Sylvi
Everything posted by Sylvi
  1. Sir, I have leasing with Commercial leasing Their leasing interest at the moment is 14% for example you take a leaseing for 3 years. VAT AMOUNT IS DIVIDED TO 36 EQUAL PORTIONS DEPENDING WHAT IS THE VAT% AMOUNT YOU HAVE PAID AMOUNT AND YOU NEED NOT PAY ANY INTEREST FOR SAME If your leased amount is 1M sellers Invoice says he had paid 20% VAT. THAT AMOUNT TOTALS TO .2M. Then you pay interest only for .8 M WITH ADDED VAT EQUAL PORTIONS .2M DIVIDED IN TO 36 INSTALLMENTS. .8M WILL GET REDUCED WITH THE INSTALLMENT GO ON AND INTEREST IS CHARGED TO BALANCE REDUCED CAPITAL AMOUNT ONLY. VAT CHARGE WILL BE SAME AMOUNT ONLY ADVANTAGE IS I DO NOT PAY INTEREST FOR VAT. I have taken OD facilities also. I hope this is correct what I pay now if there is an mistake please do correct me. Like to hear other members comments of above. Wijesinghe.
  2. Sylvi replied to Devinda_Z's topic in News & Updates
    Sir, I do not dispute your post you may be correct by all means that is in Japan. This came to me from USA as a Email so I thought I will send this post to the forum some thing new. The new-to-America Cruze is Chevrolet's latest small car and comes powered by either a naturally aspirated 1.8-liter four-cylinder, or a 1.4-liter turbocharged Ecotec four-cylinder -- both with the choice of either a six-speed automatic or manual transmission. The turbocharged engine puts out 138 horsepower and 148 lb-ft. of torque and should be capable of up to 40 mpg on the highway. The 1.8-liter puts out 136 horsepower and 123 lb-ft. of torque. The Cruze is offered in four standard trim levels, as well as a specialty option package, known as RS Appearance, which includes rocker moldings, unique front and rear fascias, front fog lamps and a rear spoiler. Wijesinghe.
  3. Sylvi replied to Devinda_Z's topic in News & Updates
    From the web. 2011 Chevrolet Cruze Engines Use Eco-friendly Cartridge Oil Filter The 2011 Chevrolet Cruze will make proper oil filter disposal and recycling easier. The Ecotec 1.4L turbo and 1.8L four-cylinder engines will use a cartridge style oil filter which is easier to recycle and service compared to the conventional steel canister-style oil filters. Recycling canister style filters requires that the metal housing and other elements, like the rubber seal, be cut away or separated, whereas the compact cartridge style is made of only paper and plastic. Because of this, proper disposal of the oil filter is easier for recycling centers. Another benefit of the cartridge-style filter is that it can be changed easily and is virtually drip free from the top of the vehicle. This lessens the chance of oil dripping to the ground or driveway and possibly making its way into the water system when performing oil changes. The housing for the cartridge-style filter is part of the engine and reused for the life of the engine. It never needs replacing. The housing also has a screw-on replaceable cap that eliminates the conventional canister-to-engine mating surface that is a potential source of leaks.
  4. From the web Advanced high-strength steels help automotive designers cut weight and increase crash worthiness Advanced High-Strength Steels Add Strength and Ductility to Vehicle Design By Jessica Shapiro Authored by: Paul Geck Edited by Jessica Shapiro Key points: • AHSS steels have both high strength and good formability. • A mixture of microstructures gives AHSS their properties. • Designers should aim for structural efficiency, thin plates, and strong joints to take advantage of AHSS. Resources: American Iron and Steel Institute, www.steel.org [2] Society of Automotive Engineers, “Advanced high-strength steels for vehicle weight reduction” seminar, taught by the author, www.sae.org [3] “Basics of Design Engineering: Steels for strength,” machinedesign.com/article/steels-for-strength-1115 [4] What material is seeing the most rapid growth in automobiles? If you guessed aluminum or composites, you’d be wrong. It’s advanced high-strength steel (AHSS). The material comprised just a small fraction of cars and light trucks a few years ago, but it could grow to over 30% of vehicle weight within 10 years. [5]Although higher-priced, lower-volume vehicles like the Audi A8 have converted many of their parts to aluminum in response to fuel-economy pressures, the trend has been for moderately priced vehicles to stick with steel. These mainstream vehicles are using better manufacturing techniques — like laser-welded blanks, hydroformed components, and better joining techniques — in addition to containing up to 30% AHSS. When the Honda Insight was first launched, it had among the highest percentages of alternate materials of any vehicle on the road. However, the latest version of the Insight is one of the most AHSS-intensive vehicles. Likewise, BMW came out with an aluminum front end on its 5-Series a few years ago but recently switched back to steel. So what is AHSS, and what makes it so attractive automakers? Grades of AHSS have strengths to 1,500 MPa but retain the formability of lower-strength steels. In general, elongation, the property that equates to formability, degrades as strength increases. AHSS is formulated for more elongation at equivalent strengths. [6]Microstructure magic The high-strength, high-ductility characteristics of AHSS come from the metals’ unique microstructures. Where most steels have primarily one microstructural phase, like ferrite, AHSS typically has a combination of martensite, bainite, and ferrite phases. Each microstructural phase has a different crystalline or molecular structure. For instance, ferrite has a body-centered-cubic (BCC) structure, and martensite has a body-centered-tetragonal structure. Each structure has its own set of physical properties due to the forces within the crystals and the densities with which atoms are packed in a crystal cell. Phases form during annealing, a process in which steel is heated to 850°C so that it becomes pure austenite. From there, the steel is cooled in a controlled manner that determines the final phase mixture (see “Transformative cooling”). [7]For instance, if the steel is cooled at a very slow rate, the austenitic phase will transform into ferrite without transitioning into any other phase. Conversely, very rapid cooling or quenching produces 100% martensitic steel (MART). A slow cool followed by a rapid quench produces dual-phase (DP), complex-phase (CP), or transformation-induced plasticity (TRIP) steels, all of which have AHSS properties. Alloying elements like silicon, manganese, chromium, and molybdenum shift the phase lobes on the transformation diagram, making it possible to form the desired phase mix with feasible cooling cycles. Forming and springback The combination of phases keeps AHSS formable while they retain the high strength of martensite. Formability is especially important in automotive manufacturing where large presses and multipiece dies form parts. AHSS parts are formable by traditional methods, but they typically need stronger die materials or coatings that boost die life. Manufacturers may also need higher tonnage presses to form these steels. [8]A key difference designers need to take into account when using AHSS is a greater degree of springback, the tendency of a metal to partially return to a previous shape. While all steel parts have some degree of springback when removed from the press, steels that undergo more work hardening or strengthening during forming have more springback. There are several strategies for reducing springback. One is overforming the metal so it springs back to the desired dimensions. For example, to stamp a 90° angle into a sheet of steel, overstamp it to about 87° and it will springback to the desired angle. Designers can also optimize radii in the edges and corners of the stamped piece. Other strategies involve changing the design of the finished part to minimize springback. Structural strategies Despite AHSS’ better strength, steel still has to compete with aluminum’s lower density. But aluminum may not be a panacea for automakers. For one thing, 30 times as much steel is produced than aluminum, so it can be hard to sustain production or keep prices down on an all-aluminum car. Various research studies (see “High-strength history” sidebar) have shown that proper application of AHSS can cut a vehicle’s weight between 10 and 25%. When fuel economy is paramount, the 5% fuel-economy boost a 10% reduction in weight provides is a nice carrot. But designers should be aware of certain approaches that can take full advantage of AHSS’ capabilities. Automotive bodies can be considered to be a combination of plates, beams, and joints — the intersections of two or more beams. If all the steel in a car was replaced with aluminum and no design changes were made other than making the aluminum parts thick enough to achieve the same overall stiffness and strength of the steel vehicle, the distribution of strength and stiffness would still be somewhat different on the aluminum car versus the steel one. For mechanical responses that are proportional to the specific modulus — the modulus of elasticity divided by the density — there’s no advantage of switching from one metal to another from a weight perspective. For instance, the torsional stiffness of circular thin-walled tubes made from aluminum and steel of the same weight is the same. Looked at another way, two thin-walled tubes having the same torsional stiffness, one made out of steel and the other made out of aluminum, weigh the same. However, the torsional stiffness of a plate is not directly proportional to specific modulus. A steel plate weighs twice as much as an aluminum plate of the same area (but not thickness) and the same torsional stiffness. So, designers can improve structural efficiency and minimize the benefit of converting to aluminum in two ways. First, use higher strength steels to minimize the weight of plates in a vehicle. Second, get the vehicle’s internal beams to behave more like closed-section, circular tubes. Advanced architectural elements like laser-welded blanks or hydroformed beams can help a steel body or frame compete with aluminum in terms of weight. Laser welding two sheets of dissimilar-thickness or dissimilar-grade steel together puts strength where it is needed in a single steel stamping. Hydroforming a continuous hollow tube to the desired contour in a die using water pressure eliminates spot-welded sheet-metal beams. Because the tubes are continuously fastened and of a thicker gage than the sheet-metal beams, they have higher strength and stiffness. Joints are a third area designers should consider. The joints of an all-steel vehicle will usually have lower strength and stiffness than those of its all-aluminum counterpart because the joints have typically higher stresses and steel is thinner gage than in the aluminum vehicle. So, strengthening and stiffening the steel vehicle’s joints will reduce the weight benefit of aluminum. Designers can add internal stiffeners to boost joint strength. More manufacturers are also converting spot welds into continuous welds or adding continuous adhesives in the seams of the joint. These strategies let automotive designers maintain or reduce vehicle weight in the face of increasing safety and crashworthiness requirements. One example is an upcoming change to the National Highway Transportation Safety Administration’s roof-crush requirements. Since 1994, vehicle roofs have had to withstand a load of 1.5 times the gross vehicle weight (GVW). In 2011, this will grow to 2.5 to 3 times GVW, necessitating thicker or stronger roofs. High-strength history 1960s and 1970s: — Vehicles used predominantly mild steel because structural performance was dominated primarily by stiffness. Higher-strength steels have the same stiffness as mild steel, so automakers saw no reason to switch. 1980s: — Fuel economy and safety requirements pushed manufacturers and steel suppliers to introduce conventional high-strength steels. — High-strength steel content topped out at 30% in the middle of the next decade. 1990s: — Designers turned to aluminum, magnesium, and fibrous composites to cut vehicle weight. More-stringent fuel-economy requirements looked to outweigh increased material cost. — AHSS being studied in laboratories were costly and hard to weld. Despite better formability than conventional high-strength steels, springback was a barrier to designers using AHSS. 2000s: — The International Iron and Steel Institute began the Ultralight Steel Auto Body Advanced Vehicle Concepts (ULSAB-AVC) study. — Improved Materials and Powertrain Architecture for 21st Century Trucks (IMPACT), jointly funded by the U.S. Army, Ford Motor Co., University of Louisville, and American Iron & Steel Institute, sought to trim pickup-truck weight 25% with steel construction
  5. Sylvi replied to dilku's topic in General Automotive
    Mr. Dilku, I will inspect as you had mentioned they have a improved version of buddy Micro van. Wijesinghe.
  6. Sylvi replied to dilku's topic in General Automotive
    Mr.Dilesh, You cannot write correct English do not try to engage another argument with me. Wijesinghe.
  7. Sylvi replied to dilku's topic in General Automotive
    Mr. Dilku, I replied to your request about what I have had with Chana Van. Any problems I have faced. Delish one member on this forum all ways try to engage a argument with me he had insulted me with personal filthy messages to me. Which I did reply to him in same manner. I told on my post this Vehicle was used by a friend of mine as he did not Know much of engines for 2000 Kms for a function without checking water or oil level Water level had gone down and it has boiled he stooped the van and poured water then re stared engine started missing I was out of the Island for 25 days then he has returned the van without informing any thing. That was the reason for engine valves gave trouble other vice there was no problem when I gave the Van before I left the Island there was no problems on the Van this boiling was not filling water level at least once in three days. My friend admitted he never checked any thing for the 2000 odd Kms he only he filled Petrol. I use this Van now after the Engine top overhaul without any problem. Any driver is first thing in the morning check oil and water level Battery water in 20 to 30 days you can see the brake oil level on the tank as this is a plastic tank. I hope this is clear to you and to other members cause of Engine problem. There are millions of Chinese built Vehicles are running daily round the world Srilanka too has number of Agents offering Chinese Vehicles they are existing. Chinese Vehicles are daily Improving with R/D is very high stranded in China they will be the leading Vehicle supplier one day. Even Japan started mass scale Vehicles only after 1970 before that the had only USA UK vehicles in that country.I have seen them personally. Japan hit first the Watch then Motor cycle followed by Vehicle and all other consumer items. We in Srilanka had all vehicles came from WEST. UK GERMANY USA FRANCE before 1962 only after 1977 Free imports were allowed Japanese Vehicles started coming in. Wijesinghe.
  8. Sylvi replied to dilku's topic in General Automotive
    Mr. Dilku, Three years ago I had a petrol Vennette which I bought in Japan and it was getting old I was running with domastic Gas cylinder I had no problems. I selected Chana because it is a new Van with lot of space 11 seats I removed one center seat which has the folding seat and fitted to my old vennate and sold same to a friend of mine for a very low amount late it was sold after 6 months of using having a profit of .2 M BY THE NEW USER. THEN I BOUGHT CHANA VAN FOR 1.3m AND GOT FULL LEASE 41000 FOR A MONTH. THIS CHANA VAN HAS A BRAKE PROBLEM THEIR MASTER CYLINDER IS NOT PERFORMING THAT WELL I CHANGED TO A NISSAN ATLES VAN MASTER CYLINDER HAD TO REMOVE THE TANDEM MASTER CYLINDER BECAUSE NO PARTS WAS AVALIBLE WITH THE AGENTS GAVE DIRECT BRAKE FLUID TO REAR AND FRONT. THIS VAN WAS USED BY A FRIEND OF MINE FOR FUNCTION FOR 20 DAYS HE HAD NOT FILLED UP THE WATER AND THE ENGINE STARTED MISSING WHEN HE RETURNED TO ME I REMOVED THE HEAD GOT IT REFACED AND HAD TO CHANGE FOUR VALVES AS THEY WERE BENT AND COMPRESSION WAS LEAKING. ALL JAPANESE SPARES FIT TO THIS VAN ENGINE THIS ENGINE 1300CC IS SUZUKI GYPSY JEEP PETROL ENGINE.NO POWER STEERING. Double AC very efficient but gave away the fans in 25000 KMs. Other than that no problem so far I have had I get about 7 to 10 KM for a liter in Colombo Out of Colombo about on 5th Gear I get 13 KMs for liter.I have done now 33000 KMs. Tyers are changed to 4 Ply as this had 6 Ply it was uncomfortable rear helper springs was removed and front coil springs were changed to smaller gauge springs to be more comfortable Spare are available body panels too with the agents. They are getting down a new set of Vans 11 seat 1.1M do not know when it will come. I have told them to reserve one for me. I### Trades also going to get down a similar type of van Petrol and Diesel. They already have Pancha truck .9 M. Your are welcome with more details if you want. My advise is to use a new Vehicle As Chinese vans are better than what it was few years ago. Wijesinghe.
  9. Members, What about a petrol car with(LPG) gas conversion. Italian Unit. I used upper cylinder oil for engine head lubrication. I used gas converted Nissan for 4 years 60000 Kilo meters saved on fuel about R 100000.00 and sold with a profit more than what it cost me never gave me any engine problem. Wjesinghe.
  10. Sylvi replied to Devinda_Z's topic in News & Updates
    From the web Vehicle maker selects AP and T hydroforming press Jul 12, 2010 Faw Car Co, a Chinese manufacturer of trucks, buses and cars, has invested in a hydroforming press from AP and T in order to produce the engine cradle for a new automobile model. As the plan to produce a new automobile model was finalised, the company decided to invest in advanced technology in order to be able to shape more complex components. The structure that the entire engine is mounted on in the automobile - the engine cradle - can be produced in a variety of different ways, for example by welding together several pressed sheet metal components. However, Faw opted for hydroforming since it offered a number of advantages. Bjorn Kinnby, AP and T's Asian market director, said: 'With hydroforming, it is possible to transform a bent and pre-shaped tube into the engine cradle's final shape in one operation. 'The material experiences no spring-back and it is possible to maintain extremely tight tolerances, otherwise known as the "net shape". 'In addition, it is much lighter and there is considerably less scrap compared with conventional manufacturing, which means both a lower manufacturing cost and a higher quality,' added Kinnby. Hydroforming involves filling a tube or profile material with fluid, typically an aqueous emulsion. With the increase of the fluid pressure, the material expands and is shaped to match the tool's mould. Since the fluid's pressure works perpendicularly against the mould's surface, it is possible to shape components with complex geometries, often in one or two operations. Typical forming pressures are between 1,000bar and 2,000bar. In order to minimise the thinning of the material during expansion, fluid is injected from both ends of the tube with the help of the mould's axial cylinders. During the hydroforming process, the mould is held together by a hydraulic press, with press forces of 30,000kN to 50,000kN (3,000tonf to 5,000tonf). The press that AP and T delivered to Faw has a press force of 35,000kN (3,500tonf). The 'short-stroke'-type, energy-efficient press has a short cycle time. According to Liu Qiang, project manager at Faw, when evaluating the available options, AP and T was the only supplier that offered a NC-based system for the control of both the hydroforming tool and the press as a joint forming process. The following nine months consisted of close project co-operation between the parties as AP and T designed, built and tested the hydroforming press according to the time schedule. Jack Wang, AP and T's area sales manager in China, said: 'The very first piece of material we shaped was close to perfect and was within the applicable tolerances. 'The reliability of the form is one of the advantages of hydroforming and the tolerance reliability is the result of our servo hydraulics together with the NC control system,' he added. Faw also has a 25,000kN (2,500tonf) hydraulic press previously supplied by AP and T, which has been used for several years for the testing of conventional press tools for vehicle components.
  11. Sylvi replied to dilku's topic in General Automotive
  12. Sir, One consignment of Vehicles has arrived to Srilanka Last week Importers are trying to cover up the loses from their old stocks keeping the prices still high some importers have reduced their prices not that unreasonable another consignment of Japanese used Vehicles will arrive by 20th of this month. Wijesinghe. Members I Apologize for repeating massages due to my computer problem this will be attended today
  13. Sir, One consignment of Vehicles has arrived to Srilanka Last week Importers are trying to cover up the loses from their old stocks keeping the prices still high some importers have reduced their prices not that unreasonable another consignment of Japanese used Vehicles will arrive by 20th of this month. Wijesinghe.
  14. Sylvi replied to tharindu6's topic in SUBARU
    Mr. Tharindu, It is great you did solve your problem yourself. I find that your Happy days are coming very soon. I will Write a small verse by a western poet about a happy marriage with my Best Wishes. Your wedding is a door to happiness, Is the start of something better When two of you all decided to share the lives as one. Your marriage is an adventure bright and new; The pleasures and delights have to begin share by you'll. Wijesinghe.
  15. Mr. J Senviratne, You are all correct by all means research and development in the advanced country's had done all comfort to the motorist in new Vehicles what you had mentioned. I appreciate your reply educating members of the forum. Thanking you. Wijesinghe.
  16. Sir, ISUZU GEMiNi first car introduced in 1970s by Japanese then this first two cars came to Srilanka by 1980 that car was very fuel efficient used to get more than 40 miles for a Gallon of diesel a friend of mine bought one of the first cars which he did more than 200000 KMs without much problems. Rear seat was not that comfortable At that time my friend paid R 200000.00. Wijesinghe.
  17. Big-D Thanks, Wijesinghe.
  18. Sir, Your comments on high end Diesel vehicles with technical details I agree. At last you mention about the minor lag in acceleration How can person overcome this lag. Do you have any suggestions with your Diesel engine Vehicles experience to lead the acceleration lag AS I lite to experiment if you have any improvements to be done to a Diesel Engine of a Vehicle. Wijesinghe.
  19. Sir, I agree with your comment. The member wants to use this type of vans for passenger he will have to modify his suspension on rear. If it is used for goods transport he can use as it is. As Srilanka imports mostly Goods carrying vans. Suspension is not suitable for passenger transport. Wijesinghe.
  20. Sir, You say that way is not the fastest to come to that showroom if there is another way please inform. As I go their from Kollupitiya passing the petrol station you are correct by your post in heavy traffic hours the road is congested. Wijesinghe.
  21. Please give your fastest way to come to that point. Wijesinghe.
  22. Diesel Vehicles are epencive as told in this thread and maintance cost is also same as said by others I too prefer Petrol Vehicle to disel with all morden tecnology installed. This above what I WRITE is my opinion Wijesinghe
  23. Sylvi replied to tharindu6's topic in SUBARU
    Sorry for repeted messages I have a problem in my Computer. Wijesinghe.
  24. Sylvi replied to tharindu6's topic in SUBARU
    Mr. Tharindu, I have send you Email please check your Yahoo account in case if you have not sorted out your problem Wijesinghe
  25. Sylvi replied to tharindu6's topic in SUBARU
