MkX
Everything posted by MkX
  1. I'm confused. Civicferio started the thread and but prvnrox haven't given much details about this problem. @prvnrox would you mind giving more details of the problem you have. I noticed you have already bought new TB. Did you change it? What RPM range it fluctuate? Does it change only at IDLE or when you driving too? If you can give us more details, we will be able to share some knowledge. Because I went through this IACV and TPS issue for quite some time and solved the problem with changing TB. Also your TPS can malfunction without CEL giving any indication. Because it works in voltage range and error code only appear when it goes below the threshold AFAIK.
  2. Well not necessarily. The reason is that ECU reads wrong Throttle position and either increase or reduces air/fuel mixture. This will cause the RPM issue. You can be more certain if it happened when car moves at certain speed. Like in my case car suddenly start quick jerks as RPM goes up and down quickly without changing the throttle position. So it can be either of senors.
  3. I can't view what profile pic he has put on. However IMHO puting his wife or who ever for his profile pic is about his standards, talkking about fat ugly chick suits for your standards. About the topic, as mentioned, if its possible to repairt this upto proper standards and obtain proper JAAI certificate (with records of repair I guess). Do it leagal and ethical way. Sell it with records then there is no harm at all. (there are worst cars in our road). However I doubt all that will be cost effective in the end. But if you want to cut short and make some easy money its big NO. I think government should have policy and different pricing for car imports depend on its history. If the process is clear easy and transparent the perticular example of car is not the worst accident I've seen
  4. Heard a Dog crossed the road and 3 bikes collieded. Is that true?
  5. Yes.. I had the same issue and it was TPS not IACV.
  6. True compare to last time nothing much happening. Last time I bought a ticket to watch races. But when I came in the night crowd is all over and there was no place to see the races. 99% didn't even had any tickets. Luckyly most people went around 9.30 -10pm. So had clear view towards the last events.If the organizers made some proper arrangements specially in crowd control I guess people will stay till late night. At least for those who buy tickets and come will stay longer. If not streets will be empty before half of the events finished.
  7. While I agree with Don on his initial point that there should be line between personal and pulic use of forum details. This Sylvi phenomenon is not just age gap, it’s just that lack of class and dignity that makes him write those things to Watchmen. May be his age caused him forget how abusive he was and go in public to complaint against watchmen. I’m sure most our old fathers aren’t this low in act.
  8. MkX replied to Le Sabre's topic in General
    Also check your Pressure cap. if its damageded or spring has too much rust, rubber seal is broken, similar problems can occur.
  9. MkX replied to madmax's topic in General Automotive
    Isn't there any policy not to make fun of cars advertised in A/L .. at least I was informed not to do so. Just saying !
  10. MkX replied to clc's topic in HONDA SRI LANKA
    If the original badge with chessy number says Type- ViRS it should be an original. So you can verify the papers to make sure its original manual ViRS. Is it in a car sale? If so the paint may got some touch ups. Better check engine, suspension parts etc, before you make decision.
  11. Well for that price you can get brand new Perodua Viva-Elite. The trend is that, the car is the choice for most who seek brand new but none Indian make Cars. I have driven Perodua Kenari quite often. And overall very good experience for the car at that size.
  12. MkX replied to clc's topic in HONDA SRI LANKA
    First of all I think in average conditions EK3 Exi should do 10-12Kmpl and Vi/Vti models should do around 12/13Kmpl. So I guess you are getting low fuel efficiency in your car. And problem must be that your car runs open loop all the time. Once engine heated up it should use O2 sensor readings to get correct fuel ratio which is called closed loop if i'm not mistaken. (there was a thread in A/L too on this topic).If your car running open loop all the time, which means ECU recognize engine is cold and do not take O2 sensor readings.There are several sensors, but do not know if all these sensors give inputs between closed/open loop run.O2 sensor / ECT (coolant temperature sensor) IAT (intake air temperature). These sensors can malfunction even without giving error codes some times. Better test them one by one.
  13. my photo some thing wrong that i cant add flicker photo
  14. hi NPP how much was the Duty fee? I've paid 9K for DHL .. and it was about 3yrs back. Would you mind telling the tax percentage. And i guess it was charged on both item value + shipping. Thats how they usually do that. When I got my RebelXS it was like 50% - 100%. Later that year budget specifically reduced tax on digi cams.
  15. I got Canon Rebel XT (350D) and used 18-55mm lens about 3,4 years back. The seller had his own rating system where he explained his rating in the description. And it was quite informative. According his his own rating body was in one rating below his best. And it was in very good condition. However he rated his lens in 3rd or 4th level.. the photos took from that lens had small patch on it. Anyhow the total both items send with combined shipping and cost me less than 50K at that time. After about 2 weeks i've got a deal and sold it to 52K rupees.
  16. same here.. i had silver colour caps almost 3 years.. few went missing some time back. There is a guy at pertol shed who help to pump air. I think he remove them and keep. So When he come across another vehicle without caps he fix them for around Rs.20 - 50 ..
  17. I use www.beemp3.com check the highest bit rate, the version, etc and download.
  18. Sylvi don't talk thinks you don't know. You are misleading forum members by talking things you are not aware of. If you are posting a price list of a place you know, you should've given proper reference. That is how its done here.
  19. Peri/Watchman - I was out of touch with canon new offerings. So will have to do a full review the new range. Kawz - Yes you have a point there in why going from 1000D - 600D. The reason I wanted to go for new camera is that I gave the RebelXS to my brother and now in hunt of a new camera. I know that moving from 1000D to 500D/550D/600D is not a major upgrade interms of the body except for increased Mega Pixels, as all fall in entry level DSLRs. Since i'm not a Pro-photographer, I thought of going for decent body, but not a professional high end. And put money on a better lens covering more towards the telephoto end.
  20. What I meant was Nikon D3000/D5000/D7000 was introduced around year 2010 isn't it? And D70, D90 was before 2008 if i'm not mistaken. Edit: err.. or is it use of word "NEWER"
  21. Manual Vi is cheaper than Multimati Vi ..EK3?? I doubt that. Because of the problems with multimatic boxes which haven't maintained properly they tend to hold less re-sale value. At least that is what I observed here in forum and my day to day experience with the car. For the question 5 - I dont know him personally or ever been there. But I highly doubt if he or anyone can change your ECU during a tuneup. If you don't have valve timing related issue, only thing a tune up would do is clean the throttle body, clean the sensors and some clean/change spark plugs, and run the engine with 3M/Wurth fuel system cleaner. I dont know how a someone can change your ECU during the process, unless you left your car with totally unreliable person.
  22. MkX replied to Le Sabre's topic in General
    Guys what is your opinion on the break down lane? If you check the training video the Pajero Jeep has one side almost touching the white colour line on the driving lane (outer lane). So vehicles will pass it just 1 - 2 feets away around 120Kmph. Isn't it too dangerous?
  23. Yes.. I guess the Canon is more feasible option for me. Even i'm now getting used canon features little. One main reason I was attracted to Nikon is the newer range of cameras and its price. And I think canon 550d and 600 falls with in my budget range so i will check on those models.
  24. The main reason I'm looking for new camera is that my brother is start using my rebel XS as his secondory camera and he really like the ease of taking a good pics with it. my budget can stretch from 50,000 - 150,000 (depends on who I purchase, the body only or with lens) The reason I look for Nikon is that new range D3000 - D5000 seems more affordable and easy to use. However from Canon side i'm femilier with 500D. And not sure what other models available at Entry level DSLRs. Most likely I will go for ebay because they don't charge much tax here at local customs (not sure if this changed at last budget. But previous budget they've reduced tax on cameras if i'm not mistaken)
  25. Does anyone has hands on experience with Nikon D5000? I've noticed most reviews says this series does not have an Auto Focus motor built in. I thought focusing comes with the lens instead of the body. Anyhow, I'm looking for an upgrade to my Rebel XS. Planning to buy the body only and find telephoto range lens later. Another option I have is Canon EOS 500D.
