Everything posted by monty
Engine Heating
Hi Guys, Replaced the thermo and all good now. Pretty straight forward job it was at the end maithri, Don, jaga, Grand Civic...Thank you all guys ! monty
Engine Heating
Good point Don. Didn't know that. If that is how it is supposed to operate then it can also be a case with the circuit relays. Will have these points checked. Btw...mine is a 96 EK3. Thanks Don!
Engine Heating
Thanks jaga ! Yes, as you noted it's important that I look for a genuine thermo.
Engine Heating
Hi Guys ! Recently when I was on an outstation trip the car's engine heat level went up and the radiator water started boiling. Took it to a garage and was told that there were a couple of causes. What was found was a leak in one of the water hoses and also the radiator fan didn't seem to switch on/off at appropriate intervals to keep the engine cool. The problem with the latter was found to be with the thermostat which did not pass the required current to the radiator fan to switch on when required. Can this be a case where the leak in the water horse might have caused the thermo to run dead in passing the current? or is it that the thermo went dead first and the horse blew up due to over heated water running through? I currently have the fan working on direct current so it's switched on all the time (which I guess is not good for the fan). Will replacing the thermostat solve the problem ? Just thought of getting some advice from you guys on what to look for before taking it to the garage ppl. Thanks Guys ! Monty
Acceleration Problem
Spot on Don!.....Lubricating the cable did the trick. No friction now and pedals smooth Thanks Guys! monty
Thanks Don !. It really helps. Would get a mech on this one.
It's a manual. Thanks!
Thanks !. Mine is an EK3 97. I'll check on this. If it is the case what would be the best remedy for this?...will a tune up solve the problem to an extent or is there a need to cleanup the throttle carbon deposits? Thanks! monty
Hi Guys, I have been experiencing a slight problem with my vehicle lately in terms of gradual acceleration after a gear change. The accelerator pedal doesn't seem to be smooth enough for me to gradually increase the RPM immediately after a gear shift and feels a bit stiff for me to have full control over a continuous smooth acceleration. Can this be a problem with the accelerator cable or related to an engine tune-up (plugs/hoses) ? Thanks Guys !
Alloy Maintenance
Does anyone know of a good place around Colombo for restoring alloys from scratches and minor cracks ? Thanks Guys ! Monty
Civic Ek3 98-2000
Hola / Pilawoos...Thanks machang. Helps a lot
Civic Ek3 98-2000
Thanks Hola !. The thread helped me brush up on certain things. Couple of quick questions one could help me with : 1) Is it a fact that there is a fair cost difference between brand new 98-2000 EK3 models (usually 300 to 302-xxxx) and recon ones which are often under English numbers? If so I would like to know whether the reg. number is the major deciding factor for the overall price tag. 2) Can a pair of EK3 (2000) crystal head lamps be fitted in to a brand new EK3 (98/99) model (which rather carries a dull look) ? 3) I would also like to know what LEV is all about. Any special options? Thanks ! Monty
Civic Ek3 98-2000
Hi Guys, I'm new to the Civic scene and would like to know what significant differences are there among 98, 99 and 2000 Civic EK3 models and also whether there are any changes across brand new and recon ones, both cosmetic and options wise. Cheers ! Monty
