harshansenadhir
  1. it all depends on how deep you were on floods and thought of all possibilities. However, certain things like CV, steering rack need to be checked fast. The more you run the more it damages. Took few hours last weekend and gave a thorough check up and exterior and interior clean up including wheel arches thinking the rains are gone. To my horror it's just started again.
  2. saw this on one of UK forums yet applicable. I'll buy one if someone manages to come up with the sinhalese version with some added filth. ..
  3. well, factory tint cannot escape if the vehicle is unregistered. I saw a small article in weekend papers that vehicle importers had been asked to replace all tinted glasses with plain and no registration till then. They've made a statement saying this will incur an additional 100k per vehicle approximately. This is absurd for a country which had gone through war and started enjoying peace. I doubt these guys wants public to be in wartime mindset, rather i can't see any rationale about this tint law. As someone pointed out if we can focus about the drops of fuel we can save around the country by running with tints.
  4. there's nothing do with the electronics and any petrol car even the first invented ones had spark plugs and distributor, ignition coil which hates to work with water. Also his logic of engine will run on controlled temperature under water fails if the thermostat (heat operated and allows water inside engine block to flow towards radiator at a certain temperature, no electronic hanky panky) presense.
  5. done the needfull, check whether info provided are usefull. I'm sure others would contribute based on the experience.
  6. Creaking noice could be due to wet auxiliary belts. check out engine oil, gearbox oil for color changes and if possible give entire engine room a good high pressure air clean available at most of service joints. pay more attention to coil pack, relay boxes and any wire connectors inside the loom. If contaminated with water, spray a good contact cleaner and apply a drop or two of engine oil to prevent further corroding/oxidization. check CV boots and rack boots for possible mud/water inside. if contaminated with water, remove, clean and grease pack again. sills and some hollow spaces on underbody may catch up and holds water. check thoroughly and if available remove the drain plugs. If not drill the sills out (exactly what I did) and let trapped water flows out. Then spray some oil inside for further protection. I'm sure brands like 3M and Wurth may have some protection chemicals if you really want to try.
  7. harshansenadhir replied to kamalabc's topic in MAZDA
    did you check the fuse for low beam before hunting for the relay?. most of japanese cars has the relay box for lights and auxiliary fans located inside the engine bay
  8. well, from what i know about that model, that's not suitable to run on any country. even a small repair, diesel pump adjustment or something like that demands removing front seats and then the panel under seats. T belts are on both the sides of the engine. Yes, two of them. Require to take the engine out. Mechanics don't like these and always charge you double the price.
  9. congrats on your new purchase. Eastetically designed stuff. Take very good care of her.
  10. also i bought crystal head lights of D9 used stuff, 8k per light. Taiwan aftermarket brand new head light 14k per light. Genuine valeo 24k per light. Now compare that too with jap. We should stop this ot now or else i won't be able to get a good euro at a reasonable price as my next buy.
  11. you said it right, dubai locals buy euro and us muscle cars. Immigrants who lives in dubai buys japanese eh?
  12. a complete door for 406 goes at the rate of 35k to 40k. I heard its the same for a 121
  13. and there's a myth euro parts are expensive, may be when it comes to body parts. But they compare the used spare price of jap and brand new part of euro. I replaced the starter motor of 406 paying 24k with six months warranty, yes a brand new valeo one. I'm sure a brand new starter motor of a 121 from toyota lanka would be more expensive than that.
  14. most expensive bmw benz used by hummer. Hows that?
  15. this explains two things. Firstly, your chana doesn't have the thermostat valve and you've removed it just like another maka baas. Secondly, your fan belt trick and engine temperature will be under control when the sump is under water is subjected to having thermostat valve. So while removing the fan belt, one should remove thermostat valve as well. But then again only if someone manage to time travel back to '80s. Mr wijesinghe, there are some of your past experience which may be not relevant to todays context. Why don't you open up a blog to write down those fond memories rather than going OT in every forum reply. I'm sure you know what a blog is provided that you spend 6 hours on internet and spend mere half of it to update the blog.
  16. if you can manage to split the lense and the light cover, there's a place they do chrome on plastics. Found the place thanks to master don and definitely can recommend to someone else. Located in wattala Jeyadan electro plate 0717757547.
  17. sri lankans are generally risk averse, same applies to car market. I second vvti's comment on maintenance. Only disadvantage is we don't have junk spares. Still i'm ok with it coz i replace with new spares means they'll last a lifetime. Ehem, well literally.
  18. You would be able to source a good 406 Executive package for that price (fully loaded with electric heated leather seats with memory/profiling, dual mode sun roof, head light washers, auto wipers, auto rear view mirrors, trip computer and cruise control, built in car stereo with boot mounted CD changer with all around JBL speakers, alloys) and lots of bells and whistles.
  19. me thinks that you haven't noticed the irony in my post
  20. means to say cooling oil is sufficient to avoid overheating? if so manufacturers would've fitted oil coolers instead of radiators and complex water lines inside the engine block.
  21. this explains why motor boat engines doesn't have cooling fans or fan belts..
  22. you beat me to it mate, decided to put it here on the same thread as soon as I received it in the morning. Thumbs up for this cop and there were plenty of helping cops on the road in this morning, not to mention there were ones nicely stayed under shelters giving up the job.
