whmsujith
Everything posted by whmsujith
Problem was with tails lights, due to the aging of the car there had not been any proper earthing. Separate earth wires were fixed to car body and now ok.
Hi Guys, I am experiencing same thing in wife's car March AK12 from yesterday as reverse gear "beep beep" sound coming when applying breaks. I was told by a friend that there is unit in the gearbox which gets a signal when applying breaks and put gear box into neutral mode, now it erroneously recognizes it has reverse signal. Is it true? Last month service done at Pitstop Negombo and by there was no issue in the break pads and only driven 1000km from then. Also, After seen @CAMANpost I will check that as right hand rear break light having a crack for last 5 years
I am not sure dude, just do it and see or when things gets back to normal show it to a good auto electrician and see.
I had the same issue in my car, but I didn't see any light coming in the setup. Only 2 days I could park the car, battery was draining out. I took the car to TL and they found that set up was the culprit as it was drawing a small current. Since it was after market fixture they refused to repair it and instead did some changes so that I could on the set up only after car engine starts. So, I had to tune up radio every morning and ran like about one week and fixed a new setup. Problem solved.
Atlantic Ref Engineers, Kadolkae Road, Negombo (road parallel to railway line)
Ok, Thanks. Sounds good.
Is this only a black and white and what would be initial cost? regretting not having a printer at home these days as no place to take a print out
removed
Can 6 people ride in an allion or premio
whmsujith replied to hustlehard's topic in General Automotive
Don't do that. This is one incident as IRage mentioned, a Premio with 9 on board.. http://www.ft.lk/news/6-killed--3-injured-in-accident-in-Wennappuwa/56-671270- 35 replies
- 6 people in a car
- 6 people in a sedan
(and 3 more)
Checked at agents in Negombo, nothing wrong with the fuse. Motor had stopped working due to not frequently being used, they said. Now it's ok, but I was asked checked the motor, if again same thin happens.
Hi Guys, My Premio's rear wiper stopped mid way in cycle and now it is not working at all. Can anybody help me regarding this? Thanks
There are Vietnam made once as well. I thnik they are not good as Korean once.
I think when you pump full tank, it will get reset automatically
- 5 replies
- 1
- toyota
- premio 260
(and 1 more)
Yes, after seen this, only ran about 2 km from home to garage Tuesday evening. it will be fixed today tomorrow. I am afraid, I don't have time to be in the garage when the repair is going on, only telephonic conversations with the mechanic.
I am going to fill it with caltex green clour, I think it is the correct one.
Premad, The Stig, thanks both of you. I will get it fixed soon.
Hi Friends, I have a serious issue in my wife's car as last weekend I suddenly saw some dampness in the driver side cabin floor and found that it's coolant. Car is March AK 12 and 6 months ago there was a heating issue. Fault was that the fan was not working in required speed and replaced the fan motor and Full radiator clean up was done also. Then the problem was fixed. Car is not being used much wife drives about 200km per month mostly on weekends. Please help me to figure out the problem mates, Thanks.
That's great! By the way what is your English Letters? Is it K series or CA series?
Please check with them again, whether they really posted it. Like Crosswind mentioned above, it's hard to believe that it misplaces during post.
Hi firstgear, When did you handover the docs to RMV for transfer? Was it in January 2017? I just called to one of my friends works in RMV to check my wife's car transfer and according to him, RMV nowadays printing January ones. I submitted my Docs toward end of February, So I have to wait at least another one month.
Ok, thanks a lot Rumesh
Yes, Checked it,there is no damage Or leaks found. Noted with thanks. I will get installed one soon. Where can I find a original one from?
Didn't have any time till today for attend this. Took her to radiator repair shop and checked. Both of you were correct, fan was the issue, replaced the fan motor with recon one. In the process cleaned the radiator as well, there was clogging inside. Ran about 25 kms with AC on, so far no issue. By the way technician told that previous owner has removed thermostat valve, is it to run without this? Pls advise. Thanks.
Yes, since it was used by a lady most of the time it had been idle since it has been registered with KM plates in Dec 2010 with ODO is 19k as she said. All the service records were available but only major services like full services. I will check the color and let you know tomorrow; now I am far away.
Ok, I also thought so. AC works normally at idle, but anyway the coolness of the airflow is not enough like in my other cars, is it also related to this issue?
