Everything posted by PerfMad
Please Recommend Repair Place For Fit Aria Cvt Gearbox
I've opened a thread some time ago.. you may find some advices + places and pricing which was quoted during those days here http://forum.autolanka.com/topic/16737-honda-citygd8-2004-cvt-gear-box-issue/
Any Place For Alternator Repairs - Not Pala Please
https://www.google.lk/maps/@6.8991686,79.8921451,3a,75y,120.19h,86.97t/data=!3m6!1e1!3m4!1s9740wpwYoExTG-jITzB0hw!2e0!7i13312!8i6656
Try vipula motors @Nawala koswatta.. Does all sort of mechanical repairs as well as other car repairs (all in one i would say). I had an issue with my Lancer alternator (blown) he said bushes are worn out + a chip (if im correct), he replaced both (bushes b/n) and chip with a used one he had and everything including labor cost me 5500/- used it till i sell mine (more than 1+ years) never faced any issue.. I usually put all my cars here, since I know him for more than 15+ years and does a pretty good job with garage work + electrical work If anyone want his contact let me know i will post it here.
Honda Service Manuals - Free Download
Any idea where i can find the user manual for honda city 2001 model and 2004 models ?
Gear Shift Issue - Toyota Premio 240
Could it be an electrical fault or some fault in ECU? don't you think its better to do a scan and see if there are any faults saved in the ecu ? There is no harm in doing a scan .. Because as per my knowledge, if there is a gear box issue it should be mostly 1 or second gear since those are the most 2 gears that gets engaged in city driving.. 4th gear is highly unlikely.. anyways that's my 2cents.. over to experts
- Coolant Leakage
Gear Shift Not Smooth - 2004 Civic Es8 Exi (1.5Cc)
Glad you sorted it out.. Happy Motoring !!!
Coolant Leakage
If it's not lengthy enough to connect it properly i believe you can replace it with a radiator hose of same size.. Any garage will have spares for these.. It will not cost you more than 1k.. If you want to do it by yourself, you can find them almost any car parts shop i believe (Never had a Nissan brand, therefore not sure about specific car parts shop..) Best thing is, check the hose, Only if its not lengthy enough go to a garage and they will get it done for you.. This is a simple fix should not cost you more than 1k.
Coolant Leakage
Now that you have found the root cause, you can remove the hose from radiator cap end and check for any damages (make sure car is not hot when you are performing this).. My hunch is your hose end might have damaged, and that's what causing the minor leak. if it's towards the end of the hose, you can always cut the damaged part and fix it again (only if the hose is lengthy enough)
- Strange Noise In Driver Side Door Actuator
Initially i thought the same thing. But then i realised, if that's the case it should happen always ya? and it should happen when i try to open it with key as well.. My hunch is, the lock/unlock system i have in mine, may be sending wrong or multiple signal to the driver side actuator ( i believe which allows the rest to open, just as universal centre locking systems).. Is there anyone who is good at checking the control box of my center locking system (if that the root cause)
Hi Guys I bought a Honda City 2001 model recently and I got 2 remote keys with flip key remote. Previous owner told these were there when he bought it as well. Remote is bit similar to this https://www.google.com/imgres?imgurl=http%3A%2F%2Fwww.ecutool.com%2Fproimg%2F2_Buttons_Flip_Remote_Key_Shell_for_Suzuki_K213003_b.jpg&imgrefurl=http%3A%2F%2Fwww.ebay.com%2Fitm%2FCar-Keys-Fob-SwitchBlade-Key-Flip-Case-for-Suzuki-SX-4-SX4-Swift-Remote-%2F190892860497&docid=YepJHHj9yHaZfM&tbnid=JpsKiEBeD8lihM%3A&w=650&h=325&bih=741&biw=1600&ved=0ahUKEwiWv-T3oZzMAhVBv44KHfkDAP0QMwgfKAIwAg&iact=mrc&uact=8 However, this remote has only LOCK/UNLOCK functionality. The issue is when I try to unlock it i get a strange sound like driver side actuator is trying to unlock itself several times (drrrrrrrrrrrrrrrrrrrr sound). This does not come when i try to LOCK the car by remote. Also I noticed that, this issue occurs only if i try to LOCK and UNLOCK at the same time. For an example, let's say I LOCK the car by remote, then UNLOCK it using the key from driver side door (not the remote) -> No strange sound all doors gets unlocked If I then try to LOCK it again with remote and then UNLOCK it by REMOTE (this time it works without any sound) but if i perform this step again, then I get this annoying sound. What could be the issue for this ? Currently what I does is, use the remote to LOCK and unlocking will be done by the KEY. Rarely I unlock it with the remote (only if I perform the 1st step) Appreciate your expert feedback on this..
- Nissan Tiida Latio Fuel Gauge Incorrect Reading
First of all welcome to the forum and congratz on ur purchase .. Coming back to your issue, to me it looks like something wrong with you fuel gauge sensor.. Early days there used to be floaters to determine the fuel level, but new cars has a sensor to signal the level. I don't think as per the age of this car it could be a fuel gauge issue rather its a sensor issue. Get this checked with a good mechanic, he should be able to solve your prob. This is my 2 cents on this. Open for experts ideas and comments
Ac Repair Place For A Honda
you can find a recon one for a lesser price i believe.. My opinion is take it to another ac repair center.. I usually goes to a place situated @ethul kotte right next to the first bus stop.. Their work is really impressive and prices are reasonable as well. I recently replaced my honda GD8 RECON compressor + cabin air filter + labor +refilled gas and serviced whole AC unit(if im not mistaken) and it cost me only 23000/- (if i remember correct)
Toyota Engine & Gear Box – Kr41
So what you are looking for is a petrol engine ?? I have no clue about this, but happy hunting.. To help you out i'll bump the thread.. Just a headsup, check enginewatta @panchikawatte.. They seems to be having lots of engines, pay a visit and see. cheers
Honda City (Gd8) Idle Drops Way Below Than 500
Hey Guys Latest update.... Looks like the culprit was the fuel pump( i assume that's what you mean by fuel pressure regulator). The one which was replaced was also a defect(had a leak) and due to that I had issues with starting (usually car starts from 3 cracks, but after replacement it was 4-5). Changed the fuel pump again with a good one and everything was sorted. Total cost was around 13k (tuneup, 1 coil pack replacement, fuel pump & labor) Thanks for your valuable inputs guys..
Hi All -->[ Latest update ] I got the car yesterday and mechanic have done like 5-10km ride and he claimed issue didn't come up.. I also drove it for like 5-10km and the issue came up again. After the recent changes yesterday i felt like; - Car cranks few more times than it was before to get it started (what could be the issue ?) ** I'm gonna put the car to the mechanic again tomorrow to get it scanned Could this be due to CVT gearbox failure ? Yesterday I noticed that once I put it to D and hold the brake paddle for sometime rev goes down and it starts to shake and feel like gear engaging and disengaging .. sometimes it keeps happening, but sometime when i release the brake paddle it moves without any issue..
I just called him, he have cleaned the sensors during the tune-up, and he have replaced the fuel pump as well.. now as per him issue is sorted.. I'm gonna take it home today and check it these days to make sure its gone permanently.. if issue persists will contact you all.. Thanks everyone for your valuable inputs. Cheers
Hi Gayan Yes i was referring to this. And he have replaced the broken one, not quite sure whether its a recon or brand-new. I was told that it cost 6000. Even after that issue didn't resolve. Latest update is, he has replaced the fuel pump in petrol tank which again cost me 3000. Hope that will fix the issue.. Anything else that can be think of ??
Hi Davy I really can't remember what he told, but he said there was lot of carbon and he cleaned everything.. I need to check with him whether he cleaned Idle Air Control valve and MAF sensor as well ( Thanks for reminding me that) Im not pretty sure he checked those or just cleaned the throttle body + injectors
No tappet sound.. Engine runs smoothly even in neutral, issue comes only when the gear is engaged. Cannot move the car at all, more I press the gas pedal more it try to stall, as soon as I put it to neutral it idles properly.
When i meant by plugs i think i was referring to coil packs.. Mine has 8 packs (8 spark plugs) so only one was broken and replaced it.. Just called the mechanic and I was told that petrol pump was blocked a bit (he has replaced it).. He will do few trails .. could it happen due to anyother reason? Since this doesnt happen always as in as soon as u start or not may b in short distance sometimes, its not easy to replicate the issue as well.. But last few days issue came up everytime, therefore mechanic is checking everything related to fuel line at the moment.
- Hum/rattling Sound - Disappear With Clutch Pressed
