dhana8706
dhana8706's Achievements
  1. A Nissan cedric?
  2. Im interested in this model too. Wanna see da pro members view before buying one.
  3. ppl talk about an issue with the dashboard. not sure though. But mostly its about the market here IMO.
  4. But Cefiro is a really good vehicle for that price. If u r not worrying about fuel.
  5. Yep a gasket failure.
  6. yaa. this is not so good. this gonna effect our tourism :S
  7. Mostly These fuel types define their anti knock qualities. Usually the engine knock is caused by fuel molecules breaking apart and detonating before the spark plug ignites the air fuel mixture (self ignition). The engine will be damaged if it is allowed to continue. Designing an engine to reduce knock tends to reduce its efficiency and power output(low compression ratio). Using a fuel with good anti-knock properties allows designers to deliver more power and efficiency out of the engine by increasing a high compression ratio. So theres no point using fuel with a higher octane rating than the engine was designed for. So long as the fuel doesnt cause engine knock, its good enough. Some cars are optimised for higher octane fuel, but can run on lower octane fuel by electronically detecting knock and delaying the spark timing, at the expense of power output and economy. And some cars can run on either 95 or 90 octane petrol. Turbocharged engines are recommended to be used high octane fuel then the turbo can increase its boost pressure.
  8. People have to learn at least now onwards to wear seat belts. And da purpose behind buying a S-class in other countries is da SAFETY factor. Sad they didnt get da benefits of it. May they rest in peace. :\ they were crazy bt very kind hearted friends.
  9. Im not surprised dats mazda agents.
  10. wat abt Nissan cefiro? A33? or mark 2 X100?
  11. wat do u mean by better than 121? :S
  12. yes. so true
  13. lol
  14. NOOOOOOOOO. dont. second hand market is even less than 23. brand new it costs 3 mil to ma knowledge. and its nt comfortable at alll. wats dat mark ii representing? dat toyota one? well its fa better than da micro thing.
  15. Money cant buy skills!
