Malkoba
Malkoba's Achievements
oh, I drive a prius everyday. about 100 kms which includes multiple reverses in 2 car parks. I never found it hard to reverse it. Probably that's just me :). The main reason I went for prius over Aqua was the space.
I'm curious as to why the Prius is not discussed? 3rd Gen 2014 goes around 3.5 mil. Well, the battery may be dead or faulty, which adds about 4.5K. But apart from that and the steering rack problem, it is a decent hatch and with 1.8 engine you get a decent pulling power. Maintenance is low if you keep it well. For the fuel figures, you can get at least 18kmpl in City traffic.
Yes. My girl friends neighbor aunt's cousins daughter's husband works in there and he said YES.
It cannot be a local DB file. The message itself contain that it cannot connect to the SQL server instance. if he is using a DB file (i.e. SQLite), then he should use an ODBC connection. not SQL connection. The drivers for these 2 are different. Actually, Even in SQL server, its referred to as Local DB when you are accessing it form the machine itself.
Install SQL Server Management Studio. First try connecting to the SQL server from there. If that doesn't work, try changing the network configuration for SQL Server. i.e. enable Shared Memory/ TCI/IP. Then try enabling SQL server browser.
I think Brand new Camry battery will cost about 600k - 650k in SL. But it comes with a warranty so you are covered just in case. If you get the battery from AU, you are testing how lucky you are . If you like, I can PM you a number so you can check the prices. I was told by a mechanic in TL that just replacing the block would not last as it is the starting point point of battery degradation. Next you will have another block out of sync and then another, so you will end up paying more and spending more time in garages. Not to mention the stress knowing that battery gonna fail anytime when you are on a long journey. Believe me, I know how it feels. I was on a trip and at Nuwaraeliya when my dashboard started flashing. Again, replacing cell vs replacing battery is open for experts to comment as I'm not an expert in any way on this matter. This is totally my own experience. I just went with replacement for the peace of mind.
Replaced my Prius battery at 398k rupees about 2 months ago at 120k on the clock. As far as I know, cell/block replacement would not last, but I would keep it open for the experts to comment on. At TL, got a quotation for 550k. So I went around and found Browns Hybrid care at Borella, in which they charge about 100k less for the same battery with 1 year/24k km warranty. I think Camry battery is pricier than mine. However, I would suggest to look around and check the prices as TL is significantly higher.
Thanks for the replies. I have to replace pads like every 40k because of my driving styles. ? You are absolutely correct tiv. TL quoted 23k per disk.Not going there to buy anyway Today I checked some hard breaking, One was about to hit a rear of an axio. missed by couple of inches. but didn't feel any wobble or anything. no pulling to a side as well. So does this mean that its good with the current disk?
Hello experts, I would like to have your opinions about the following matter. The impacted car is Prius 3rd Gen (2012). Can happen to any car though I was out of country for a while and the car was driven by my spouse. When I'm back, I saw a tiny groove on driver side brake roter. I The brake pads were worn out, but the metal indicator was not set with the previous brake pads, hence no metal sound. Regardless, I replaced the brake pads with OEM parts from GS Auto. The mechanic recommended to resurface the front roters due to the groove saying it will impact the brake pads and the braking. My Questions are is resurfacing really worth when compared to replacing? Or even resurfacing is really needed when you have a groove which is about 1-2 millimeters in width and depth? If replacing is better, I would go with OEM parts. Any idea on the cost margins Anything specific to keep an eye on Thanks in advance.
If you think of trying to run in EV mode, I suggest to get an electric car instead of a prius. Unless its a plugin hybrid, EV mode is useless. Well, to drive
toyota prius buying a toyota prius 2008 or aqua 2012
Malkoba replied to Rohitha1988's topic in General Automotive
Aqua will be better than prius with regard to fuel consumption, given that you stay on "Economic Range", as per one of my "Friend" based on his Aqua. I drive a 2012 Prius and I get average 15kmpl from and to colombo daily (100km up and down) even though I'm always on Power mode and drive it like a normal gasoline car. So if you want to be more economical, you will have to turn "Eco" mode on, which has less acceleration. Not sure how much it will save you as I never drive on Eco mode. -
Well, this is my 2 cents. The car will treat you back if you treat it properly. I have a 2012 prius with 100k on the clock. Still battery is at 100%. I normally do all services at TL for the peace of mind. Yes, their may be places cheaper than that with the same quality. But if you are not 100% sure about those places, agent is the best option. One more thing I noticed is that people put a lot of pressure on battery. They try to yield max saving by putting the car to EV mode all the time and stress the battery out. I'm not sure this a good thing. I drive mine as a normal gasoline model, and always on power mode, which give me the extra acceleration. I really don't look at the battery, still it gives me around 16 kmpl average from home to Orugodawatta and back. That is 100 km daily up and down.
Yep. Checked on youtube how to replace it. will do it today. Thanks for the info guys.
Thanks for the support guys. I installed translator as you suggested for future use. I will have it checked with Toyota Lanka
