Push110
Everything posted by Push110
  1. I also search for it in the internet but unable to find it. But I could find the user manual of corolla 141 in toyota owners club. Though it's not fully compatible, some of things are common and can be applied to 260. But there are things which do not comply with it. like activating speed lock, whch i still couldn't do in 260, resetting kmph/kmpl average values etc. I will try to translate the most required things from my japanese catalog. But if you could find, then pls update this thread.
  2. Registered the 260-time to ride :)
  3. Hi, There is no G grade for 110. Available grades something like are from top: SE Saloon Limited (Reveira) : With all options+ additional options like Nickel handles etc, . SE Saloon : With all options XE Saloon Limited : Above - retractable mirrors XE Saloon LX Saloon : Without power shutters etc Some are not fiffed with ABS
  4. Hi, It happened to me once due to (accidently)intechanging the hoses to the reservoir's cap. In that case, whenever there is a pressure builds up in the radiator, water comes our from the reservoir. It was with AE100. Best Regrds, Push
  5. Smells the breez of a Brand new car
  6. I'm not sure about the fault with the system, But I'll explain how it should behave & you may (or may not)guess what has gone wrong. 1. When you lock the car wit security and then you unlock the car using remote, u failed to open a door for a while, then the car is aotomatically locked. (it thinks you have opend in accidentelly). 2 when you have startd moving and then you press the brakes, doors get locked. 3. When you stop the engine,it will unlock all the doors. (but if you have opened a door manully before switch off the engine, ths will not be happened.) 4. If the fuse of your brakes has burnt due to some other reason, or has some loose connecion then the above 2-3 may not functon poperly. 5. If your remote has some bad contct points for the buttons, then it may trigger sials without your knowledge.
  7. Actually mileage is around 110K and the oil also was at the dark red colour, not black. And it was not thickey as well
  8. Hi, I went to Auto M***j to service my AE110 corolla. When they change the ATF (manually), they have first added some additive before removing the used oil. and they ran the engine for 10 min and remove the oil by removing the oil pan & filter. They have added another additive (different formula, same brand )When they put the new oil (Mo**l)to the gear box. Additive were cost me 2500+ each. My queation is is it really need to add additives? In both stages. May be ok to flush. but to mix with new oil? what do they really do? Best Regards, Push
