Anuz91
Everything posted by Anuz91
  1. Dear experts,, I have gone through the several posts that have been already discussed about steering rack repair regarding to electronic power steering systems. My vehicle is a toyota 121 and I'm having the same issue with the steering rack. I had gone to a nearby garage and they had adjusted (tightened) the rack for two times. When I visited to the same place today, they told me that now the steering rack cannot be adjusted and the only thing that can be done is to replace it with a reconditioned one. (The problem is the middle part of the rack has worn out more than it in the ends) I have heard still it can be fixed by using some nylon bushes. Is it true? If so from where can it be done? otherwise can you suggest me a place to do the steering rack replacement? (Place around Kandy will be much helpful) Thanks in-advance.
  2. Anuz91 replied to lasa's topic in The Lounge
    Guys hows your experiance on Bridgestone tyres and toyo tyres? (road noise/comfort/durability) Is it worth to spend more on toyo( considering its made in japan) over bridgestone?
  3. Today morning i went to a tire house to check the condition of the tires and found out that the front right side tire had deformed a lilttle bit even though the tire was not worn out. AS Muditha420 said the unevenness of the tire has resulted the pulling effect. Thank you guys for your kind replies. Have a wonderful new year. :)
  4. Thank you both for your replies. Muditha420: I guess this test will help me to find the cause for the problem hopefully. Thanks again machn. Will try this and let you all know.
  5. Dear all, Hope I might not be starting a whole new discussion on a previously discussed issue as i couldn't find any. Today evening as i was driving in the main road (carpet one) i clearly felt that my steering wheel is pulling to the right side. (It's not like constant pulling, it pulls and stops and again pulls and stops continuously) I checked all the tires for tire pressure and the problem dint solve. I have done my alignment checking few months back and did not do any repair in the suspension system afterwards. My car is a Toyota 121. What might be the cause for the problem? Thank you in advance.
  6. Did you check your PCV valve? take a look at the following video.It might help
  7. There's a place near Kiribathkumbura. Where i did my engine tuneup sometimes back.They did a pretty decent job.
  8. Guys, i have the same problem. could you someone recommend me a good place to check out my suspension system? my toyota 121 gives a rattling noise when it hits a bump or a pothole.
