Everything posted by Nissan cdj
Wiper Blades Slip
Thanks for the opinion JC. I think I have done a modification to driving side wiper stocks should be 17 if i am not mistaken and now i have 21 inch in drivers side but even in my earlier set it was 21 inch driver side and it worked much better. AS U THINK DO I NEED TO CHANGE IT TO STOCK 17 inch. It seemed original Bosch as the Logo was embossed in the wiper and the Agents D*MO hologram was there in the packaging. When i was reaching home Just a hour ago I went to see the motor shop salesman. I told him the scenario and he checked it he told me since the old ones are worn out u may have seen it working perfectly this ill. e fine two three days later not to worry and so on and the other thing he mentioned was Windscreen should be soapy therefore he told me to put up the windscreen washer liquid (50 ml bottle) which was given free with the purchase into the reservoir and see everything would be fine. so i could do so and tell you the result BTW told that your set seemed to be okay after two three days yeah.
Wiper Blades Slip
Thnxx for you quick respose Komi. actually motor was serviced recently and as u said there's no play in the arms, could not rotate either way you said and when the wipers are all down when i try to push it up the mimic from the other wiper could be seen and it doesn't move further. so therefore i guess there's nothing wrong with the motor and arms as i have not.met with an accident in the front end. by the way it seems someother issue yeah apart from the motor, arms & the play what should be the problem since the previous. set worked very well & you know the motor works very well.
Wiper Blades Slip
Hey Guys, Yesterday I replaced Both the Wiper Blades with Bosch Eco Plus of my van Nissan vanette c22 1993 as earlier set of blades gave me a squeaking sound most of the times But it was wiping well & very smooth on the Glass though. I replaced it with the same sizes existed with Bosch Eco Plus as Driving side - 21 inch & Passenger side - 17 inch. Now the issue with these new set of blades is its not very smooth on the windscreen I mean its kind of slipping when its moving up and down its not moving easily sometimes both the wipers stuck in the middle in a place where the wiper motor couldnt push it. But when i use the wipers with the washer its okay upto some extent but still its slipping. Its like when water is not there on the glass it tends to slip and stop in the middle with the motor on. So that i have to again press washer to get back the wipers back into their position. Though the Previous set of wipers were chinese ones, they were moving freely, wiping well though there was no water on the glass., Not slipping and therefore it was very smooth but theonly thing made me to change those was the squeaking sound. By the way these new set of Bosch Blades are grave when compared with my previous set of chinese blades. Actually chinese ones seemed to be very simple and light weight. Hope this would not be the problem though. So my issues with these new set of blades are 1) What should I do to make these blades move freely on the windscreen ? 2) Why do the wipers get stuck in the middle unlike the previous ones ? 3) Since they are new will it get used to move freely like the previous ones by two three days later ? I hope that some of you guys may have experienced same issue with the replacement and may have had solved the issue. So looking forward to Solve My issue as well. Thanks in Advance. Nissan Cdj
Findout The Colour Code ????
Finally I found the color code it's 514G (greenish ash)
- Steering Rack Oil Leak
CefiroA33, as the above reply said nissan may hv same model of ppwer raxks in different nissan vehicles therefore put more concern on model if ur replacing by the way in nissans repairing using repair kit would not be the cure.once in a bluemoon repairing will be success but in case of nisssan best option is to replace the rack
Relaying Headlights
I used. female clips but then my autp electrician said that since its risky using fmale clips its better to use the original socket which was given with the relays.so i asked hI'm wether there will be any. voltage drops due to twisting the socket end wires he said no therefore i used the original socket. though he said there's no voltage drops I am doubt so as u knw will there be any voltage drops ? Thanks in advance
H3 Fog Light Bulbs
1)What are the best brand of 100 w fog lamp bulbs which gives a high visibility and durabilty ? 2)And the other thing is how is h3 led bulbs )26 smd led ) are they better than halogen h3 or not 3) what are yellow coated (3000k) h3 bulbs ? Need experiences of u expertise thanking u Nissan cdj
Relaying Headlights
And the other thing i want to know is what are the bulbs that are listed on ebay as h4 xenon halogens ? Is it a must to solder the wires that are connected to the rexondition nissan relay socket i meant isnt it enoght just twisting the relay socket wires with the direct battery wires and output wires of the relay ?
- Relaying Headlights
Relaying Headlights
I myself did the the job perfectly and i am happy about it but there was only little more emit of light brigtness even after relaying anyways now i am up to change my 60/55 w bulbs to 100/90 w so what are the bulb brands u recommand as an expert or experienced motorist thnx in advance Mr Sylvi
Relaying Headlights
is it okay if i do the relaying job of my headlights on my own since i am jobless these days.i wanna knw 1 will this increase the brightness of my headlights as electritions say ? 2 whts the best method to do this do i need to have a full wiring from the battery or just two relays for the existing wiring (for the original wire harness) 3 and whts the guge of the wire thst i should use for this and the type of relays is there specific relays for this or just 4 pin relay which we can buib from recondition part shops 4 where do i have to get the positive wire i meant from the battery or alternator ? 5 and what are the things that i should consider before doing this and while doing this ? 6 the other thing is longer the wire, the more the resistance. Therefore how to shorter the wiring to get more power sorry if i am wrong u expetise are welcome and appreciate ur advices / comments on this Thanx in advance
- Corolla Ce110 - Find Model By Chassis Number
Buying A Vehicle For 2.4 Mil
Fuel consumption CR41 2C engine 8~10 city limits with dual a/c and 10~12 outstation
Heating Issue
<blockquote class='ipsBlockquote'data-author="harshansenadhir" data-cid="247222" data-time="1378820974"><p> <br /> once I've experienced following with a friend's allion. Car stalled and he thought the battery is weak and asked for my help for a jump start. But when the engine was running I heard typical signs of overheating (engine was under stress and even ignition knock could be heard) still the gauge was at middle point perfectly. Checked the water level to see it was empty and as we added water, it boiled and lots of steam came out before it settled down. which means even to steam there were no water earlier. when there were water in the system, the gauge showed temp.<br /> <br /> lesson to learn, study the type of the sensor you got (whether it's sending temperature from the block or from water) if it's from water, then if there's no water for the sensor to "sense" the temperature, reading will be inaccurate.</p></blockquote>as u guys know how this is related to nissan vanettec22 LD20 engine. this engine indicate temp from its engine bay or from the water whic radiator holds ?
Interior Cleaning Is Good Or Bad
Crosswind u mean dash isn't good da ?
Jaliya its upholstery ans carpet cleaner it has been stated in the bottle as tht
Wht do u ppl think about dash uphostery cleaner spray ? is it good and does it has the power to do the job
Thnxxx for the reply crosswind my seats doesn't hv much dirt to be seen but when i hit the sit it will emit more dust wht should i do to remove the dust inside the seat sponge i don't have a vaccume too and then wull somehow i removed the dust and then is it okay using dash upholstery cleaner if. i am using dash how is the procedure thnxx crosswind
Car Airfreshner
And air wick is worth for the money we pay rytit was just Rs 95 /= 4 months ago and now its 105/=
Car Airfreshner
What about air wick gel and liquid (spray) air freshner ?
Car Airfreshner
Today i went to arpico super center to buy some automotive products.so i found so many air freshners in various flavours and designs and therefore tht voided my choice too.there were poppy (grace mate) ambipur and sonny car airfresh thnx in advancener which clips to the a/c vent etc. so i would like to hv a survey on this as which is worth for the money we spend and which long lasts and which is more reliable and give out more fragrance. so it would be appreciated if u share ur experience on car air freshners in this forum considering the points i hv mentioned above thnx in advance
