Janith Seneviratne
Everything posted by Janith Seneviratne
  1. hy i think he has j4x series shackles coz in j5x series the shakles are like u bolts
  2. there should be one, cz no body gives credit to these jeep, all are thinking that LC's n LR's are the best, dnt see the what's inside the these babies, from my experience they are much better than BJ's
  3. as the 4dr5 engine manual says the original alternator does not hv a W termonal
  4. is there a mitsubishi jeepers club in SL
  5. no oil level rising, found 1 problem there's a little diesel leak in tank where the fuel line connects, now its fixed, bt still it uses about Rs. 500 diesel to go from nugegoda to kaduwela to koswatta to kaduwela n back to nugegoda, is it normal or if its not the should be the diesel pump 1f my frnd told me dnt replace the diesel pump, go to a pump worker n tune it
  6. no oil level rising, found 1 problem there's a little diesel leak in tank where the fuel line connects, now its fixed, bt still it uses about Rs. 500 diesel to go from nugegoda to kaduwela to koswatta to kaduwela n back to nugegoda, is it normal or if its not the should be the diesel pump 1f my frnd told me dnt replace the diesel pump, go to a pump worker n tune it
  7. yea i gt wt ur tellin i heard a good news yesterdy a frnd f mine told me there's a working j44 meterset for Rs.7000/= sum where he knws so if there's more i'll post here the place here, n the way u tell i hv to dig a hole in d dash, no worrys if i cn gt an original thing bak
  8. the thing is if i put the 5 dials i would hv to dig a whole in the dash board, am i right, its worse than attaching a leyland, and i checked my meters and i dnt think we can replace the coils of it, cz if i cn i would probably go 4 it, do u knw sum1 who cn do that, n i want a really need a fuel gauge cz i think i hv sum problem in my fuel consumption cz i dy i went from nugegoda to nawala and piliyandala and back to nawala n again to maharagama with 10ltrs and when im cuming back from maharagama to nugegoda, engine stopped "no fuel", so as early warning need a gauge, any ideas on wt 2 d on that, is really replacing the diesel pump fix this ????, n btw if u knw sum1 who cn repair gauges tell me plz
  9. putting a 5 dial meter sets takes the looks so i've been thinking of using a Leyland Floater, Temp Sensor and there gauges
  10. i already hv an extra 5 dial meter set which comes with J55, bt if i install it, i'll loose the original looks, so now im thinking of leyland fuel n temp gauge n attach it
  11. i checked it, it the two dial gauge, the coils inside are burnt, n the sender works fine under the parameters of 20 - 120 Ohms, n i wiring is also works fine, no broken wires
  12. does any one know any where i can one of those, my fuel n temp gauges are not working
  13. yea sry i gt d full tym 4x4 thing, i ddnt changed anything for awhile, and there r no big tires in my jeep, normal road tires, this happened suddenly, now its like a week this started happen i checked my milage it only does around 3-4km per ltr, i only added a 2" lift, do u knw a good mechanic who checks ryt, i mean a honest guy, i checked the diesel lines but there were no problem in it, n thanx for the replyin
  14. does any1 knows where cn i buy wagner driving lights? the following is the light i want i only want 1, f any1 hv one tel me a price
  15. i hv a J44 jeep it used to gv a good milage, but now for few weeks it drinks diesel, it needs about 4ltr to go from narahenpita to battaramulla n back it used to do more, any advice wt to do, as i knw usually in normal conditions these engine at least do 10 km/ltr, 12 - 13 max when in topping conditions with 4 wheel on, i hv full time 4 wheel cz no lockin hubs
