Peugeot 504 Restore
sadly it was a 1C engine but everything else was (even the clutch slave pump) I've reverted back to original. I was at the verge of re-fitting it with a 2L twin carb petrol engine. Bought an engine, overhauled completely and restored that engine to pristine condition with thermal paint on the block to have the original look of the engine. Couldn't complete the project and had sold all except that engine which is still with the mechanic, I don't know the current state of that engine even. A closed chapter that is. 504 is no more manufactured. It has been manufactured in Iran till mid 90's or so, in argentina till about 99, in Kenya and Nigeria till about 2008. The last manufactured 504 has been donated to Peugeot museum at Sochaux. here is a picture of the last 504 to be ever built and the production line ran for 40+ years (starting from 1968) You should take out a 2 litr twin carb and compare the power, stability, comfort all in one. The sooner you kick down the throttle you'll hear the wheezing sound of the engine and it lifts the 'nose' up and reaching 140 is nothing at all.
Peugeot 406 Or Corolla 121
Seems my intended reply has been given by many in different form. I wonder these fan boys would get the message. Expensive to maintain, yeah right. Compared to the junk/used spares, YES by all means, maintaining Euros is expensive. Comment after checking the prices from agents or genuine stuff, not thaiwan after-markets or junk spares please. I bought the genuine starter motor brand new for 24,000/- with 06 months warranty now beat it.
Peugeot 504 Restore
I see, so there are a lot of 504 fans around eh? I thought I was only one of handful. To answer your questions, nope mine wasn't original diesel, the previous owner had converted it without swapping the gearbox (if you convert with swapping the gearbox, it's worthwhile to dump the car). The market value is entirely depend on the condition and how originality is kept and preserved, so anything between 50,000 to 1 mil is possible. I know of a 504 GR which has got offers more than 9.50 and he's not willing to sell it. Original diesels runs solid even in USA they used to batter them using vegi oil and still they runs fine to the date without re-builds. Only issue is the excessive sound and rough start. No matter how good the engine is, the starting is rough and requires some cranking, but once fire up it'll run even with cracked pistons, leaky gaskets (again battered examples from around the world). parts for original diesel peugeots wasn't and isn't an issue as long as Mahindra diesels are around. The engine of the maxi truck is similar to the Peugeot diesel and some components including the pump, pistons, some bearings can be inter-changeable. The engine of the old mahindra jeep is exactly the same engine (Indenor diesel) came in 504 Diesel version. will keep you posted about a good tinker fellow, apparently a 'golaya' fellow is there but he's a full time employee of peugeot agents as yet.
Peugeot 504 Restore
Oh my oh my, before even reading the rest of your reply tell me what color this car your dad used in dcsl? Is it a 12 sri numbered black one? If yes, no doubt it's the GR i had and restored. Because, the previous owner had bought it from dcsl auction he said and it was very handful of the 504s in sl with original factory fitted a/c.
Peugeot 504 Restore
Great to hear that you finally took it for a spin. Quick things you can do are, repair the front shock absorbers as they're repairable and a front overall bush kit (it was 2750/-) when I last changed them about 4 years back. Also in GL there are rear CV joints and axles. Check for quality of them and repair or grease pack if required if grease is bad and if dust/mud trapped inside, you'll destroy them soon. So better check these. Do an overall fluid change, the brake, transmission the diff and grease pack (at a service station) following. The front ball joints (this is not possible in GR but in GL you can) and tie rod ends, Torque tube (where the drive shaft is hidden in, this tube starts from the tail end of the gearbox and goes to differential box which is mounted on to the body) Steering rack. (Also if possible, take the steering rack out and check the quality of the rack piston. Replacing with a brand new piston would cost you about 800 rupees and it's well worth it. You can disregard if the rack is smooth and rattle free. Best thing of this generation french cars is almost all spares are repairable even front shock absorbers!!. Optionally you can take the lights out and clean the lenses and reflectors. I used to split them and clean them and re-fix using silicone adhesive. take out the panel just behind the hood (bonnet) and observe for any bottlenecks in water draining lines. There's a one in the middle and two at each sides. Usually leaves and other small particles blocks these drain lines and water tend to accumulate. This can result in excessive corrosions, so better be cautious. Clean this area with a pressurized air and apply some WD40. However, if you have any plans to do body work in the future, you can do it at that time. Don't forget the rims. Take them out, remove tires and see how bad it's corroded. I don't think it's feasible now to spend for a brand new set of rims as back in 2005 one cost me about 6500/-. You can try to restore the rims and even make them tubeless!!. This I've done with the 504 (L) (maroon color one in the pictures) I had. Tinker guy repaired them with small metal pieces and one leaking spot has been identified on the side wall of the rim where it cannot be welded. Used brass welding and filled that small hole and grinded and smoothed. Only burden is each rim you have to fit a tubeless tire (a test tire I've used) and check for leaks and then redo tinker work. All these are options depending on the level of restoration you wish to dive into. Don't think I'm making them mandatory or such. Awaiting for more porn
Peugeot 504 Restore
@jd - true that and i prefer these threads over fuel consumption shit at any cost. awaiting for more pics i mean porn from the op. @don - now its not that easy to find quality and humble workmen who does a job which worth the price they ask for. This guy was an exception and i'm getting paint work done by him to the date. Only issue is he can't take tinker work any more as he had underwent an open heart surgery, so meddling with metal is no more feasible for him like the good old days. Yeah, you're spot on about letting them go. But in life you always have to choose, so did i and sometimes i regret this decision. Will try to do it again when i can shift my priorities back to vehicles, i mean financially. So your father too had a 504? Yes, and i admit it's more comfy than the 406 for some reason. Remember, this statement is backed by my mother in law. So it has to be 200% accurate.
Civic Hybrid
why? Because we got lots and lots of penny wise people around. They don't know the fact that they've become penny wise by being pound foolish. The opportunity cost of the huge 'investments' on some fuel efficient vehicles cannot justify by the fuel saving figures if you calculate and compare.
Peugeot 504 Restore
don't worry on the look of the facia panel, a good tinker would be able to sort it out in no time. I've sold all three 504s i had as maintaining them were becoming an issue as old generation peugeot mechanics and tinkers were hard to find. The guy who did the restoration gave up on corrosion repairs as it wasn't that profitable and during the last couple of days of my project he got a heart attack and had gone through a surgery too. So i couldn't complete the next GR which was awaiting its restoration and i slowly decided to let go of them my beauties. You better take the dash off as in GL it's a metal dash board which has a crash pad fixed on to it. So it should be rust proofed. This picture is of the glove box and i think you should be able to repair it. If not, try bmc 'watta' in panchikawatta. You should be able to source a one in fair or better condition than this.
Peugeot 504 Restore
took it home after more than a year .. still the seats needed fitting as I was yet to receive the new seat covers, all done in white color. This was the day before the wedding day and was quite happy to complete (almost) the project on time. again, took it back to the service station to do complete fluid change and a service as it was stationed for more than a year. enjoying sun rise after more than a year... note the re-done door upholstery .. new tires, new rims and new hub caps.. another view .. look at the grand view almost brand new 504.. taking a break on a weekend .. This was my daily ride until it was replaced by the 406.. was a superb and a solid ride.
Peugeot 504 Restore
lot of hard work has done and it recieved multiple base coats before a high quality body filler has been sprayed. and the final filler coat has been sprayed. I was very pleased with the shape it was getting and was impatient to see it in the final coat. and now, the car is being receiving the final coat. 2k paint, debeer paint and Dupont lacquer was that. little expensive but results were just beyond my expectations.
Peugeot 504 Restore
this donor car gave lots of nickel bits and pieces and a door frame. Nothing left in solid metal in this otherwise. bought a load of junk from an old 504 enthusiast and these were very useful when I was fitting the car back throughout mid nights and needless to say I was just couple of days behind the big day.
Peugeot 504 Restore
post #2 due to image limitations.. the dash boards and interior were completely removed. All four doors were taken off from the body and windshields were removed after sometime and it was removed together with the beadings and metal bits and pieces. I didn't remove the hood upholstery as I didn't want to damage in trying to remove and re-fitting. the rear panels are being treated. The left rear panel and the wheel arch were horror stories to look at even. Culprit is the fuel tank as it holds some mud and dirt between the inner rear panel and the tank itself. This was a usual place of 504's to get rusted. Rather than welding small pieces I wanted them to do the complete panel. They used cardboard templates and the images I've provided in preparing this to get a close original finish. rear left panel has been fixed and body filler applied. a Big relief. the right side wasn't an issue at all. Some minor work was sufficient. the rear facia panel
Peugeot 504 Restore
Got some breathing space during weekend and thought of compiling all restoration pictures I had for the betterment of other people whom are into restorations now. There were more pictures but cannot access them from here, so bear with limited pictures but I'll try my level best to cover as much as possible. This is how it looked before the restoration. Rust cannot be seen from this picture, but the wheel arches, sills and floor boards were attacked by rust. The paint was not in good condition and I wanted to re-paint it in white to use as my wedding car. Uploaded with ImageShack.us This is how it's started. The facia panel has been removed and is a must if you're planning to do a better job on a 504 as lot of mud and dirt used to trap inside and can result in corroding the body. Uploaded with ImageShack.us another view of facia panel removed. Some rust were already treated and anti-corrosive paint has been applied. That was my rule of thumb to them. That is to apply anti-corrosive as soon as a welding job has been completed. Uploaded with ImageShack.us floor boards getting replaced. Note the steel rods welded to the pillars to prevent mis aligning the pillars due to removed floor board and the sills. Note the complete sill assembly were cutted off. Uploaded with ImageShack.us now it's got new sills. Complete sills assembled outside and finally fixed to the car. It fitted so well and the efforts were well paied off. Note the new sills in brand new metal color. I used 18 gauge original metal sheet throughout the restoration to ensure original rigidness of this body. some more views after sills were fitted.
Peugeot 504 Restore
difference in the facia panel is due to some work done on it and how lights are fixed. Study some pictures on the sites i've given. You yourself would be able to judge and advise the tinkers. I got close ups of wheel arches, light surroundings, etc printed in large size and gave them to refer. Will publish some pics today if time permits.
Never was an issue for me in the ownership of more than 4 years. I've never bought from agents except couple of sensors and some small bits and pieces which other suppliers in panchikawatta don't store. There are about 5 players in Panchikawatta and Colombo except agents whom bring down and store spare parts and body parts. Apart from them, there are individuals whom bring down spares and body parts time to time. If not for all of them, there are few guys whom are frequenting between Colombo and Singapore and they do supply spares within a matter of 2 days. The most expensive part I've replaced in last year was the Starter motor and it was a half a day job.
Peugeot 504 Restore
thumbs up for the great work you'll have started and pm me if you need any help in this. I've restored a GR back in 2004 and project ended in early 2006 making it's my wedding car. My flickr page got some pics of the restored ones but I haven't shared any restoration pictures which I will do in this thread as time permits. Your car is an example of face lifted/post '74 GL AKA clip model which got rear drum brakes and padded steering, etc. Good to see it's interior bits are well preserved but rust got attacked the rear windscreen frame and rear wheel arches from what I've seen on pictures. You can take the windows off and treat rust but don't take off the nickel bits on the windscreen beeding. Pop it out as one piece and fix-in also the same way, or else you won't be able to put it back without damaging the nickel parts. further, the face of this car doesn't have the original look, probably due to the fact that someone later might've messed with it. Download some images from web and ever refer to my pictures, you would be able to see what original light surrounding and facia panel should looks like. Some great sites I've obtained info, catalogues and pictures are listed below if it helps. The later got pics of my car before restoration. (http://www.garage24.net/504ww27.htm). Good luck for your project. www.504.org www.garage24.net
If you ask me whether is it worth the additional 1 million, I would say no straight. Invest that 1 mil on some real investment rather than "investing" on a car like some people advises and "use" the vehicle. Compared to junk spares you find in Delkanda, maintaining a 406 is expensive but if you compare the prices of original/high quality spares then there's not much of a difference between maintenance costs of a 121 and a 406. I can't exactly tell you how much your annual maintenance cost would be, as it depends on lot of parameters. if you need mine for the 2009-2010, it was around 100k Starter motor(brand new valeo with warranty) - 24,000 Gear links - 8,000 Front lower arm bushes - 2,750 each Set of Tires - 37,000 about 4 services (oil + filter) - 17,600 air cleaner - 1,200
repost
Toyota Prius
down-hills would've been useful in re-charging the battery and keeping it in good health.. hmm
Vehicle Numbers
29 and 30 for motor coaches
Fuel Consumption Comparison
so you replied to 4 and a half year old post.
Magcity Service Sucks
i've reasoned out that, it wasn't a car, a land master.
the land masters got a driving belt which transfers power from ply wheel to transfer case. Must be that. Otherwise i don't know of any fan belt which moves a car, or it must be mag city "experts" reasoning he posted here
Toyota Prius
two thumbs up!! Should try an outstation ride and see the difference as well.. This should be a later model of 405 coz very rarely it came to SL with air bags and the options you've mentioned.
How To Restore Your Headlights
lens getting oxidated? I'm not quire sure what this question is and it should be reflector as oppose to lens I guess. However, as per my knowledge, two things can happen. The lens will discoloured due to exposing to UV and the reflectors can be oxidated if it's made out of metal and chrome plated. It won't oxidated if it's plated on plastic. Oxidation can happen if the seals are broken and water, moisture get into the light, that is if the reflector is made out of metal. If the reflector is plastic, the discolouration or fading, melting can happen due to high wattage bulbs and low quality reflectors found in cheap substitutes.
