jdnet
Everything posted by jdnet
  1. Ok guys, I decided the grill on the tribute was annoying the heck out of me. Basically there isn't any mesh protecting the condensor and everything on the road was hitting it. I tried painting and sticking a mesh behind it but without cutting out the grille it did not sit well. So today I just cut the entire grille out. Still haven't decided what to do with it. I probably should have thought about this before I cut it off because now I really gotta get this done. So here are my options. 1. Take send the grill out to get chromed and find a decent looking stainless steel mesh and stick it behind the grille. 2. Fabricate a new grill out of stainless steel mesh to take the place of the old one. Let me know what you guys think would be a better option. As she sits now without a grille: The current grille BTW I know my condensor looks bad, but there are no leaks so i'm going to let it be for now. Also The chrome trim on the hood is missing on the pic. Didn't get to pick it up from the chrome platers today.
  2. check autob**ein delkanda if you are looking for a used sensor. As for getting it check I would try M**na motors and avoid ca*m*** at all costs.
  3. lol I wasn't saying it's not cool to have. It's always nice to have all the bells and whistles. As for the oil thing. If the car has been sitting for a while (i.e. the morning), 10 seconds is plenty to get the oil upto the vital parts of the engine. The best thing you could do for your car is take the first few kilomteres nice and steady without any sudden accelerations. The only thing you would need to do different in a diesel is to let he glow plugs warm up until you start the car.
  4. Cool, I'm glad I could help. I must warn you that although working on automotive electrical systems is time consuming and annoying, it does get addictive.
  5. Well the idea place to tap into the harness would be at the connector but eitherway do you think a car thief will take out the remove the screws, take out the dash panel and try to figure out which wire to cut, all while the alarm is set off? Automotive theft used to be a little big but it seems to have died down in recent years. Mainly due to the fact that they can't send stolen cars up north anymore. I'm not saying it doesn't exist though. One things like remote start, here's my 2 cents; Running a car at idle for 10 mins or so to cool it off is an utter waste of gas. The best thing to do is get into the car with the windows rolled down and start driving and once the hot air is out just switch the a/c on?
  6. Why are you going through all that trouble to find the ignition wires? All you need to do is find it it from the ignition cylinder on the steering wheel, and follow it down to the connector, you can even tap into it at basically any point you wish.
  7. rebuild engines, transmission, electrical systems, basically anything that was affected. Then a complete teardown and clean up of the interior. Everything depends on whether the car was running and sucked water in and on where the water reached. It's pretty relative to the specific car affected though.
  8. Basically those two wires are the ones that stay around 12v during cranking. It's a secondary power source for the module. Ground the black probe of the multimeter and use the red one to check the reading on the wire. Basically unless someone can tell you the exact color of your wires you will need to check the readings of the wires connected to the ignition one by one while cranking. Either way if you have the right wire it would be one that stays around 12v during cranking. About the second ignition wire; it basically does the same job as the main AFAIK. I can't remember too much on it but I believe you can use the same wire as the ignition wire you tapped into first. As for what would be relevant to diesels, I haven't installed any on diesel vehicles but I believe the only difference is that you will have to run the glow plug wire to the unit. Also this should give you a better understanding of what the wires are: http://www.howtoinstallcaralarms.com/tag/remote-start/
  9. Ok so I guess wiring should not be a problem to you. Exactly which wires on the harness you got with the viper unit do you have trouble with?
  10. http://forum.autolanka.com/Index.php?/topic/3430-how-to-buy-a-used-car-in-sri-lanka/
  11. Well I've installed a few and could offer you some tips, but let me ask this from you first. How good are you with electrical systems in cars? Installing systems with remote starters are a serious PIA and unless you are familiar with the electrical system of your car, it would be a lot safer to get it professionally installed.
  12. http://www.youtube.com/watch?v=BeP6CpUnfc0&feature=related
  13. jdnet replied to M navy's topic in TOYOTA
    Adey stop lying machan. I can take my tribute upto 350 kmph and make 90 degree turns without rolling the car over. Think your balta can do that? Plus mine comes with 5 seat belts. Oh yeah and the boku allow wheels add to the safety of the vehicle!
  14. jdnet replied to sara1987's topic in HONDA SRI LANKA
    You sure? A few months back I bought an EK3 and sold it at a loss in less than a month and yes I did go for another make.
  15. tool shop at jubilee post. They have the spray and paste. I think I need to go pick up a can of that spray tomorrow.
  16. jdnet replied to M navy's topic in TOYOTA
    Machan in all seriousness why would you want to buy a belta? 30 kilomteres per liter is horrible. Buy my mazda tribute, it gets 45 KMPL.
  17. jdnet replied to M navy's topic in TOYOTA
    Op is an inspiration for birth control.
  18. Sumiya, There's this rust removing gel you can use. I can't remember what it's called but you just apply it over te rusted area and it easts at the rust leaving you with clean metal to work with. Anyway look around. I lovedthat stuff.
  19. Why is thiws your first post?
  20. jdnet replied to M navy's topic in TOYOTA
    FINISH HIM! MORTAL KOMBAT!!!!!
  21. jdnet replied to M navy's topic in TOYOTA
    Ahhh that statement will really help getting you the answer. BTW if you have to know the 1000cc belta gets 27 kilometers per liter.
  22. ummm I think you should be fine getting 9kmpl in the colombo traffic. I would be worried if you are getting this on a long trip. Here's what you should do: Before you get a heart attack by stressing yourself out about fuel figures, just forget about them for a while and just drive the car. Now if you are getting horrible kmpl's during outstation trips then let us know. If not just enjoy the car...soothing music helps.
  23. jdnet replied to Mars Volta's topic in The Lounge
    Machan you should join me for a round of fishing one of these days. Although I must warn you that I'm more of a spear, ice, fly and bow fishing guy. Eitherway, the most important part of fishing is the cooler box.....
  24. jdnet replied to Mars Volta's topic in The Lounge
    Yeah prices are a bit high, I'mnot going to argue with that. Although when his father was there I always got a steep discount since he knows my father pretty well. The thing I like about that place though is that they are retty helpful and even the son knows about the rigt lures to use. I think the last I went there was during the middle of the NE season and I found that the xrap lures cost more there than the shops on top of the fish market. Something like a Rs. 600 difference. Although the reason I recommend the place is that the op is looking at places for a beginner to gear up. The owner should be able to tell him the correct gear to use. You won't find that sort of help in the fish market places.
  25. go to a car sale and find it out, there's also this new invention called a telephone....
