mnaka
  • Location
    Sri Lanka
  • Interests
    Vee Dub bugs, mitsubishis, Land Rovers, minis
mnaka's Achievements
  1. Thank you Rumesh very informative, i will try it, and yes protractor template thing has to be done first, thanks again for the time taken to explain/write this all
  2. Yeah thats a great idea Rumesh, maybe ill give it a shot, btw what is this method called? so i can read more regarding this before approaching it right? and this is the same method used for static timing right?
  3. Just for diy jobs RUMESH
  4. Hi guys ive searched the forum but coudnt find a answer, im looking for a dwell meter and a timing light combo to buy, does anyone got any leads? thanks
  5. The baffles in the tail pipes makes the whistle sound, typically, only the ones with loose baffles will whistle, original factory tailpipes actually had fiberglass packing inside them and when time goes this packing will get distorted then again the whistle appears, remove your tail pipes and see the sound difference
  6. mnaka
    Volkswagen
    I think he is talking about a New Beetle
  7. Thanks Sylvi
  8. I think you are talking about the oil pressure gauge im talking about fuel pressure gauge which connects to the fuel pump actually petrol type 1 to 5 psi i think
  9. Do any one knows a exact place and the rough price to buy a fuel pressure gauge - Thanks
  10. Check the head gasket
  11. Or you could use LM123 3amps, 5v regulator same as 7805 http://www.national.com/opf/LM/LM123.html
  12. You could use an ampere meter and multiply the value from voltage
  13. Yes 'Dinuk' 7805 regulator is rated to give 1A output so the output must less than 1 amps
  14. 36mm if early style, 46mm if later style(68 and newer)
