Prami
  • Location
    Nugegoda
My Vehicle Details
  • Vehicle Make
    Mazda
  • Vehicle Model
    Mazda 3
  • Engine Type
    1600 cc
3,173 profile views
Prami's Achievements
  1. Prami
    Mazda Axela
    vishkid & Reckless; Thanks for the precious replies..
  2. Prami
    Mazda Axela
    Mazda Experts, need some help regarding my M3 tyres and wheels. I have a 2005 Mazda 3. Going to replace my OEM 195*65*15 tyres in to bit larger size 16" or bit larger tyre size in 15". Let me know anyone did this earlier. Checked some tyre sizes. - 205*65*15 for 15 alloys - 205*60*16 for 16 alloys Because currently car ground clearance is very low (this is the way came as originally). Hard to manage with the Sri Lankan roads. At lease if I can adjust the car height to 1" that would be good. I think only option available is to upgrade the tyres and alloys. Need your comments for this.
  3. Go for Würth. Im using this for my Mazda. Follow the instructions.
  4. Zakie - 777508864 Call him and get an appointment. I'm not sure he will work on these days.
  5. Prami
    Idle Rpm Drops
    Have you done a GOOD Engine tuneup recently? If not, before you replace the ECU please have a good engine tuneup first. Same thing happened to my car also. After the tune up it has solved. I have done a manual tuneup. But it doesn't work for me. After that I had this one before 2 years back. Without removing the injectors, but throttle will remove and clean manually. Engine will run around 45 - 60 minutes using this FUEL INJECTION CLEANER. http://img687.images...50266604050.jpg http://img684.images...05266604050.jpg - Full system have flushed using this.
  6. I think Toyota 121 stock headlight bulbs are H4 type. As Ripper has mentioned, Bi Xenon is the suitable type for your car. This is the socket type you need to get. - H4-3 Bi-Xenon (both high and low beams are xenon in a single bulb) For double check, please check your bulb socket type first and get the HID kit.
  7. Simple Answer: NO Fuel injected engines do not have carburetors.
  8. First try, Fuel System cleaner. Full system will clean from this.
  9. Short trips = Less Fuel efficiency Long Trips = More Fuel efficiency Anyway, please check and clean the Plugs & Air filers first. There are plenty of fuel system cleaners* (3M, Würth) in the market. I am using Würth in every 6 months. Price may be around Rs. 1100/=. Good results. 3M also good. *Fill up the fuel tank first and insert the Fuel system cleaner in to it. Dosage may be around 50:1 (50Ltrs per one bottle). If this is not work, better to have a engine tune up. Read this: Good Luck.
  10. First let us know the Fuel efficiency and engine capacity? Is it manual or auto transmission?
  11. Yes, Mazdaspeed will help you regarding this. And before you going to fix the parts, please have a chat with the OWNER about the prices. Can negotiate it.
  12. Whats da issue mate? I'll be there on Saturday.
  13. Anyone have tried these kind of Radar Detectors? (order from overseas) ?
  14. Yep, If not go to Sunla*ka.
  15. Yep, they had a problem with the insurance company and he has withdraw the cover from them.
