Everything posted by gNaveendra
- Wagon R Hybrid Engine Oil
Best gear to drive viva elite
Neutral! So no wear to the Gearbox. ??
- Number Plate Province Change
WHICH octane for VITZ?
Higher the Octane rating better the anti-knocking property! Though Octane 95 is encouraged, it is NOT worth the money you additionally pay comparing the Octane 92. No immediate visible difference. Therefore, Octane 92 is worth the price. Most of the times, it depends on the compression ratio of the engine. Read this thread. Compression ratio & Octane rating
- Cefiro a33 Problem
Difference between Putty, Cataloy and Filler
What is a Guide coat?
Fuel consumption
If the engine was swapped with 4G15 in Sri Lanka, won't the CR mention it under the 'Special Notes'? Is fuel efficiency of 7 kmpL for 4G15 engine is too low?
Fuel consumption
@Aj lancer Is the following information legit for your car? @Davy You may comment on this. Car originally had 1300 cc engine.
Coolant temperature sensor
Will this affect the starting/cranking?
Nissan FB 15 door lock meachnism
Though I fixed few times this door actuator mechanism as a DIY job, bit difficult to understand what are referring by 'Big gear wheel'. Maybe you could have posted few pictures of your DIY work.
- Honda FIT GP5 error on transmition
Honda ATF
A previous discussion on the same topic might help you. EK3_transmission
Fuel consumption
@Aj lancer Is your CS1 is Auto or Manual gear? You said that you did tune up 3 times in the past 1 year. Did they change the spark plugs all the 3 times??? Is there any indication for the under-compression in the piston chamber?
Fuel consumption
Welcome to the AL forum. What's the current fuel figure? IMO, it is difficult to check whether the t-belt is changed or not unless the previous owner/s reveal the detail. Bunch of members who owns/owned lancer are in this forum may help you in this regard.
Suzuki Swift 2002-2004 fuel economy
Both shares same engine? Whether engine is same as Swift?
Most fuel efficient sedan car??
N17 not that bad. It did 13 kmpL for 4 people, A/C on all the time during a day time travel stretched from Colombo to Anuradhapura. I never came accross Platz. May be other members in this forum can help you.
Coolant Issue...Suzuki HT51S
Is this the situation when your car is not running?
How to Pay Traffic Fines at Court
What do you mean? Will your advise work? I don't think so. Hooray!
I think you didn't understand the reply by Davy. Else you run the car w/o the radiator cap??? less likely!!! Is your radiator cap original or not? Radiator caps are not usual bottle caps. It has lots of engineering inside. A factory specified cap is essential to maintain pressure and to protect the cooling system.
The OP might have forgotten the expiry/renewal dates. Really should he hire a lawyer? If he do so, is it possible to escape from paying penalty?
My suggestions: N17, 110, EK3, ES8, CS1. Why do you prefer such specific 14 kmpL figure? Did anyone tell you? Pls don't open redundant threads, as it is annoying.
small japan car with good fuel economy
[emoji13] [emoji13] [emoji13] Sent from my [device_name] using http://AutoLanka.com mobile app powered by Tapatalk
MG ZS 2018
Why is this? Totally unwanted here.
