GAPAUTO
Everything posted by GAPAUTO
It has passed the warranty period for brake related units.
@Davy No micro didn't provide me the error codes, i forgot to ask them even for future references. But what they told me is that the device was malfunctioning time to time it cannot be predicted at what time it will malfunction. As your saying if it cannot be happen due to the smoke test RPM probe, then i think it might be factory defect in the device :(.
Few months back my ABS unit starts to malfunction. The ABS light comes on time to time when driving. When i took it to micro they said the the ABS unit it malfunctioning time to time and it not a issue in the sensors. By the way they first tried by cleaning the sensors :). They also amazed about this because the car was just finishing 2.5 years and only ridden 9000km. I remembers the last time before this ABS problem starts to show up, at the smoke test they put thier engine sensor with the magnet kind of thing on something similar to this ABS unit. if that was the ABS unit can that magnet thingy can cause the ABS unit to malfunction ?
If you are willing to do a DIY job then i recommend looking at this video. As other said i think it good to refrain from doing a traditional paint job since that will any way look bit different and in the process of removing the panel they will damage at least one hook or bracket . Or do a youtube search with this search text "paintless dent repair body line" you will get lot of videos showing workout a bodyline dent as yours.
Here is the guide i promised http://gapgeelydiy.blogspot.com/2016/05/replacing-wiper-blades-on-geely-lc-cross.html
Just got it removed guys i will share a How to guide link soon and mark with as resolved.
I tried to lift it but it doesn't seems to lift
Guys i need help on removing the wiper blades from a panda cross. I search the internet but every video i found which has this kind of wiper arm has a small clip to unlock the blade from the U hook. But this is bit different and i'm not sure how to unlock it. if anyone has experience please share how to unlock and remove it, that will be a really good help. I have attached two picture how the arm and blade look like since the arm cannot be lift 90 degrees.
From where did you buy them ? I'm also in search of touch up paint pens to deal with minor scratches which has reached the base coat, and i would also like to know where i can buy clear coat spray cans ? Clear coat pen would be fine as well.
Thanks Davy, Great explanation and This was what i was looking for, Sure i will try to start a new restoration thread and post everything there. GAP
Hi i own a 1978 Lancer Station Wagon which i'm in the process of restoring parts since it has lot of worn out parts. One of the two things that i;m looking right now is the radiator and the handbrake mechanism inside the rear drums. The radiator is having a small leaks which started few days back and i had this problem twice within a year. Now i just want to go for a permanent solution without soldering the same radiator again and again. So i was hoping whether i can find a after market radiator (not a recondition one). When i called the radiator house they told me to visit there branches so they can see what can be done. So i just want to know whether i can get a after market radiator from recognized place like radiator house or any other known place. Otherwise i will be soldering this twice per year on my whole life since i'm not in a mood get rid of this car . The second part i'm looking for is the hand brake assembly which is in the read drum. The teeth in the mechanisms are worn out so bad the handbrake doesn't get applied properly. Is it possible to buy a new shoe with this assembly as a whole unit ? For this also i prefer to go for a new one because junk yard stuff are also half way worn out. GAP
You are probably right , just called Radiator House and they even don't have the universal (flexible) once available. But they claim that the moulded ones are avaiable for this 1978 Wagon model in panchi as you said, and even they might also have so i'l just check on them. I wonder how engine moders (racing mods) find the universal stuff or may be they import directly i guess. To bad our spare part shop owners are not up to date with the parts available in the world
It seem they only support new models , mine is a 1978 Wagon version
Hi Guys, Today morning my lower radiator hose just cracked while the engine was running. Luckly i was at home and just after starting the engine. I did some quick checks around Kadawatha to find one, but seems since my car (Lancer Wagon) 4G12 engine is more than 30 years old they don't have them. Any known places in Panchika Watta to buy this ? Or any one knows a place where i can buy a flexible radiator hose as shown in below picture This seems to be alternative for old engines with lack of molded hose which comes with the engine. And even if i find a molded one probably it won't be a brand new i guess, but going for brand new flexible hose might be a good idea as i though. GAP
Hi Guys, Thanks for the advises, I think i will look for 13" and according to http://www.ajdesigner.com/fl_tire/tire.php i think using 155/70R13 will give minimum effect on Speed Thanks
Hi all, What is the recommended allowheel size that I should choose for 1978 lancer wagon ? Right now my tire is 155R12 76SS which is 12". I don't want the change to mess my speedometer reading or lower ground clearance. GAP
Thanks for the advice, well i'm not try to make it look like a a mustang of course, cause a wagon will never look similar to one like that. What i want was to give a new look so that it look young and sporty . I think if i want make a American muscle out of a Japanese car i better sick to a Celeste which can come more closer in looks . Any way your suggestions are really valuable
Do you have a mechanical distributor or Electronic one ? Because if its mechanical then i would check the platinum points and the condenser. As suggested if the cold start system failure then probably you shouldn't have damn rough engine as you say. Because i had used two cars where on had a electrically controlled choke and a manual choke which both of them they were not working.
I'm looking for the whole assembly. And i heard there is place in Makola Area, anything any one here know about a place Makola for lancer parts ?
Hi All, I own a Lancer Wagon which is 1978 made. I broke i tale light from a small accident so i'm looking for a place to buy a new one or a pair. Can any one point me to a place where i can find them ? I live in kadawatha so my preference is a place near kadawatha or panchikawaththa. GAP.
Well i want to slightly modify it to add some muscle look into it like this http://carphotos.cardomain.com/ride_images/3/556/3881/26389440010_large.jpg
Any pictures of the pimped ride where this thread started upon ? i own a lancer wagon and i'm also thinking of pimping a bit to be a more Japanese muscle since how much we try we cannot make it beat a Mustang .
