Nilantha
Everything posted by Nilantha
  1. yes. old website is better than new one
  2. if it is manual gear 11-12kmpl with AC (Colombo city) 14-16kmpl when long run with AC (if you dive Ampara, Bati, Ambilipitiya, Anuradapura via ella new road you can take 17+) if it is auto gear 10kmpl (Colombo city) with AC 14kmpl when long run with AC
  3. Check this out. CE110 come with 2C Engine (2C Molli Engine) i will tel you few steps, if you can get done, you can have smooth, good in fuel, good in power engine. 1. you have to service the injection pump and pressure the Injectors (if injectors bad you have to replace) 2. Adjust the tappet clearance (2C tappet clearances are 0.25mm intake, 0.30mm exhaust when engine is cooled. also remember every bass can't adjust tappet clearance of the 2C engines) 3. replace the Fuel filter with VIC, Union or Genuine, 4. replace the Air filter with VIC, Union or Genuine 5. if you can sure genuine mileage of your engine is 125k just try Toyota Engine oil 10w-30w (for 2C and 3C engines Toyota recommend 10w-30w engine oils.) (keep looking oil level when using 10w-30w. if your engine mileage over 200k you can observe oil burning. if you observed oil burn change the engine oil to 10w-40w Mobil or Castrol) 6. Better use oil filter VIC, Union or genuine. 7. also you have to drain water from the fuel filter every 15,000-20,000km ** when you do Injection pump service you have to go to reputed place. because this Injection pump want to be calibrated properly by experienced person. i will post Toyota recommendations for 2C and 3C engines tomorrow. i have to take pictures from a Toyota Engine.
  4. :sport-smiley-004: :sport-smiley-004:
  5. for 1.6m you can't go for a english number AE110. so better Honda City
  6. yes, Toyota oil is high quality. its come with Made in Japan label. it is 10w-30w if you use that oil for engine have run more than 100,000km you can see little engine oil burning. its because that oil 30w (thin) Toyota oil suitable for new engines.
  7. if you read this topic top to bottom properly you can see who is doing b u ll shit. i gave him advice to protect his engine if he is going to keep his vehicle for long time. it seems you also looks like this service station guys. Mobil XHP is mobils 15W-40W engine oil. yes it can run 5000km if you difficult to find Mobil XHP you can find Castrol 15W-40W (Castrol GTX) or Mobil 15W-40W (Mobil Super1000 but not quality than mobil XHP) for 5000km oil change or Lanka Super DS40 for 3500km oil change personally i not recommend 20W-50W for this vehicle to run 5000km. its too hard for your engine if not mileage more than 200,000km. http://www.alibaba.c...ium_15W_40.html http://www.mitrovich...hp_2007_eng.pdf
  8. if you are going to use your vehicle for next 2 or 3 years better you change. try to find Mobil XHP. its is very good engine oil.
  9. yes, that is the meaning of quality is low.
  10. if your engine in working temperature your oil viscosity rate is 50W so, if your engine mileage 115000km this 50w is bit hardy (not good for your engine). so better you use 15w-40w oil. please note that don't trust service station guys and spare parts shops guys or sales mens. they don't have technical knowledge. if they can keep good profit margin they are selling any low quality goods telling thats the worlds best thing. so they no want to care about others things. they think only about there profit.
  11. I think 50W is bit hardy for your vehicle. better you run around 3000km and change. BTW how is your engine Mileage? if it is over 200,000 no problem 20w 50w
  12. Nilantha replied to lasa's topic in The Lounge
    Try to use Dunlop or Goodyear i think value for money, also brand called Continental also good.
  13. Nilantha replied to lasa's topic in The Lounge
    yes correct. i too agree 100%
  14. i always on fog when drive to night
  15. for me Manual gear vehicle is better. I never buy Auto Gear
  16. yes, i was using Mobil Delvac it can run 5000-6000km. engine also very smooth and low noise. just like petrol engine. but when i change oil after 5500km oil was very dirty and just like Tar. so i decided to change to mono grade because it can change every 3500km. because often oil change engine also very clean. when change oil, oil is not so dark and thick than Mobil Delvac oil when change, one technical guy told me to use this Lanka Super DS40 (Ceyptco) it also giving me smooth running and low noise just like Mobil Delvac. but i know Lanka Super DS is mono grade and Delvac multi grade. Lanka Duper DS40 Rs.2200/3500Km= Rs. 0.62 pr KM Mobil Delvac Rs.3500/5500km = Rs. 0.63 pr KM Not so big money difference. but using Lanka super can keep engine clean because oil change every 3500km (but can run 4000km also, but i change from 3500km)
  17. i was using Castrol And Mobil for my petrol vehicles. now im using LANKA Super DS40 for my CR41 its very good than Caltex DS40 very smooth and low engine Noice price only 2150/- 5L change every 3500km
  18. better check from edirisinghe. they have much exprience
  19. tray to do head check from Edirisinghe brothers
  20. i think better you replace gasket and replace all oil seal and tappet cover seal. also better you check timming belt and timing belt adjusters also better you check plug wire set.
  21. if you have diesel injection pump with RPM sensor you can fix. i am too trying to do that. check whether you have Injection pump with RPM sensor
  22. yes i mention here 250,000km minimum with proper oil and filter change
