jdnet
Everything posted by jdnet
  1. Machan if heaven is full of priuses, i would rather go to hell and drive a DB9 or something.
  2. But you gotta pick the right one. OBDII is a U.S. standard for all vehicles after 1996. When it comes to Japanese vehicles, it depends on each vehicle. Some vehicles past 2000 still came with OBD 1 and the rest either have OBDII or JOBD (basically a version of the obdII platform). Eitherway the majority of newer JDM vehicles will use JOBD. European vehicles use EOBD which is another variation of the system. Eitherway most JOBD scanners will be able to read generic codes on cars with other versions of OBDII, the problem is that they wont be able to read manufacturer specific ones. If you are going to buy a scanner you should figure out what vehicle you want to read the codes off of and what obd system it uses. Here's one of the basic scanners I just bought to toss around the place since I do not want to take out my more expensive scanner all the time: http://www.amazon.com/Autel-MaxiDiag-JP701-Diagnostic-Scan/dp/B001LHXUI0/ref=sr_1_3?ie=UTF8&s=automotive&qid=1295681831&sr=8-3 It should work fine on yuour vehicle if it's JDM or european (again, it will not work on vehicles that have OBDI). If you want to read all cars (OBDI II JOBD EOBD) and get manufacturer specific codes then you are going to need a scanner like the new bosch one I got. Although the price difference is almost $5000 lol.
  3. Yeahb I was just checking since those filters tend to clog up well before the recommended interval. I used the drop-in filter on my old intrepid and but didn't have any issues in the 50,000 miles I used it for. Then again I was in an area with minimal air pollution and dust. Never really checked for dust either. If you do notice dust in there you best change back to paper filters. Longetivity of the engine is worth far more than the little performance you get out of the filter.
  4. Are you using the K&N recharge kit? you gotta make sure the filter is decently cleaned and oiled. For our conditions you should atleast cut the service interval on the filter by half. Eitherway the best and safest thing for the engine is the paper filter.
  5. Stop trying to be a hero. I love how these idiots who never contribute only come in when one of their fellow retards is injured.
  6. Loan sharking. 5-10% a month interest rate.
  7. probably because of the curve?
  8. Edited: was probably in bad taste....
  9. Not again........
  10. I hope they do have a minimum speed. A combination of cars moving really fast and really slow will make for a bad situation. Also a minimum like 80 kmph will help weed out the cars that cannot reach the speeds safely.
  11. You should really get the fluid changed then. What year is the vehicle?
  12. Just curious...will three wheelers, buses and container trucks use the highway?
  13. right........
  14. jdnet replied to flyboy320's topic in General
    Yeah my IO has that I think the brand is razo or something. Didn't even know I had it until I took off the panel to install a new timer. Turned out it was there but switched off. Lol I once got the timmer running for like 3 mins. A lot of speed and a whole lot of revving. Eitherway the cool thing about the unit is that it would not set the timer if you haven't been using the turbo (high revs).
  15. Machan the newer "clean diesels" like the jetta actually get far better KMPLs than hybrids and don't sacrifice power for fuel efficency. They don't require battery pack changes either and are a whole lot cleaner than the older diesels, actually. It's actually just as clean as a petrol allion. As always someone here picks something up and thinks it's a magical development. Truth be told if they would reduce the tax on new diesels we would all save quite a bit on fuel, not to mention the saved foreign exchange...
  16. jdnet replied to jdnet's topic in DIY (Do-It-Yourself)
    Well I did run into another problem while taking measurements. The plastic which the badge is mounted to sticks out a bit too far. I'm left with two choices. 1. cut it and shorten it or 2. Delete it all together and install metal strips to mount the badge onto. I was thinking of deleting the thing all together and just mounting the badge onto the mesh but the spokes support the frame.
  17. jdnet replied to jdnet's topic in DIY (Do-It-Yourself)
    Really what car is it? pics? BTW I.m going to go with the chrome border too
  18. 1. There isn't a maximum milage per se and there isn't any way of telling the milage other than my tearing it down and inspecting the wear on it (even that would only tell you the condition). 2. There is no such thing as a reconditioned engine. Either it's rebuilt or it's not. I doubt there are any places here that get down rebuilt engines. What we have imported are used engines. 3. Reliability? again, these are USED engines so you really can't say. It's highly dependent on the vehicle it was plucked out of. 4.Value of the vehicle overall decreases with engine transplants. Also i a buyer wants to finance the vehicle he will run into problems 5. Depending on why you want a new engine, repairing will be cheaper (exceptions are cracked heads and blocks). 6. Over all, rebuilding an engine is safer than replacing it with one from a car you know nothing about. When rebuilt, most of the parts will be new and the the whole engine should actually function like it's brand new (if done right). So the best bet is to rebuild an engine.
  19. Exactly why would someone wanting to buy a car worth 2.8 million go for two marutis instead? That's like saying "don't bang Jessica Alba, you can bang two Oprah Winfrey's instead."
  20. jdnet replied to jdnet's topic in DIY (Do-It-Yourself)
    After looking at the setup of the caddy grille, I decided that mine should sit at the front instead of the back as originally planned. It looks like I'll be taking a trip to the machine shop to get a hole cut in the mesh that wil let it sit around the mazda badge. Also I didn't get to pick up the mesh today either. So no updates for atleast a day or two. What do you guys think of the new grille?
  21. jdnet replied to jdnet's topic in DIY (Do-It-Yourself)
    BTW if anyone needs to know what I'm getting my inspiration from its the cts
  22. jdnet posted a topic in DIY (Do-It-Yourself)
    Ok so I know I have another thread on this but I thought i'd change this into a DIY project. This DIY will not be specific to your car and the materials needed and how it should be done would depend on your car. For most cars you probably will be able to take the grille out without cutting,but on mine it's a part of the bumper so I basically had to use a jig saw to cut it out. I'll be using epoxy to put it back in. I left the center spokes holding the badge because I really didn't like the debadged look I saw on some pics. Plus this makes it look more stock. BTW a big thanks to kelum_wj and TDI300 for helping me decide. I'll be updating this thread as I move along. Grille cut off the bumper. That the front end looks like now The grille with the spokes cut off. The mesh I have behind it is just a ordinary one I put on just for the pic. I will be installing a better looking stainless steel mesh on it. I cut off the spokes with a jigsaw and sanded down everything using a finishing sander with 60 grit and 100 grit sand paper. If you don't have any power tools you can get the same results with a saw blade and sanding it down by hand. Next step would be to repair the holes left after cutting the spokes out. I haven't come that far yet but i'm thinking fiberglass would be the better option. Anyway will update soon.
  23. Thanks man. Thanks for all the pics too.
  24. Now the second one looks really cool, especially if I add the mazda badge to the center. Would hide all the damage to the condenser fins too. Any idea of what would be a good material to build it up with? I probably would have to get it chrome plated...
  25. This would look great with the mazda badge in the center but the only problem is that it would be pretty hard to fabricate for me. Need to get this project done fast too as the tribute is probably going out in the next month.
