mensoft
Everything posted by mensoft
  1. YES. that's what we must do .
  2. you can make this without any other comportment just to light 4 leds . but to be safe we better use the correct diagram. as i mention this it the correct one i found on the net to use in the car.I made it and using without any issues . so if you want you also can try making these in different ways and up[date us too.
  3. Thanks for the comment Bro. Diod for protect from any reverse voltages Capacitor for filter any large spikes that can burn LEDs (This have made for car. not for just 12V) Resistor to limit the current.
  4. Then can you post a picture of your "4LEDs in series to a burnt bulb broken the glass". ? R U using these in your car without burning ?
  5. Sure @ dearly road . I have seen some at arpico too. some times can find @ auto parts and electrical shops .
  6. I think 4d dashboard better buy the 12LED has made for dashboard.
  7. 4LED in series OK for 12V .but Do car gives only 12V want it go higher when it charging ? Do alternate also gives exactly 12V ? no any spikes ?
  8. YES. there are lot of products if you go to dearly road. but this is DYI fun .
  9. in the site i found this is very suitable for cars . capacities and diode will protect the LEDs from any spike.
  10. Just go to peta. 1st cross street . you can find the parts .
  11. This is how i made led parking lights. Just found the diagram from the net and applied on my car . Only you need 100nf capasitor ln4007 diod 150ohm resistor 4 white leds Old Parking Light When it Light Remove Old Bulb This is the circuit you need to make . this is the the bulb with 4 LEDs. Super Bright parking light. For all of these It will cost you only Rs.30 Max.
  12. I also think can get from panchikawatha or delkanda. But I think how good if you put a new diesel engine.
  13. Hi Lancer L , Happy to see a lancer owner here. I also use the lancer Flat light . Its Exactly gasket. You need to relapse the gasket . its not a that big job . you no need to sell the car because of your Mach said . if you really love you car and you want to keep it running it can be repair . it will cost around 6K as i guess .
  14. mensoft replied to jami's topic in General
    I think its a timing belt issue .
  15. Ya Ya washers i got for 150. 3600/= went for replace washers + break liners too. (sorry for the mistake).
  16. I never know that . I have seen most of the garage fellos clean the parts with kerosene. so i used . any way i washed all kerosene with water after .
  17. Clean the cylinder with a soft piece of cloth. Assembled all again with new washers. Bit difficult part is to put the springs back. (Forgot to say I got the sketch before I remove the springs) Filled new oil to the master cylinder and send the air on break line . (For this you need a help of someone) Done. This time I spend only Rs.400.
  18. New break washers and cylinder covers. Spare parts shop ask whether need rubber grease also when I buy the oil and washers. I had no Ida abut this grease. They say that is use to put the washers without make them damage. Any way I brought that too. Then I clean all the parts with kerosene oil and then water and kept to dry.
  19. This is my project on repair rear wheel break washers. Suddenly my break paddle was going down more than it was. And poor break. Then when I check the break oil level. Rear break oil cylinder was empty. Then I check real wheels from the car behind I saw there is an oil leak. Once I went to the garage to change the break washer and they charged me 2500/= and I had to bring the parts too. Almost around 3600/= it cost. I thought this time I’m going to do and start the job. Leak on wheel cylinder Tools I used for repair Had to buy break oil Little kerosene oil l to clean
  20. mensoft replied to mensoft's topic in General
    This is what exactly i was thinking. Thanks Don
  21. mensoft posted a topic in General
    Is it possible to convert carb model car(First Gen Lancer A72) to EFI ? where can get this done ? cost ? Is it pointless doing ?
  22. mensoft replied to mensoft's topic in General
    can we convert this to Km/l ??? Honda generator ? NO.
  23. mensoft posted a topic in General
    215 g/psh (2000 rpm) what does this mean ? what is the meaning of 215 g/psh (2000 rpm) whan talk about fuel consumption ?
  24. mensoft replied to mensoft's topic in General
    Yes . That's good . Tel me how to do it ? Already i clean my air filter and i removed the hose connected to the filter cover from crank case . now the smoke and bit oil spreading to the ground. but when conect the hose engine runs smooth than it removed. my engine is Mitsubishi MCA-JET (G11B) that hose is now disconnected from air filter cover .
  25. mensoft replied to mensoft's topic in General
    will it be a big repair ? how much it will cost ?
