Rookantha
Everything posted by Rookantha
  1. Hi, I came across this gadget in the web and would like to know your experiences and ideas about it. Does it really work? as the manufacturers say this is the way it works "FUELSHARK - HOW IT WORKS JUST PLUG AND SAVE! The components in your car's electrical system are interconnected with each other. To get superior performance from your car, it must have a clean electrical circuit environment. Many cars develop electrical imbalances over time due to the power demands made by various accessories and normal wear on batteries, spark plugs and other parts. To maintain optimum electrical performance and improve MPG, your car will run better with a stable voltage environment. The Fuelshark provides just that. It is a multi-purpose Voltage Stabilizer. Fuelshark's design instantly stabilizes your car's electrical system, resulting in better fuel efficiency and overall performance. By stabilizing your car's electrical system, one big benefit is that your engine's spark plugs deliver a strong even spark, resulting in better combustion. This can increase power and MPG, in addition to having cleaner emissions. This revolutionary technology provides consumers with an inexpensive way to save money at the gas pump and help our environment at the same time. Better yet, there are no installation charges. Just plug the Fuelshark into your cars lighter adapter and the blue light will let you know that the Fuelshark is working, and reminds you that you are saving money! '
  2. Thank you for your suggestions.
  3. http://s394.photobucket.com/user/Rookantha/media/DSC_0021_zps6h1ya9ah.jpg.html http://s394.photobucket.com/user/Rookantha/media/DSC_0020_zpswj318cvm.jpg.html
  4. I have a similar problem in my Alto. A screeching noise when cutting full and tightness in the wheel.
  5. Guys, I too had to face the same incident recently. Mouse entered to the engine area and damaged wires. I couldn't even start the car. Got a local technician to reconnect the wires. Should I need to do a rewiring? then who will be a good tech on this around colombo? after reconnecting I didn't face any problems with wiring system. PS: How we can add photos to this thread?? Rookantha
  6. I asked from A*W and they gave me a quote of Rs 15,664 + VAT. Their response is quoted below. " full service will include the Oil and filter change, Body wash, Interior vacuum cleaning and exterior wax coting. Additionally based on Manufacturer recommendations the 20,000km service needs to consist of a Rear brake clean and adjustment and the Replacement of Sparkplugs, Radiator coolant and Brake oil. Based on your vehicle service history the Gear oil, Air filter and Rear brake washers will need to be replaced if not previously done as this is not indicated in our system. Furthermore kindly note that each service will include a full technical inspection which will identify wear of suspension components, Oil leaks ect. The steering and the clutch system issues will be diagnosed during this inspection (Kindly inform your service advisor of the abnormality)." Item no Description Quantity Amount(Rs.) 1 FULL SERVICE 2,500.00 2 CHANGE RADIATOR COOLENT 1,250.00 3 CHANGE BRAKE OIL 1,250.00 4 CLEAN REAR BRAKE 625.00 5 WHEEL ALIGNMENT 1,375.00 Parts 6 COST OF SUNDRIES 650.00 7 BP-VISCO 3000 20W50 TG SLCF 208L 2,067.00 8 CA-AXLE GL-5 90 208LT IFN 2.500 1,365.00 9 FILTER ASSY,OIL 1 655.00 10 ELEMENT AIR CLEANER M ALTO/WAGON R IFN 1,105.00 11 CA-Brake Fluid DOT 4 250ml 2 724.00 12 PISTON CUP SET M 800 IFN 2 448.00 13 BP-ISOCOOL 1L 3 1,650.00 Sub Total 15,664.00 VAT @ 11.00 1,723.04 Total 17,387.04 What do you recommend as you have experience on this. Is it worth taking the vehicle to A*W or it is better to get the services done by local service center?? Your advises on this highly appreciated. Rookantha
  7. Hi, Thank you for the response. I'd be glad if you can share a checklist that should be attended to during the service.
  8. Hi All, The next periodical service of my car (Maruti Suzuki Alto) is around the corner. Now 20000Kms done. I'm thinking of whether to put it a local service center or to A*W Service. What is your suggestion? Will A*W do a good job? Now I feel that the clutch and steering wheel is bit tightened. Can you pls help me as to what should be done in a full service? Regards Rookantha
  9. Hi, I'm driving a Maruti Alto 800 (2010). Hope some expert can help me with this. 1. What is the ideal gear shifting ratio as this doesn't have a RPM meter. can you tell me which speed which gear. Usually I do shift as follows 1st to 2nd : 20kmph 2nd to 3rd : 30 kmph 3rd to 4th : 40 kmph 4th to 5th: 50kmph is it OK for the engine and fuel economy?? 2. Recently I went on a trip to Jaffna (Full flat straight roads) with wife and our baggages. My car did something around 21Km/l (Calculated using full tank to full tank method) in cities it does only 12 - 13 km/l Regards
  10. Hi, I was just searching for help for Altos and found this. I can see its been almost 3 years from the last response but want to know few things as I'm also driving Maruti Alto 800 (2010). Hope some expert can help me with this. 1. What is the ideal gear shifting ratio as this doesn't have a RPM meter. can you tell me which speed which gear. Usually I do shift as follows 1st to 2nd : 20kmph 2nd to 3rd : 30 kmph 3rd to 4th : 40 kmph 4th to 5th: 50kmph is it OK for the engine and fuel economy?? 2. Recently I went on a trip to Jaffna (Full flat straight roads) with wife and our baggages. My car did something around 21Km/l (Calculated using full tank to full tank method) in cities it does only 12 - 13 km/l Regards
