asier
Everything posted by asier
  1. could be dirt on sensors..when trouble shooting go from the cheapest to the most expensive repairs.
  2. Thats neat ....but can the millage figures be manipulated of a E46?? most forums says its near impossible but after reading this not so much it seems..
  3. the amount of ridicules about euros are too damn high...yet thats why these sweet rides are affordable ...
  4. whats ur car??the engine?? may be you are only doing city driving...last wk only did long runs highway and low traffic roads gave me good 14 average...if not go see a mechanic check ur plugs etc
  5. the petrol fuel figures are bit misleading they do average of 11-12.5kmpl....8.5-9 is city figures...this is for n42 motor
  6. yes i saw one in a photo album of a bmw meetup,a blue pre facelift convertible...havent seen a single one up for sale, can imagine why owners keep them.. sorry feels like i have hijacked the thread..
  7. if you are going for a petrol i can provide you wt some insight...btw are there any facelift six cylinder e46s here in sl..have neva seen one..
  8. 4D56[edit] Displacement - 2.5 L (2,476 cc) Bore - 91.1 mm Stroke - 95.0 mm Fuel type - Diesel This engine is also built by Hyundai in South Korea, meaning it also sees use in some products made by their Kia subsidiary. Non-Turbo[edit]Power - 55 kW (74 hp) at 4,200 rpm Torque - 142 N·m (105 lb·ft) at 2,500 rpm Engine type - Inline 4-cylinder SOHC Fuel system - Distribution type jet pump Compression ratio - 21:1 Non-intercooled Turbo[edit]Power - 84 PS (62 kW) at 4,200 rpm[13] Torque - 201 N·m (148 lb·ft) at 2,000 rpm Engine type - Inline 4-cylinder SOHC Non-intercooled Turbo (TD04 Turbo)[edit]Power - 90 hp (67 kW) at 4,200 rpm Torque - 197 N·m (145 lb·ft) at 2,000 rpm Engine type - Inline 4-cylinder SOHC Fuel system - Distribution type jet pump Compression ratio - 21:1[14] Intercooled Turbo (TD04 water-cooled Turbo)[edit]Power - 78 kW (104 hp) at 4,300 rpm Torque - 240 N·m (177 lb·ft) at 2,000 rpm Engine type - Inline 4-cylinder SOHC Rocker arm - Roller Follower type[15] Fuel system - Distribution type jet pump (indirect injection) Combustion chamber - Swirl type Bore x Stroke - 91.1 x 95mm Compression ratio - 21:1 Lubrication System - Pressure feed, full flow filtration Intercooler Type - Aluminium Air-to-Air, Top-mounted Turbocharger - Mitsubishi TD04-09B Also known as Hyundai D4BH[16] Intercooled Turbo (1st Generation DI-D)[edit]Power - 85 kW (114 hp) at 4,000 rpm Torque - 247 N·m (182 lb·ft) at 2,000 rpm Engine type - Inline 4-cylinder Fuel system - 1st Generation Common Rail Direct Injection (CRDi) Compression ratio - 17:1[14][17][18] Intercooled Turbo (2nd Generation DI-D)[edit]Power - 100 kW (134 hp) at 4,000 rpm Torque - 320 N·m (236 lb·ft) at 2,000 rpm Engine type - Inline 4-cylinder Fuel system - 2nd Generation Common Rail Direct Injection (CRDi) Compression ratio - 17:1[14][17][18][19] this is taken from Wikipedia...im no expert on this but they heve improved the volumetric efficiency thus increasing power efficiency and torque
  9. guys any place where i can get a mig welding done on snapped side mirror..parts are aluminum...replacing would drain my purse.. around colombo
  10. any one who can help me to find place where mig welding is done or any other place to fix fev broken aluminum parts of may car...
  11. Guys iv being eyeing for an e46 318i for few months now...but most cars i found online and contacted are there for months without selling..now im having second thoughts about having one..any one can give a probable reason for this???
