mkindika
Everything posted by mkindika
I have replaced ECU. No CEL error codes and air flow sensor and throttle body are new ones. But I used old 2 injectors because new ones were broken. Thanks for help.
I had another issues too and I got new engine for a reasonable price. I will check these things with mechanic and let you know. Thanks for help.
Hi Davy, I swapped the engine. Why still I get this issue in new engine also?
Yes, I changed Distributor also finally swapped the engine too. I am going to check fuel pump and tank as said by MasterDon. Thanks mcn.
Thanks for your input. I aslo feel like same as you. I will get check the fuel tank and pump.
My car is EG8 Vtec one. The problem i'm having is, as soon as I hit the gas padel, it kinda boggs until it hits 2500 rpm's (+/- a couple hundred) then it picks up and runs strong. I cannot drive in traffic when the problem exists. Not all the time I see this problem and engine's heat or cold makes no difference. No misfire when I run on highway or accelating and stopped(In neutral) the car. No check engine light and no CEL error codes. I have changed the Dizzy and spark plugs,ECU, fuel filter and checked the timing. Finally swap the engine too with new reconditioned one. But I still have the problem. I have spent more than 2lakh by now. I am going to check injectos bocz I used 2 from old engine, fuel pump again. Your help is highly appreciate.
Hi guys, I am in a need of EG8 vtec distributor. I thought ignition coil was bad and bought a new one. But actually CMP sensor is fault. If you have got a removed distributor(most probably due bad coil), please let me know. I only need the housing with CMP sensor. Regards, Indika.
Hello...... I need HONDA CIVIC EG8 VTEC Solenoid Valve. If you have or a place to buy please let me know. Thanks.
Hello Sylvi, Thanks for your response. It s 93 vtec civic eg8. The problem started with a little miss. When I full throttle the engine stops suddenly. I can start running with low speed. When the engine heated ,then I can accelerate the engine.One day I was unable to even starts the car. It was seemed to be a fuel problem . Fuel system was cleaned. There were no issues with fuel. So the mechanic told me the current of the spark plugs was too law. So we change the whole distributor. I could only drive one week only. Now it happening again.
I had a problem with my distributor. I replaced with a recondition distributor for 16 000.00. I drove one week with pleasure. But now the problem comes again. It is difficult to start my eg8. When I throttle it stops. what to to. Any help would be greatly appreciate.
Oh my god.... I had a problem with my distributor. I replaced with a recondition distributor for 16 000.00. I drove one week with pleasure. But now the problem comes again. It is difficult to start my eg8. When I throttle it stops. what to to. Any help would be greatly appreciate.
hi guys, I am going to replace my front bumper.If you know place to buy eg8 front bumper with fog lights and lip kit please let me know. Thanks.
Thanks Guys.. I am going to bid for headlights.Thanks all helped me. Regards..
Dear all, Thanks everybody for sharing your experience.Headlight costs about LKR 30000.00. How much will I have to pay as tax? Thanks.
Hi guys, I am going to importing headlights from ebay. I need to know whether I should pay tax.You may have some experience. Good luck.
I have the same problem.It is said that throttle body or fuel filter.I dont know the what the problem exactly is.
Thanks Kelum. I had no idea about it. Thanks for your advice. I will go for it.
thanks CyRax. I got to know that there are some nice shops around Delkanda. I will check there.
thanks nexus . I checked there but shipping cost was too expensive.
Hi guys, I am looking for eg8 angel lights. Can anyone tell me where to buy ? Thanks.
