which connects the high ampere power to the motor, so that it turns. If the motor turns - problem is a jammed or burnt solinoid - get the starter motor serviced. If the motor does not turn - it's a jammed or burnt motor - get it serviced or replaced if all the above done and the motor turns hunky dory and no starting engine yet - sell the car
  23. HardHat replied to Sparky's topic in MAZDA
    need to ask some basic questions to run a 'process of elimination' of potential causes Sparky is the engine not turning over at all or turning over but very slowly? and what is the make, model, year of the car? Is it a Petrol or Diesel? Auto - Manual?
  24. Guys, I guess a big part of the fun of off-roading is getting stuck - and the subsequent recovery of course So let's share photos of our best stucks This should be one of my best to-date HardHat crested on top of a dune
  25. HardHat posted a topic in General Automotive
    Run Beam a typo of course
