Everything posted by Janith Seneviratne
Mistubishi Jeepers
me too
Defender Svx 60th Anniversary
i hv seen it cz n i hv pictures of it but cant post them cz im the one who's offered to buy it 1st but b4 everything happns it wz already sold
4dr5 Jeep Meter
i'll check on hand break cz i also need one
4dr5 Jeep Meter
if you can find me one too, so i can put back the original looks, for hand break lever try asking mangala's garage at rajagiriya buthgamuwa road
4dr5 Jeep Meter
i'll be going to kurunegala 2mrw i'll let u knw if i find one
4dr5 Jeep Meter
good luck on that, two dial one is damn rare and expensive, my fuel n temp meter got burnt too, so i've put a 5 dial meter(which comes on J50 series) set, i saw those old meters for sale at willies but they asked 35000 for that, so i turned around n went home , try in kurunegala but no promises
gt a chance to see the interior its the same as original svx only thing missing is the aluminium gear knobs
the things i saw missing from exterior is body sticker only everything else exterior saw the, so then seems like an illegal one , but at least theres one of em here in SL, i could clearly see all the side SVX badgers with showed on the pictures and those wheels
today saw a defender 60th anniversary around ratnapura, can any one clarify if its a real one, all i could see is the svx front grill, side/rear badges, with no big sticker with 60 on it, suspicious part s d num cz it hd a 64- num? anyone has any info about this unique daemon
J44 Mud Guards
nothing except people r annoying the keep saying petrol mud guards dtz d main thing, checked the prices, in kurunegala they are asking 16000 a mud guard neva mind i changed my mind, now im pretty stuck financially coz of the tinkering and painting of it , so that would go to todo list
J44 Mud Guards
hmmmmm................ interesting, thank you, then seems im gonna hv to buy a pair of them too, but dunno y my petrol mud guards are stronger(its has an it has an inner skeleton to support the weights) than in the diesel ones i've seen, or is it wise to modify my ones to the diesel ones size?
J44 Mud Guards
is theres a difference between the mud guards of 4DR5 petrol and Diesel?
Is 4dr5 Came As T20?
hope they'll run out of 325 numbers soon, and harshan thanks for the knowledge shared with us
ah ddnt knw dt, i only thought converted got 65,50,51 and 32(some early converts)
325 are army auction stuff, the one running around in colombo with a GC is also an army auction one, mine i have 51-xxxx, hv seen 50-xxxx too
4dr5 Jeep
does anyone hv the diff rations of the petrol diffs one?
4dr5 Jeep
yea can do the conversion, but better go for diesel diff's and leafs, i have the same thing petrol j32 converted to diesel, by doing the conversion to coil ur gonna loose the original value of ur jeep, putting diesel diff's is a trickier job too, ur gona hv to do some chassis grinding for that in front, coz im doing it again cz the last guy who did it messed it up, in a diesel jeep the shackle holding brackets are much wider than the petrol cz in a diesel leafs are wider cz of the heavier engine and you got to have sum one really good to do this cz we're talking about chassis modifications here, for the whole 4 leafs conversion it might cost u around 25K-30K with all the parts and labor, cz ur converted you'd better do this conversion cz one of my friends jeep (a J32) had front broken leafs all the time, hv u ever hd dt problem?
Mitsubishi J44 Hand Break Lever
ah i have the same thing a J32, just got the quotation for body lining and tinkering only its 40K, seems ok
Noice In The Hub Brakes
normal garage cn do it, its not a big thing, if you know and hv the tools u cn do it by ur self
disassemble ur hubs and see the liners and try adjusting if they r binded, i had dt problem too found out my my front liners are un balanced and read liners where fell off cz of mud n water, if ur liners has fell off ur gona hv to phase the drum
Disk Brakes For Mitsubishi Jeep J44??
i dnt have disc's in my one but im not using the factory booster ones, n i hv much better break on the road, but theres a but, when i go in mud breaks dnt wrk properly and last time i checked my liners hv fell off the shoe's this time i riveted the liners so need to check again, but as disc break kit i heard theres a brembo like disc break conversion kit for dana 30(front) and dana 44(rear) called wilwood nice break system colored calipers like in an STi and ventilated disc awesome stuff put pricey each pair gona cost around 900 to 1000 dollars so for both diff's $2000 doesnt worth it for a 4dr5, better use a bigger servo and the diff with bigger drums (dtz wt i did)
same scenario with my old man, dtz wt he also want, wtz ur jeep n around how much did it cost u for the paint?
4dr5 Jeep
ok good topic, there is a difference between the engines of the jeep and rosa/canter 1. the starter motor is fixed from the engine side cz of the different bell housing unlike in the jeep its from the gear box side 2. in jeep oil filter is a top mount( directed to top) in canter/ bus engine its the other way around 3. intake manifold is different in bus/lorry cz it takes air from an air box fixed in body sumwhere 4. bus has a bigger radiator as i think cz its has a 12 ltr coolant capacity vs 8 ltr in jeep 5. most of the buses and lorry's hv 12v starter and systems 6. clutch slave is also different in lorry's and buses 7. jeep has a coil spring type, buses and lorry's have a diapragm spring 8. 5 fwd gear boxes hv a 3.8 ltr oil capacity so i guess its bigger than jeeps one cz jeep can only have 1.7 ltrs, so guess there will be a problem coupling d transfer box cz of the space issue 9. and the gear ratio's are totaly different in 5 fw n 4 fw (dnt know on 3 fw stuff) Gear 5 forward 4 forward 1st 4.755 3.000 2nd 2.765 1.795 3rd 1.492 1.354 4th 1.000 1.000 5th 0.792 so its little different hope this helps
4dr5 Jeep
which one do you want column shifter of floor board shifter i have a floor board shift gear box in my shed, if interested PM me
as i know the best way is to put a diff with disc breaks to it, there are dana30 and 44 diffs with disc breaks
