Everything posted by Hoonigan
- Up Sizing Tyres - Pros And Cons
Autolanka Funniest Moments
Wait, what?? Did the Civic drivers know they were racing?
Cool Ebay Gadgets For Cars
Watchman is right, better to use a synthetic chamois leather to dry off. Can picked up at an Arpico for around 500 IIRC
Bonnet Paint - Black
Race Inspired Cosmetic Enhancement I think it's a play on carbon fiber panels as well. There seems to be quite a few cars rocking different colour panels these days I do have to say, some carry it quite well. Boils down to what looks right for the owner. OP, I think, the sticker (or vinyl wrap) path would be the way to go. You can test how the cops react and will be an easy fix if you get into trouble. Also, it will give you some time to see if you really like how it looks after sometime and won't be as expensive to roll back if you don't like it anymore.
What Is The Best Bang For The Buck Used Vehicle, For Any Price Range?
Euro diesels do get great mileage because they were engineered to do so appeal to fleet managers and meet combimed emissions requirements. Whhat do you mean by gas guzzlers exactly? Other than the 3lt+ or so specimens which are more performance oriented? Why I ask is because I get 7 to 8 in city out of a 2ltr 4 banger which is what some 1.6-1.8lt japs get.
Project Capri
Installed the glasses today. Instead of using the original/traditional beadings, we 'pasted' the glasses on. The process still involves beadings but very low profile. I think it turned out pretty sleek. Got the wheels back too. I initially wanted to have the centres copper plated but couldn't find someone who would undertake the job and decided to paint them in a colour that is close enough to my eye. The lips were buffed to a polish. Wiring is beeing done, mostly done, hope to wrap it up early next week. Battery was relocated to the boot due to lack of space at the front. Have a bunch of little stuff to do before upholstery work. Dusted off little bits and pieces collected over the last three years to finally go on the car.
What about Mazdas?
They are reusable and if I'm not mistaken, they come with a lifetime warranty. But I'm with tiv. I was thinking of getting a drop in and was reading some forums and there were numerous cases of people having MAP/MAF sensors going bad. So stuck with OEM Oversimplified, the higher flow they promise has to be obtained by relaxing the filtration, ie, letting more particles pass through. This will lead to engine wear.
- Fuel Efficiency
- Most Economical Petrol Car In Sri Lanka
If the thread is to more user friendly, someone should tabulate all the entries and prepare a nice little spreadsheet (basically spoonfeed the data to someone who can't be bothered to put in some time to do a bit of online research) And if it was just the fresh-out-of-the-factory models, you can have a single number against a particular model. But since quite a large chunk of the market still look for older cars, quite lot more aspects play a role and having multiple people reporting the actual numbers throughout the thread can paint a more realistic picture. But hey, if you don't mind tabulating that thread, that indeed would be a great help for many
Project Capri
Thanks mate So I thought on several occasions before but the goalpost keeps moving LOL. But yes, it is quite a milestone to have finished paint. Cautiously optimistic
Project Capri
Been quite sometime since I dug this thread up Needless to say, I missed the deadline to have the car ready for my wedding. However, it was almost constantly being worked on. The highlight reel is as follows 1. The water pump was p!ssing all over the place. Had the water seals and racers replaced. Yet to test if the repair is successful and will have to bring down a replacement if not. 2. Additional tinkering work discovered in the process of stripping the paint down. Biggest being a caved in roof due to shoddy repair work before. Which looked like a flat piece of sheet metal was used to cover a sunroof and covered with filler. Almost the entire roof was fabricated anew and extra structural support was welded on from the inside. The tinker did a number on this one and drastically cut down the amount of filler that would otherwise would have been needed. 3. The door handles, window trim and the grill were all powdercoated black. 4. Door locks and boot lock were repaired and a new key was cut. 5. And of course, what seemed to be an endless cycle of prep work for the paint. The car went through a couple of colour changes during the process. From the black guide coat to the White base coat and to this..... Ideally, I wanted the engine bay and the engine painted before it was mounted. Due to the modifications that were needed inside the engine bay to make room for the larger radiator and other ancillaries, that never happened. Right now, it doesn't look practical to pull the engine out to repaint. So we're making do with what can be done as is, lots of masking and skinned knuckles of the painters. The engine bay is painted blue already. the actual engine itself is up next. The wheels are already in a shop being painted and polished. Glasses are to be mounted and the wiring to be done in the foreseeable future. it's getting there
What To Look For When Buying A Bwm E46
Well I'll be damned! Did not see that until you pointed it out
Thanks MadMax, Did some reading on BMW forums and was lead to believe it's sort of a given. Will be sure to look into it a bit more and get it sorted. I had the cooling system pressure tested and replaced several O-rings, Thermostat housing and the infamous expansion bottle within the first couple of months after buying the car.
I get between 7 and 8 commuting in traffic. Have seen 10-11 with long hauls not babying the throttle. If you're going for the petrol with the N42, the engine burns a bit of oil. There's no conclusive amount considered 'normal' for the engine. But this is something worth checking.
only 2? really? While they are comparatively less in numbers than the diesels, I came across quite few for sale when I was looking for one. Ended up buying the one Bugatti recommended. It was not in tip top shape and I had to do some catch up work after buying it (including a full respray). Considering the age and the cost of maintenance, expect to attend to some preventative maintenance.
Steering Wheel Leather Cover Fix/installation
If it is a cover over the original steering wheel wrap, there's a place in Mount that does it. Got mine done a couple of months back and it seems to hold up well so far. Reasonably priced and you can get it done while you wait.
Off Roading For Beginner
Oh yes the Patrol. I was seriously considering a Y60 Flat roof when I moved back. But the wife shot that idea out of the sky and had to settle for a far more domesticated option. There were some nice examples that used to come up for sale at decent prices. But I also heard that body swaps and there was rampant cut and bud action with them, not sure how far that is true though.
Drove a friend's 3.8 V6 Montero on sand once. The first thing I noticed was that the visibility was much much better compared to the Wrangler I was using back then. Had enough power and never really had to redline it to get out of trouble. Haven't driven any diesels offroad so can't really say anything about that. But I would imagine the low end torque of diesels are why they are preferred. If you only plan to do light offroading, the Montero in stock guise will be more than enough. But as others have mentioned, the fuel costs might make saving up for the diesel a better idea.
Look up Bugatti on the forum
- Windshield Restoring
I quite a bit of research when I had the Jeep to swap the 31s to 35s. This may not be directly applicable to the Hilux but some of the general principles will still apply. first issue is clearance. Whether the tyres can clear the bodywork under flex and the fronts on lock to lock steering. This is where suspension lifts come in and wheels with the right backspacing will sort out any issues with the fronts. Your fuel economy WILL suffer, and speedometer readings will be incorrect. With the Wrangler (which has a 3.6 V6 engine), it was deemed safe to go up 35s on the stock differentials. 37s, 40s would need aftermarket diffs to maintain power to the ground and to avoid destroying the diff. I don't think this is something you should worry about, but just have a look online On the plus side, the truck will have a better foothold when you go offroad and it will badass
Petrol (N42) manual
