Everything posted by VVTi
5 Series (E39)
Because you can't put two profile pictures... Because I don't need a BMW to make a 'somebody'.... because when I park it at work next to some stranger's car, I am not feeling inadequate. Because when I drive it, I don't think I am driving, what did you call it, 'a car. a big car. an impressive car. a powerful car'...
5 Series (E39)
I have One word for you machang, GOOGLE. All your life's questions will be answered.
Will Hybrids Fail Or Succeed In Sri Lanka?
Pissuda Mr. Cat? If its not a Toyota Hybrid, it ain't a Hybrid...
Someone like Cali of course... he can recharge his battery while dukata pung gahagaha....
- Law On Beat Barrels And Sound Gadgets
- 5 Series (E39)
- Post Whoring - Part 2
personal experiences?
5 Series (E39)
Correct. M54 is a improved version with double VANOS, with 192bhp on paper instead fo the 170 on the M52. (Non-TU)
Didn't klnow there was a Justine Bieber version of that song...
5 Series (E39)
How old are you BTW? For ASC you can google. You can try and squeeze out 1000kms.... and have the engine burst a pipe and warp the engine in mid day traffic. If you are a gambling man, this is highly recommended as it is quite thrilling to see the steam come out and literally hear the engine grind to a halt. There are quite a number of 3 owners in this forum, so I would keep my opinions to myself about 3s. 3s are not a lesser BMW, it is a different model. I had a 3 myself and loved it to bits. Also the fact that you consider yourself a higher being just because you drive a 5 (your comment about parking next to your friend at work) confirms to me you bought the car for the wrong reasons. Also one of the most powerful E39s (540i) short of a M5 in Sri Lanka is currently owned and driven by a lady, so again I would keep my opinions regarding that to myself too... Again, I ask you, how old are you?
5 Series (E39)
Well, a good radiator shouldn't have cracked revved or not. Seems to me you are ready to put the blame on Milroy over the radiator cracking. No, BMW stereos will not play pirated stuff. ASC will come in handy, trust me... And I think I mentioned it before, I own a E39 523i manual. But can I ask you if you bought this because you wanted a E39 or because you thought you will give it a go and the price was right?
5 Series (E39)
I would rather the radiator failing at the garage than in midday school traffic. The fact that the car was driven sedately and very little would not have taxed the cooling system much. But now once it starts being used a bit you might need to be prepared for some more surprises. All radiator hoses should be replaced ideally and the collant flushed. I would do the brake fluids also and the steering fluids. About the engine check light, drive at your own risk. Key Fob buttons are $4 on Ebay.
Any Body Having A Damaged Lancer Cb8?
Yep, salvage auctions. But if you have a connection you might be able to get them before they go to the hammer.
Fb15- Attaching A Passenger Side Airbag
Where will you find the accelerometers? You guys think that the airbag is a toy, eh? You think it's something that a place like Chamara Stickers can put up like Wanker Mirrors and a 3M tint or a set of chrome door handles?
Car Air-Refreshner
Also there is a carpet cleaner at Arpico, you sprinkle it on the carpet, leave for a few hours (I left it overnight) and vacuum it. Works wonders. Smells fresh for months. It cleans teh carpet by absorbing all the dampness and any odors. Blue cardboard cylindrical canister with a pink top.
My only question is, WHY????
5 Series (E39)
That sounds like a shorted out main bus. The battery is in the rear right hand side in the boot inside a small recess. If water gets in, there is a whole bunch of fuse boxes and connectors. If water got in then there could be many reason wand many little short circuits. Few months ago after getting a small accident repair done at Millie's I had the stereo playing up on me. When I checked the CD changer and the Amp I found that water has gotten in and the water vapour has gotten in to the system and was shortening out. Took a whole day of drying in the sun, contact cleaner and hot air gun to get it all working properly.
5 Series (E39)
But how to carry in excess of 8 litres that you will need for a proper flush? Isn't there a rule against bringing oils?
5 Series (E39)
@Don, when the FSU goes blower sometimes sticks to one speed, High or Low, or its on all the time or it does not come on at all. Normally first and cheapest point of checking is the FSU as the older cars had a FSU whose heat sink was not all that good for SL Conditions. The new one I got had a larger heat sink than the one I replaced. So far so good. Changing the Climate Control unit should be the last option once all others are checked. Agents normally start from the largest and most expensive option...
But I say let the Darwinian process take place. You go and fix one machang!!!
5 Series (E39)
I had to replace the Brake Booster also due to the rubber weakening. Prestige quoted 115K+VAT, Milroy 75K. One weak point is the FSU (Final Stage Unit) in the AC blower. 14K at Milroys. Without it, the AC blower plays hell.
5 Series (E39)
If the engine light is coming on intermittently, you better get it checked ASAP. From a loose fuel cap to a sensor failure, unless you connect the scanner, you will not know. Also the ZF oil is about 6500 per litre, need some 5-6 litre for a service, plus filter charges. A vehicle that has not run that much for this long is not necessarily a good deal IMHO as they tend to start giving age related issues rather than mileage related issues.
A Small Hum From The Backside Of My Civic Es8 When Its Parked
If only Autolanka had an option to limit the in bred retards from joining in to ask only one stupid question....
So your answer is that it's 'normal' fr a humming sound to come from the rear end of a car, and that it is to remove the 'forms on petrol'? And that to have the power antenna motor constantly running is also ok??? And that if you ignore the sound will go away? WTF? Has it ever occurred to you that it could be the sound of the fuel pump?.... or a beehive in the back?
