Sierra Charlie
Everything posted by Sierra Charlie
  1. <blockquote class='ipsBlockquote'data-author="Davy" data-cid="267767" data-time="1413640372"><p> Reviving this thread to ask a question to which the answer may seem obvious. The Nexus 6 vs the OnePlus One. What do you guys think?<br /> <a href='http://www.gsmarena.com/compare.php3?idPhone1=6604&idPhone2=6327'>http://www.gsmarena.com/compare.php3?idPhone1=6604&idPhone2=6327</a><br /> <br /> While the Nexus 6 features stock Android 5.0 (Lollipop) with a whopping price tag of 799 USD, it seems like going for the OnePlus One with pretty much the same spec (yet with Android 4.4 + Cyanogenmod) is the sanest choice for a fraction of the price.</p></blockquote> Guess the Nexus line has a fairly large advantage over OneplusOne in terms of OS updates. I've used Cyanagenmod on couple of my phones and the experience was fairly alright then. I've moved to Nexus since and no plans to move on to any other platform. One problem I'm having with Cyanagenmod is I've no idea how their support is going to be like with future Android releases. Used a Samsung for a while and the only problem, and the biggest reason to move to Nexus, was that they didn't support OS releases for their phones well.
  2. This is awesome. I'm not one of the tree-hugging type. But Tesla is probably the way to go as far as electric vehicles go.
  3. Customs seem to be quite strict on small items since of late. If the package is small, they tend to usually pass it without much hassle. Bigger packages attract more attention and I've not come across a logical way to predict how the customs would act on packages from eBay or any other vendor. As for me, I had to pay some taxes for a camber kit I got down from eBay. However a much larger package containing a couple of switches and interior trim was passed along just fine. Probably they just consider the weight of the package, with heavier packages undergoing more scrutiny than lighter ones. Anyhow, only order stuff from well reputed vendors. I personally prefer eBay since their guarantee is spot on. Plus, their dispute resolution process tend to err on the buyer's side. As for taxes, just brace yourself. It might come through just fine. But in any case, have a cash buffer of about 40% of the value of the item you buy. You have to pay the taxes then and there if your package is retained at the Central Postal Exchange.
  4. <blockquote class='ipsBlockquote'data-author="The Don" data-cid="266964" data-time="1412096683"><p> Yeah, the electronics might have gone funny thanks to the identified faults, causing and intermittent problem.<br /> <br /> Do you have part numbers of the parts you got/found? The Gallant is sold in the UK but a lot of them came with GDi. But sometimes stuff goes for cheap. I once bought a Lancer throttle body complete with sensors for £15</p></blockquote> I do indeed. Will send you a PM.
  5. <blockquote class='ipsBlockquote'data-author="The Don" data-cid="266959" data-time="1412091890"><p> <br /> No but sounds like the issue is gone now. I don't think you got your engine washed did you?<br /> <br /> Oil filters usually don't cause this issue. But sometimes due to pressure washing water gets inside certain contacts and you get a bit of a miss for a short period, but this disappears when the engine warms up and you run a while.<br /> <br /> Do the simple things first. I think you got your spark plugs replaced recently didn't you?<br /> <br /> Take all plug wires out one at a time, inspect them at both ends (spark plug, and distributor end) and then put them back. Check for white dust and corrotion. Then inspect the wires for damage, and make sure all connectors are fully in place and locked in.<br /> <br /> Then look at the air filter and make sure its clean.<br /> <br /> Are you confident with a screw driver and taking parts off an engine (like TPS, and ICV)?</p></blockquote> Hey Don, I'm OK with tools and in fact carry a somewhat extensive tool box in the G. I'll complete the inspection items tomorrow morning. I'd rather not take out the TPS though. It's set to a point not to cause idling issues. I once had an episode of high idling RPM. Air filter is clean and the plugs were declared OK by the famed Mr. Fernando. But I'd eye ball them plug wires. Thanks for the tips Don. Will keep you posted on the progress.
  6. <blockquote class='ipsBlockquote'data-author="The Don" data-cid="266952" data-time="1412080280"><p> <br /> Well unlikely, but do keep an eye on the temperature, the next time it happens. Usually jerks are also an early symptom of overheating which is more likely when you are revving the engine harder. Does your jerks come with the taka taka sound usually associated with being on the wrong gear?</p></blockquote> Temp is normal, thankfully. I was on 2nd and 3rd almost all the while this happened. So I kinda doubt it was something to do with the wrong gear and nope, no taka taka sound. I had my car serviced right before this drive. New oil/new oil filter. Forgot to mention that. Could that have had anything to do with this jerk?
  7. Hey Hashan, glad to hear that your issues are sorted. Need to get mine sorted too.
  8. <blockquote class='ipsBlockquote'data-author="The Don" data-cid="266880" data-time="1411995249"><p> <br /> Sounds like your engine is trying to stall, but the anti stall is kicking in to rev the engine up.<br /> <br /> The issue is probably either with your idle controller, throttle position sensor or the MAF if that is the case. But you usually experience these problems very close to idle speed. So I'm not really sure at all if this is the problem. Did you say you recently replaced your ICV?</p></blockquote> Hey Don, have to replace both the TPS and IACV. It's been quite a struggle sourcing the parts. I should get the TPS shortly. Ordered one from eBay since I couldn't find it locally despite quite an extensive search. I tried replicating the issue while driving in Colombo on straight roads. Couldn't do it. The G chugs along fine at no throttle on 2nd and 3rd gears. No hiccups. Could it be a combination of hilly roads and the load from the power steering while on A7 that triggered it? BTW, if anyone is wondering what a sane man is doing at 3.30 in the morning, you might have never heard a couple of rats frolicking on a ceiling. Better buy a cat.
  9. Sure. Happens when my foot is on and off the accelerator as long as the revs are low. Noticed it mostly when the RPM is around 1300-1900. I let it coast a few times to see if it would stall. Nope. Didn't stall. But the jerking continued. I replaced 2 engine mounts after I bought the car. It's less than 4 months since I replaced them. I haven't had the clutch/flywheel/pressure plate looked over.
  10. Went to Gampola over the weekend on the A7, probably one of the best hill driving experiences here in SL. Once you settle to a cruise, it's just a matter of enjoying the drive and the scenery unless of course you have a nagging issue like I did. So Gents, here's the case. whenever I drive on the 2nd or 3rd gears around 1300-1900 RPM, there's quite a noticeable jerk. Happens when decelerating, which is often on a road like the A7. I already have issues with the TPS and the IAC valve (Both of which I'm looking to replace) but I never noticed such a pronounced jerk before. What should be my course of action? I'm thinking of replacing the fuel filter thinking that it might be the case. I know I should take the car to a mechanic but my regular mech is getting ready to leave the country early next month. So I can't go to him. Any pointers are gladly appreciated. Also on a related note, think it's that time of the year when cars of all type decide to jerk on their own.
  11. Hey Hashan, Nice to hear that you got the timing belt done, albeit at a higher cost than you would've expected. As for the tuneup, I highly recommend Mr. Dhammika Perera. He works from his garage in Borella. Highly recommended. I was expecting to part with at least 12k when I visited him (For sparks plugs, injector cleaning, etc.) But the guy inspected everything, observed that I shouldn't worry about either of these until the next service and fixed my errant idling that has been a worry for a while. All this cost me around 3500 IIRC.
  12. This has been discussed many times over. Use the search. This post has more information and several more links.
  13. Yep. Totally different part.
  14. Think you should get it looked over by a specialist. There are well reputed specialists that won't cost you an arm and a leg. I too feel that it's something to do with the IAC valve since I too have the same issues. Like you, I didn't know what's wrong until I had someone have a look.
  15. Hey Trinity, glad to be of service. Do you have the complete assembly? Despite replacing the bearing, Think I'll feel a bit more safer if I can just replace the complete wheel hub assembly.
  16. Small update on the G. I had to replace the wheel bearing of the rear left wheel and wanted to post the way I did it in the thread in case any other Galant owner has to go through the same process. Please ignore this if you know this already. As a first time owner, the process I went through was a revelation. The part in question looks like this. My car has 4 wheel studs instead of 5 studs. Think that's the case with a majority of brand new Galant imports to Sri Lanka. Now the problem is it's really hard to find the complete assembly. I spent over two complete days trying to find it and my search extended from Delkanda, to Nawinna, Piliyandala, Kohuwala, Moratuwa and Panchi. I was on this wild goose chase because of the rotary wheel looking part. That wheel actuates the ABS sensor and by the looks of it, this wheel doesn't seem replaceable nor removable. I had to call up Unimo to get a quote and it was a wee bit north of 30k for one side. eBay has it from around 30$ onwards but finding the right four stud version was again problematic. Here's the eBay search link At this point I was quite desperate and had to consider other options. An old mechanic introduced to me by one of my friends suggested that I take it to a lathe and get the rotary wheel thingy removed and get the bearing replaced. Since that seemed to be the only option, I tried and bought the correct bearing from C@ntr*l B@*rings in Panchi. There's a lathe guy right across C@ntr*l B@*rings. The guy managed to remove the rotary wheel, removed and replaced the bearing, all in about 10 minutes. The total cost was about 3200. Had to spend around 4k on tuk tuk charges alone but I pretty much went to each and every single shop on the Delkanda stretch. Learnt a bucket load of stuff about the whole car parts business. Found the original spoiler also. If anyone is looking, there's a shop with heaps of original sun visors just beyond the Delkanda junction on the right side when you come from Nugegoda. You'll have to take the car to buy the sun visors. They're clueless about what sun visor goes for what car. I found some seemingly original spoilers for the CK2, Honda Civic EK3, EG8. These were at a nearby shop to the one where I found the sun visors. Spoilers were around 5k each.
  17. Hey Komi, was wondering myself. Glad to know that work is indeed in progress. Hope it's the same case with the Don as well. More power to you both.
  18. <blockquote class='ipsBlockquote'data-author="ShintaroX" data-cid="161757" data-time="1307107663"><p> Also have a good look inside yourself. Maybe it is something stupid like a mechanic has left some small tool inside there after some earlier job.</p></blockquote> Give the above a thought too. I also had a major rattling noise from the front. Checked belts, suspension parts, wheels, ac and nothing was wrong with any of it. Randomly kicked the number plate in frustration at the garage and hey presto, it was a loose bolt in it. The noise was like as if the radiator was going to fall off. Eliminate the simple stuff first.
  19. Welcome to the forum bro. Like you, I've also benefited from the collective wisdom of the wonderful people in this forum. AL is almost like a handbook for me. I've this forum open in two computers and a phone literally 24*7. I've a Galant and I kinda, sorta have similar issues with my car. In my case, it's a bad Throttle Position Sensor and a faulty IACV. Like you, I also thought that there's something wrong with the clutch. I could be wrong, but before anything, eliminate any other factors that doesn't include the transmission. Here's a thread from the forum that you might find helpful.
  20. True that. I do have a parts supplier guy I know. The guy is expensive, reliable and talks the spare parts lingo. I was looking for some body trims once and had no luck. I gave this guy a call and was explaining to him what I needed. Guy listened to me like 7 seconds. Interrupts me and tells me, "Mahattaya Diki patiyakda hoyanne?" Lo and behold, it was indeed a Diki Patiya I was looking for. Pretty much every shop know what that was. Felt like a complete j***a&#036;&#036;. Anyway, would like to talk to your parts supplier too if you don't mind sharing the info. The current one I talk to tend to find stuff from the higher end of the cost spectrum.
  21. Maglites are pretty good for self defence. One reason why I opted for one as well.
  22. Had a similar issue with a flashlight/torch the other day. Accidentally dropped it. The whole lens assembly came off and the lip where the lens assembly fits the body is cracked rendering the bloody thing unusable. Looking to buy a Maglite now. Hope they are still good like they used to be.
  23. Trinity I thought the repair kits are OEM spec. Necessarily stuff you need to carry out a particular repair to restore something to the factory spec. Am I missing something here?
  24. I checked my front right brake pad today. There's a play of about 2 millimetres. I checked the service manual and apparently the G has a shim as opposed to a pin in your CS3. So, have to check the fitment of the pads as well as replace the shims when I go ahead with the repair.
