Everything posted by Ted
How To Reset Limit Switch In Toyota Premio 260
Hi all, My toyota premio 260 driver side power shutter was repaired and now the limit switch is not functioning properly.. that means there is a time out in the stepper motor. I tried to reset it by pressing coupl of secs when ignition but it didn't work? Can't it be reset without taking the motor outside? Anyhow..if this problem had to anybody..kindly request to pod0st how he came up with it.. Thanks..
Power Shutter Repair
Hi asrock... I was able to fix the glass attached to the sliding bar.. now i only have to resent the timer...your link will be very much used to me.. thanks a lot buddy...
Xenon Light Not Working Toyota Premio
Yes i have an HID kit. And this kit is has been installed in japan. Brand name is Leaps. There is also a canceller unit for each side kit. Do you know any electrician who can identify faulty point so that i don't have to buy a total kit. Thanks for your infor as well.
Hi, Previously only one buld was not working ( totally off) and other bulb was working. Now the working bulb is blinking fast. So one is totally off and other is blinking. I am not sure wht really has happened. Do you know any place to get this checked?
Thans for the advise.. I have normal Xenon not original HID. Do you know any place from which I can test wether bulb or ballast unit or both malfuntioning?
Hi, I have a premio 2010 manufac. 2 weeks ago when i started the car left side Xenon light was not working. Then I witched off and on the light switch. Then two lights were okay. No problem happened untill yesterday. 3 days ago i replaced a new battery and yesterday started the car and i saw the same light was not working. Then i switched on and off several times but only one light ryt hand side was working. Also so etimes both Xenon lights were not working. All other lights are working.Does anybody know wht has really happened?
Fix It Pro Scratch Remover
Hi all, Does anyone have experienced the scratch remover called fix it pro? Does it really work for very tiny scratches visible as white lines?
I have a premio 260 and my power shutter of driving side door has to be repaired both mechanically and electrically, 1) have to fix the glass mounting clips to the sliding shafts. 2) Have to reset the timer of power shutter motor. I want to find the best place capable of doing above repairs. Repair centers with big names have done some mistakes to my car in past..so i want to find a good place taking care each step. Kindly request all to share your information with me... thanks.
Power Shutter System Repair
- Toyota Premio
- Toyota Premio
