sank
Everything posted by sank
Thanks mate. From below url we can compare the variants. http://specs.cars-directory.net/mazda/familia/1998_226/
Thanks a lot
Ok guys. Thanks a lot for your information. they help me a lot. Please be kind enough to stop comparing Honda and Mazda within this topic. I beg your pardon thousand times because I did the same mistake earlier. I just want to know whether there are any variants within BJ5P. ( Say BJ5P type 1 some features are available but type 2 not available etc..) Or every BJ5P come with same set of features?
Thanks many times for your response.
no not prohibited. I want to buy an English number vehicle
thanks for the response. What is better B3 or B5? do the above efficiencies for auto gear car?
Yes, you are correct. Honda is better than Mazda. I had ek3 few years back but I can't go for Honda YOM beyond 2000 within my budget. Do you know about fuel efficiency of mazda?
OK. I want to buy a mazda familia. There are few models like Bj5P, Bj3P Bj6P etc.. SO what is the best one among them. Details about fuel efficiency are there any common issues with mazda famila?
Hi, i want to buy a mazda car (non hatch-back) arround 1.8 to 2 mn. I am new to mazda and appreciate your support.
Which Is The Better Between Nissan B14 And Honda Ek3
sank replied to Ruwan Sampath's topic in General Automotive
Buy Honda EK3. It is better than B 14 or FB14. I had EK3 which did 10 - 11 kmpl in Colombo and 14kmpl outstation. You can't get the driving pleasure of Honda from Nissan. -
If this noise is with FM channels only (not with the USB) then check your antenna cable connectivity. Connect ground wire to outer connector of the antenna socket.
First turn off the engine and check whether if there is any noise. If no noise Start the engine and check. If noise appears, most probably the reason would be improper grounding. Most car audios have outer casing and inner casing. Some people connect the ground cable to outer casing for easy. (They don't use the power connector ground wire.) As a result the circuit board ground doesn't receive 0 volts exactly and noise arise. So correctly ground the unit using shorter length wires will minimize the noise. If this not works then another reason would be the problem with the input filters of car audio power supply. For this you have to add LC filter before the car audio power supply.
A Shot List Of Tips And Tools A New Diyer Would Need
sank replied to jdnet's topic in DIY (Do-It-Yourself)
Thanks jdnet. You can easily buy tools from hardwares at Panchikawatta. There are so many products available including German, American etc. I recently bought Chinese socket set and its very good. Indian sets are also available but durability might be less because in some cases the sharp edges of sockets become round if you try to unscrew bolts. This problem occurs specially in wrenches. -
Useful content. Thanks for sharing.
I think Mitsuboshi (not Mitsubishi) is better than BANDO. I use Mitsuboshi ones without any problem for long time. And also you can identify which belt has the problem by pouring little amount of water on to each belt while the engine is running and check the noise. Once you do this if the noise disappears the problem is with that one. I'm not an expert but this how I identify the problem.
How To Change Frequency Range Of Car Radio?
sank replied to Ajith Chanaka's question in Electrical problems
If someone interested.... I bought the FM modulator from Pettah 1st cross street shop for Rs.165 in February 2010. The range is 94MHz - 108 MHz. In my area (Gampaha) it works fine but when I reached to Colombo the channels are mixed. -
Replacing 60/55W Bulb With 100/90W H4 Bulbs
sank replied to mjayanath's question in Electrical problems
If you replace your 60/55 bulbs with 100/90 the reflectors get damages due to the excess heat. I personally experienced this. If your reflectors are in good condition use only 60/55 W bulbs. -
Is it true that Diesel once done more than 10kmpl?
Hi, I want to buy corolla AE110. Though corolla and sprinter has same engine (correct me if I am wrong) corolla price is higher than sprinter. Can anyone tell me what is the reason? My major problem is how to identify corolla and sprinter separately. (Except from the badge) Recently I found a sprinter 1.3L crystal light model for 1.65 million. Is it worth?
Dear Experts, I want to buy FB 15 car. But I don't know how to identify Super Saloon and Ex Saloon separately. Because someone can replace the Ex Saloon Badge with Super Saloon badge.
Nissan C22 vanette YOM - 1991 Engine - 1950 CC Transmission - manual Colombo - around 12km/l Outstation - 15 km/l Those values are without A/C.
