Duminda_CR
  • Location
    Mawanella
Duminda_CR's Achievements
  1. did you took the car out after long time? did you wash the engine bay 2,3 day before?
  2. This may happend due to bad maintanance only right? changing oil and filers may lead the long run without any issue
  3. for kandy guys i wanna recommend williys place in polgahamula...
  4. latest price i dont have any idea brother.. if i got a chance i will check and post the same.
  5. brother no need to fight right? yes in honda, sound is comming from fuel pump only. coz that unit is inside that as i heard from an expert. same kind of sound is comming from the power antenna unit so cant figure out unless we hear it properly. both sounds do we need to worry? thatz why i said simply ignore.
  6. definitly this should be a gear box oil problem. have you done oil change every 25000kms? use only honda cvt gearbox oil.
  7. bro.. no need to worry. this is coming from petrol engines. there are some mechanism to remove forms on petrol. that unit sounds like that only. thats not a big issue. and same kind of sound can be comming from power antenna motor. simply you can ignore that sound.
  8. Mannnnn.. cant stop laughing after see ur reply.. LOL
  9. Cleaned the alternator and issue got resolved. Thanks all
  10. bro did u check sway arm bushes?
  11. thanks
  12. Hay guyz... i got a problem with my ek3. when i driving suddenly the battery alarm comes. i checked the battery terminals even. there was no other issue. i wonder how it comes. it suddenly flash and goes some times. and some times it lasts for several seconds even.. might it be a problem with alternator?
  13. awsome idea but seems it costs. coz you need to change total breaking system including break pump and lines. no idea how much it cost. can say its possible if you have much money..
  14. Bro, then dont waste money for 60 amps battery since ur car is not taking that much power from battery. so better to go for normal 45 amps battery,,
  15. As i know it suppose to alignment after every 5000kms. since we are not running carpot roads always it gets changing. So better to check continuously.
