dpk Posted June 25, 2015 Posted June 25, 2015 Dear All,I owned a Toyota passo 2007 car and it gives steering noise(sound likes when we open a corroded door,) after drive 12-15 Km in any road condition, when turning steering wheel both ways. but this is vanish when we stop the car and leave it for a night. could you please help me to come-out this matter. Thanking You Quote
Rookantha Posted June 25, 2015 Posted June 25, 2015 I have a similar problem in my Alto. A screeching noise when cutting full and tightness in the wheel. Quote
MV-5 Posted June 25, 2015 Posted June 25, 2015 I have a similar problem in my Alto. A screeching noise when cutting full and tightness in the wheel. belt which drives the PS pump Quote
The Don Posted June 25, 2015 Posted June 25, 2015 Dear All,I owned a Toyota passo 2007 car and it gives steering noise(sound likes when we open a corroded door,) after drive 12-15 Km in any road condition, when turning steering wheel both ways. but this is vanish when we stop the car and leave it for a night. could you please help me to come-out this matter. Thanking You This could be worn bushes or lack of lubrication. Lubricate the points that need to be lubricated and check things like tie rod ends, rack ends etc. The bushes might have got to a point, they have hardened due to use and old age. I have a similar problem in my Alto. A screeching noise when cutting full and tightness in the wheel. Like MV-5 has said, tighten the power steering belt Quote
dpk Posted June 29, 2015 Author Posted June 29, 2015 Thanks Don, but problem happen only after run 12-14 Km continuously Quote
bycap Posted June 29, 2015 Posted June 29, 2015 May be Shock absorb mounts are broken. You can inspect it easily. Quote
The Don Posted June 29, 2015 Posted June 29, 2015 Thanks Don, but problem happen only after run 12-14 Km continuously Well clearly the noises can only happen from moving parts. Either there is play, wear or some of the replacement parts are good quality. For example I replaced my rear suspension bushes with some thai ones I found from Panchikawatte. One of the rear ones squeek when it moves around. There is nothing that can be done about it apart from replacing them with proper bushes which comes with the suspension arm. Quote
dpk Posted June 30, 2015 Author Posted June 30, 2015 Don, Can't it be from EPS motor(when motor hotter or something) Quote
